Old 09-11-2008, 07:46 PM   #1 (permalink)
Default cd rom drive
I am using windows XP and have CD ROM drive. Oflate I came to know that my CD Rom is not reading any CDs. But from the folder My Computer when select eject CD, the tray comes out. It means that my PC is communicating with my CD drive. But it is not reading any CDs. Is the drive corrupted?
Ramasamy59 is offline
Old 09-11-2008, 08:11 PM   #2 (permalink)
AFK
thewisecrab's Avatar
Default Re: cd rom drive
Originally Posted by Ramasamy59 View Post
My computer is communicating with the computer. Yet it do not read any CD. Please help me.
Is this some kind of a trick?
Check out http://thefinal3rd.com, an Indian footie blog. Follow me on http://twitter.com/thewisecrab
Fishdumplings!! Duniya goal hai?
thewisecrab is offline
Old 09-11-2008, 08:19 PM   #3 (permalink)
AJJU
azzu's Avatar
i think he is really unsure wat to ask or he is a Spam !!
I love and Live to Design
azzu is online now
Old 09-11-2008, 08:24 PM   #4 (permalink)
PhB
Jughead!!!
PhB's Avatar
What's that supposed to mean?
PhB is offline
Old 09-11-2008, 08:41 PM   #5 (permalink)
I think he means "My computer is communicating with the CD drive, but still does not read the CD".
Bandu is offline
Old 10-11-2008, 06:55 PM   #6 (permalink)
AFK
OK...the post has been edited now....
How old is the drive?
What sort of CDs are you trying to read?
Old 11-11-2008, 10:36 AM   #7 (permalink)
PhB
Jughead!!!
PhB's Avatar
Hey! That happened to my DVD drive also. It couldn't read any discs. So I cleaned the lens with a CD lens cleaner.
PhB is offline
Old 11-11-2008, 10:53 AM   #8 (permalink)
Fullbring
Zangetsu's Avatar
Just an ejecting tray doesnot mean a full communication with the system...
u can eject the tray by only plugging the powercable also...
Just use a good lens cleaner...coz there may b dusts inside & also use a good clean \
CD...
if nothing works then take it 2 a service center..
Windows OS Calculator Bug
Sqrt(9) - 3 = check the answer
Zangetsu is offline
Old 11-11-2008, 10:59 AM   #9 (permalink)
PhB
Jughead!!!
PhB's Avatar
And also by prodding the tiny hole in the drive with a pin, you can eject it. Put a dab of liquid on the cleaner if it doesn't work the first time.
PhB is offline
Old 11-11-2008, 11:44 AM   #10 (permalink)
Cool Buddy's Avatar
When this happens, its time to buy a new drive. this is common, nothing new. if lens cleaner doesn't help. then its gone. taking it to service centre is useless if its out of warranty, they will quote the price of a new drive for repairing the old one.
BTW this post is in software troubleshooting?!
AMD Phenom II X4 840, 4 GB RAM, MSI HD5670, Corsair CX400 PSU
Nokia 5230
Canon IXUS 115 HS
Cool Buddy is offline
Old 11-11-2008, 12:45 PM   #11 (permalink)
Even lense clearner is not working
It is more than 5 years old. All type of CDS. Even lense clearner CD also not working
Old 11-11-2008, 12:55 PM   #12 (permalink)
Fullbring
Zangetsu's Avatar
Then its time 2 say goodbye 2 it..RIP
Zangetsu is offline
Old 11-11-2008, 02:58 PM   #13 (permalink)
Which brand is it?
One last thing you could try before you discard it is to check if the data cable is fixed correctly. If possible try using the drive on another comp (dont use the same cable!).
Raccoon is offline
Old 11-11-2008, 04:24 PM   #14 (permalink)
AFK
5 yrs?
Time to say good bye to it now,
you can get a DVD writer for 3K these days....
