Old 19-11-2008, 10:33 AM   #1 (permalink)
sganesh's Avatar
Default need help in installing joomla
Hi,
i need to setup
Joomla on my local machine XP,
i ve installed xamp5 and joomla1.5.8 stable edition,
i ve extracted content of joomla to c:/wamp/www/,then
i started xamp,when i typed in local browser
http://localhost/joomla/installation/index.php
it says
Fatal error: Class 'JRequest' not found in C:\wamp\www\joomla\libraries\joomla\import.php on line 33
kindly fix this issue!
Thanks
sganesh is offline
Old 19-11-2008, 10:53 AM   #2 (permalink)
GaurishSharma.com
gary4gar's Avatar
Default Re: need help in installing joomla
*Are you using PHP4 or PHP5?
PHP5 has some problems, try using PHP4
*maybe the files are corrupted.
gary4gar is offline
Old 19-11-2008, 11:17 AM   #3 (permalink)
sganesh's Avatar
im using wamp5 server which has php version 5.2.5
sganesh is offline
Old 19-11-2008, 01:41 PM   #4 (permalink)
wamp5 is the solution my friend.. Just install it. Unzip joomla into the webdirectory.
Start from scratch. Uninstall both xamp and wamp. Delete the directories.
Then install wmap5 from biginning.
AMD 64 X2 5000+,Gigabyte GA-MA69VM-S2 ATI Radeon. Corsair 667 MHZ 1*2 GB PC 5300, Dell 19 LCD.
krinish is offline
Old 19-11-2008, 02:16 PM   #5 (permalink)
╬Switch╬'s Avatar
I think you should try and redowload the joomla zip.
There are 10 types of people. Those who understand binary and those who don’t…
╬Switch╬ is offline
Joomla or Drupal ? digster QnA (read only) 3 22-07-2008 11:47 PM
Joomla Shift appu QnA (read only) 8 24-06-2008 05:36 PM
Joomla NucleusKore Open Source 5 05-02-2008 10:17 PM
How easy is Joomla? goobimama QnA (read only) 4 13-12-2007 09:13 AM
Joomla + SMF Maverick340 Open Source 3 16-03-2006 03:50 PM
- by gforz
