My system was recently attacked by
TR/Delf.aam.35 Trojan. What it did was that it changed the attributes of the folders (that i double clicked to open) to hidden (system folder). and created an executable having the same name as the folder double clicking AVG 8.* (that was then installed) was not able to detect the virus. I switched to Avira Antivir Personal. It detected and removed the malicious software and other things but the folders that had been hidden by it could not be set visible again.
I went to
folder options >
view >
show hidden files. The files were not revealed. Then i tried the option of "show system files and folders", this revealed the folders. The problem now is that those folders (right click > properties - attributes) the hidden checkbox is checked and is disabled ( i.e its grey in colour and cannot be unchecked).
I tried the attrib -h in the command prompt which said cannot unhide system files.
Please tell me what to do. Mean while i am even trying to search for some remedy in the previous posts even.
Thankyou.
