Old 22-11-2008, 01:44 PM   #1 (permalink)
Question REALLY weird problem !!!
I got a bsnl connection a month back......everything was and still is fine
but i realised dat my max speed is lmited at 100KBps .....
my neighbour gets 200-240 KBps
i checked my router config. page....it says max line(down) rate 1022 kbps !!!
i mean, it can't possibly b a line problem......da guy living js 50 metres away gets 2mbps......
i called up da internet guy......he said he'd never heard of such a problem b4.......
googling returned only 1 useful result ........apparently ,sum guy had got da same problem b4,posted in a forum.....but der ver no useful replies(sum1 suggested sum problem in da firmware.....n it dated back to 2006 .
i hav a new router : D-link GLB 802c
ne help wld b highly appreciated...thanx!
aditya
earthen61 is offline
Old 22-11-2008, 04:24 PM   #2 (permalink)
paroh's Avatar
Default Re: REALLY weird problem !!!
BSNL or MTNL people them self don't know any think about broadband. First check what the attenuation rate and snr margin in ur router.
paroh is offline
Old 22-11-2008, 08:43 PM   #3 (permalink)
my router shows 8000kbps and am on 750UL connection :/
Faun is offline
Old 22-11-2008, 09:27 PM   #4 (permalink)
Vendor ID: 0039
Revision Number: E.37.9.48
Serial Number: 123456789abcdx
Local Tx Power: 12.4 dB
Remote Tx Power: 20.5 dB
Local Line Atten.: 34.0 dB
Remote Line Atten.: 18.5 dB
Local SNR Margin: 37.5 dB
Remote SNR Margin: 29.5 dB
Self Test: Passed
DSL Standard: ADSL2+
Profile: MII
Tx Line Rate: 509 Kbps
Rx Line Rate: 1022 Kbps <----------------here's da problem!
Max Attainable Line Rate(Down Stream): 10964 Kbps
SRA Parameters
Auto SRA: Disable
SRA CRC Error Rate: 1800
SRA FEC Error Rate: 60
SRA Up Shift Obs. Period: 3600 Secs
SRA Down Shift Obs. Period: 600 Secs
Power Management Mode:
aditya
Old 23-11-2008, 10:02 PM   #5 (permalink)
uhh.........ne suggestions?
aditya
Old 24-11-2008, 09:22 AM   #6 (permalink)
paroh's Avatar
I think every think is ok . U should try to change ur modulation to (G.Dmt). If still it not work u should call to ur ISP to check ur synchronized speed at mtnl server end.
paroh is offline
Old 24-11-2008, 03:05 PM   #7 (permalink)
tried da g.dmt mode...........din help...speed increased from 1018 to 1024kbps
called da guys at bsnl......everything's fine at their end
they said dat there may be a problem with the line........too many joints or sumthing.......
aditya
Old 03-07-2009, 12:14 AM   #8 (permalink)
...i'm still open for help , u know !
aditya
Old 03-07-2009, 12:15 AM   #9 (permalink)
hehe...tulululu...nebody there?...ppl...momma?...nebody?
aditya
Old 03-07-2009, 01:00 AM   #10 (permalink)
Freshly Churned Chutny :)
Debu_013's Avatar
Is your ADSL modem not obtained from BSNL?
BEcause i cant find the Dlink model on their model list at
http://www.calcuttatelephones.com/da...tall/menu.html
+==CPU= AMD Athlon II X2 250 3.0 GHz
+==MB== AMD 690V (MSI K9AGM4)
+==RAM= Transcend 2GB DDR2 800MHz
+==Graphics_Card= XFX GeForce 8600GT 256MB GDDR3
Debu_013 is offline
A weird problem fuzzz Software Q&A 1 14-04-2008 01:45 PM
weird problem in XP its_me_jeet Hardware Q&A 4 25-09-2007 10:07 PM
Weird Lan Problem zodiac_511 Networking 3 25-09-2005 08:27 PM
Weird Problem!!! zegulas QnA (read only) 3 26-07-2005 05:51 AM
a weird problem.... hearthacker QnA (read only) 11 03-06-2005 08:04 PM
