when ever i open my d-partetion it shows error message saying Windows Explorer has encountered a problem and needs to close. We are sorry for the inconvenience.
it will ask me to close the menu. so i can' read/write datas in my d-partetion.
Than most likely it is shell problem. Download shellexview.
1. When using shellexview disable the shell by right clicking them as there are lot of shell for fast result select and disable 50-60 item in one go. after disabling them check whether u are getting the same error by opening ur drive. if u still get the error enable the disabled shell item and again select other 50-60 item and disable them and again check whether it works or not. And when u find the shell which is causing the problem only disable that shell and enable all other shell