Old 11-11-2008, 04:54 PM   #15 (permalink)
Fullbring
Zangetsu's Avatar
Originally Posted by thewisecrab View Post
5 yrs?
b-low 3k..he will get a SATA HDD
DVD writer b-low 1.5k
Zangetsu is offline
Old 11-11-2008, 05:06 PM   #16 (permalink)
AFK
Yeah...well I bought my drive 2 yrs ago, it was 3 K then...now it's about 1.2K I guess
Old 11-11-2008, 05:12 PM   #17 (permalink)
5 yrs?
No logic in throwing away a working drive just because its 4 years old!!
As for prices, LG DVD writer is available for 1,050 here. I bought my Moser Baer LiteOn for 1,200. That was couple weeks back.
Raccoon is offline
Old 11-11-2008, 10:35 PM   #18 (permalink)
AFK
My logic is that the drive definitely must have exceeded the warranty period now.
Also, since it is about 5 years old, it will be heavy on the pocket to fix it too.
In most cases, a new drive can be bought with better features at the same cost of repairing the old one (if not cheaper)
So, it is better to go for new a drive once you are sure the old one refuses to work despite repeated attempts (AFAIK, this is clear from the fact that even lense cleaners have no effect)
That all
PS. my 700th post
Old 11-11-2008, 10:46 PM   #19 (permalink)
PhB
Jughead!!!
PhB's Avatar
So thread closed?
PhB is offline
Old 12-11-2008, 01:16 PM   #20 (permalink)
It is the age of USB drives. Can't we work without CD Rom drive?
Old 12-11-2008, 02:27 PM   #21 (permalink)
AFK
Yes, I agree. But what will you do if you dont have a pen drive at the moment? what will you do when the pen drive is packed to capacity and you cant delete any thing as all info on it is vital? How will you copy a CD/ watch a movie/ listen to Audio CDs on your PCs without a working drive?
A DVD drive is now a neccesity
Old 12-11-2008, 02:35 PM   #22 (permalink)
If you have a pen drive you need not copy a CD. Nowdays all DVD players having USB port. So you can watch movies, listen songs through your USB device. I think the usefulness of CD Rom has reduced considerably. Do you agree?
Old 12-11-2008, 02:52 PM   #23 (permalink)
Fullbring
Zangetsu's Avatar
I agree..but not in case of DVD...if u need 2 archive then DVD is the best bet...
Zangetsu is offline
Old 12-11-2008, 02:57 PM   #24 (permalink)
AFK
the CD is now outdated tech....but the DVD is still useful...hence I suggest you go for a DVD writer.
Old 12-11-2008, 03:03 PM   #25 (permalink)
This thread is closed now.
Old 12-11-2008, 03:09 PM   #26 (permalink)
AFK
You cant decide whther the thread is to be closed...the moderator will .
Old 13-11-2008, 12:28 AM   #27 (permalink)
Archiving big files like movies is not economical on USB pen drives! A 4.7 GB DVD costs around Rs. 15 and a USB drive of about that capacity will cost about Rs. 450 - 500 (approx). Even if you factor in the cost of the burner, it is not at all economical.
Raccoon is offline
Old 13-11-2008, 09:55 AM   #28 (permalink)
Fullbring
Zangetsu's Avatar
Hey dude...Do u know the meaning of arhive...process .if not then google & then come back 2 ans our comments...
Zangetsu is offline
Old 13-11-2008, 03:45 PM   #29 (permalink)
^^^ Huh?!?!
Raccoon is offline
How to convert ordinary flash drive into U3 smart drive? thetopcyborg QnA (read only) 13 02-11-2008 11:59 PM
How to Use Pen Drive or Usb Flash Drive drive with NTFS topgear Tutorials 19 01-08-2008 07:40 PM
Why hard disk drive as removable drive? Sheik Rasheed K Hardware Q&A 6 25-03-2007 10:01 AM
Need some suggestions about buying Pen Drive(flash drive) ~It_is_Andrew~ Hardware Q&A 16 14-09-2006 10:23 PM
Hard Drive! Optical or Magnetic Based Drive Stitch QnA (read only) 1 30-05-2005 11:14 PM
