Old 10-11-2008, 05:45 PM   #1 (permalink)
Extheist
aditya1987's Avatar
Question No 6 Channel sound in Media Player Classic?
Hello guys!!
I have a problem i have recently updated k-lite codec pack from "4.1.7" to "4.2.5". Before the update I used to get 6 channel sound on all video files that had 2 channel sound in Media Player Classic. Now I do not get 6 channel on these video files after updating. I get 6 channel sound in those video files which has 6 channel sound. Also when running the same files in VLC player I get sounds in all 5 speakers. But I do not like VLC player because it does not automatically deinterlace the video.
So please help to me to configure MPC so that I can get 6 channel sound..
Thanks,
Waiting for your reply
aditya1987 is offline
Old 10-11-2008, 09:17 PM   #2 (permalink)
swatkat's Avatar
Default Re: No 6 Channel sound in Media Player Classic?
Go to View Menu > Options. Here, click on "Audio Switcher" under "Internal Filters" branch. Select the option "Enable custom channel mapping" and then choose the appropriate speaker configuration. Click "Apply" and "OK". See if you can get audio output from all your speakers.
Also make sure that proper speaker configuration is selected in Windows Control Panel. To check this, go to Control Panel > Sounds and Audio Devices applet. Here, click "Audio" tab and click "Advanced" button in "Sound Playback" section and then choose proper speaker layout.
http://swatrant.blogspot.com/
swatkat is offline
Old 10-11-2008, 10:07 PM   #3 (permalink)
Extheist
aditya1987's Avatar
Thanks for your reply
I tried what you said but it dosen't work
EDIT:- I opened view>options>Internal Filter>Transform Filter and ticked AAC,AC3,MPEG Audio. And it worked now I get sound in all speakers.
Old 10-11-2008, 10:14 PM   #4 (permalink)
swatkat's Avatar
Hmmm... Are you using latest version of MPC? IMHO, VLC is better than any other player out there
Cool! You can now stick to MPC then
swatkat is offline
Old 10-11-2008, 10:26 PM   #5 (permalink)
Extheist
aditya1987's Avatar
I dont like VLC because you cannot seek flv videos in it. And also it dosen't deinterlace the video automatically.
Old 10-11-2008, 10:32 PM   #6 (permalink)
swatkat's Avatar
Okay! Good that you were able to fix the 6.1 channel issue in MPC
swatkat is offline
Old 19-05-2009, 09:40 PM   #7 (permalink)
I know this is an old thread, but I signed-up just to say THANK YOU both! You saved me a lot of grief, now I can enjoy my MKVs at full 4.1 and keep MPC ^^
Oh and Swatkat, sorry but though VLC is a decent program but MPC is much more flexible
Anyways, thanks again guys
~Avalon
Avalon is offline
Media Player Classic Equalizer plug-in Ethan_Hunt Software Q&A 4 24-03-2008 11:43 PM
Windows Media Player Classic Plugins?? subhajitmaji Software Q&A 2 29-10-2006 10:37 PM
Media Player Classic problem himanshu_k_c Software Q&A 2 26-09-2006 07:45 AM
Help Media player classic error pirates1323 QnA (read only) 1 05-06-2005 09:15 AM
