| Forum |
#1 (permalink) |
I have tried to do as you all mentioned,thanks for that BUT......... I tried to install antivirus,but the msg comes saying" you have another antivirus/security product installed on this computer,it is advisable not to have more than one anti virus,we recommend you cancelll this installation and uninstall the current anti virus product" WHat it means,although i have uninstall all the antivirus and clean the registry manually and through software also.please suggest me. Thanks |
#2 (permalink) |
EXIT: DATA Junkyard
Well, install ur earlier antivirus again
Then uninstall using Revo Uninstaller Run CCleaner registry fix After that, restart, and install ur new anti-virus
http://pleaseguide.me/ |
#4 (permalink) |
AFK
Use Ccleaner on your system. restart and then install.
Check out http://thefinal3rd.com, an Indian footie blog. Follow me on http://twitter.com/thewisecrab Fishdumplings!! Duniya goal hai? |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| suggest an antivirus | himadri_sm | Software Q&A | 5 | 10-11-2008 09:38 PM |
| NOD32 antivirus v.s. Kaspersky antivirus | cooldudie3 | Fight Club | 42 | 08-10-2008 01:28 PM |
| Please suggest me a good antivirus | amrit1 | Software Q&A | 13 | 12-05-2006 10:39 PM |
| Norton Antivirus 2005 vs Symantec Antivirus Corporate | Curious Guest | Software Q&A | 1 | 23-04-2005 08:37 PM |
| Antivirus Installation | dando | Software Q&A | 11 | 16-03-2005 07:03 AM |
