Old 05-11-2008, 07:02 PM   #1 (permalink)
Default 32bit applications on 64bit ?
I ordered for a Dell Studio laptop from USA. The laptop hasn't reached yet. Only yesterday did i notice that my Vista on the laptop was 64bit. As i've never used 64bit i have a doubt.
Can we run all 32bit applications on the 64bit Vista ?
snubbed is offline
Old 05-11-2008, 07:38 PM   #2 (permalink)
paroh's Avatar
Default Re: 32bit applications on 64bit ?
yes it will run ur 32bit application. but u need to install only 64 bit drivers of ur computer like graphic card etc etc
paroh is offline
Old 05-11-2008, 07:40 PM   #3 (permalink)
15.0 GHz
VarDOS's Avatar
yes all drivers should be x64...and x86 files can be easily run.
VarDOS is offline
Old 05-11-2008, 08:05 PM   #4 (permalink)
the drivers wouldn't be a problem as its a laptop, so all the drivers will be present in it.
snubbed is offline
Old 06-11-2008, 12:37 PM   #5 (permalink)
AFK
thewisecrab's Avatar
Dont worry.
With 64 bit, all 32 bit programs will work. Also, you will see increased performance with those programs that have 64 bit support as they will work faster
Follow me on http://twitter.com/thewisecrab
"This Jen, is the internet"
thewisecrab is offline
Confusion between 32bit & 64bit OS satyamy QnA (read only) 1 15-12-2006 11:07 PM
performance diff 64bit linux with 32bit ( L gurus help) hellomotto Open Source 13 28-05-2006 12:38 AM
Difference between 32bit & 64bit WinXP jack// ani Software Q&A 8 10-12-2005 08:02 PM
32bit or 64 bit godsownman QnA (read only) 16 09-06-2005 09:56 PM
Anthlon64 and the 32bit applications. Sathyan A. S. QnA (read only) 2 20-02-2005 10:23 AM
- by gforz
