26-10-2008, 11:17 PM
Level 96 Headbanger
How to forward a port for uTorrent using BSNL DataOne?
Guys, I have a BSNL DataOne Broadband connection. My problem is that I can't get uTorrent to download anything (Other clients don't help, either). I have followed the instructions as per the Port check function in uTorrent, but don't know how to configure my ADSL Modem using DataOne's control panel.
Please Help....
"Words meant to dwell in darkness shall never see the light of day.
Words can be broken, so can bones. Execute the mandate." :twisted:
Steam : DeathMetal
Garena : death_metal27
My Blog : The Pandemonium (Latest Post : Where does music come from?)
Guitar gear : GB&A (acoustic), ESP LTD-M50 ( New :twisted:), Roland MicroCube Amp.
27-10-2008, 02:11 AM
* Teh Flirt King *
Re: How to forward a port for uTorrent using BSNL DataOne?
You need to open ports in your BSNL Router (so called Modem  ).
The method is different in every router model so giving exact method is kinda tough!
BTW I suggest you try searching forum before asking for help.
Check this thread on how to forward ports:
Configuring BSNL Modems to Forward Ports.
27-10-2008, 06:45 AM
Hi friend,This software will solve your problem.
eDonkey 2000 v1.4
Automatically forward your ports with PFConfig. If you are trying to run an application that requires ports to be forwarded, you can skip the work and just use PFConfig. With PFConfig, you don't have to learn how to setup your router. It's so easy to use, you just pick the program from a list and say 'Update Router'.
please google search to find it otherwise PM me i will provide you.
ਨੋ ਗਰਲ ਫਰੈਂਡ ਨੋ ਟੈਂਨਸ਼ਨ,no girlfriend no tension,website: Punjabi.c-o.in,forum: punjabiteacher.co.cc
27-10-2008, 09:20 AM
Legen-wait for it-dary!
The link is here:
https://portforward.com/store/pfconfig.cgi
You can download a demo. Its a paid software, although you can find *cough* *cough* copies around...
I'm skeptical on how a software can set up a router's port forwarding, so if anyone tests this, please post what happens. Thanks.
27-10-2008, 11:52 AM
The Black Waltz
Try using a port number in this range
49152-65535
#krow @ irc.freenode.net
27-10-2008, 11:56 AM
AFK
31-10-2008, 06:40 PM
Level 96 Headbanger
I got PFConfig, but it does'nt show my routers manufacturer. I don't want to risk jeopardizing my connection by doing it manually. If you provide concise steps, maybe I can try it manually.
BTW, my modem is a UTStarcom's UT300R2U...
Steam : DeathMetal
Reason: Automerged Doublepost
01-11-2008, 05:49 AM
Obsessed with Technology
I have the same model. Please give the stpes to do port forwarding
AMD Athlon 64 X2 Dual Core Processor 4200+ 2.19 GHz, 2.5 GB Ram, 120 GB Hard Disk, XFX 8600GT
Visit my blog devrathnd.blogspot.com
01-11-2008, 10:06 PM
techtricks.co.in
portforwarding
xp-vista crossover connection
installing xp on vista notebooks
02-11-2008, 03:55 PM
The Researcher
I fyou have ut300ru, follow the below mentioned steps.
1. Go to local area connection properties and click on TCp/Ip properties. select use the following ip address and give 192.168.1.2 and subnet mask as 255.255.255.0 and default gateway as 192.168.1.1.
2 Now in IE type 192.168.1.1 and it will ask username and paswword Most of the time, it will be admin and admin. after putting in the username and password, it will take you router's settings page. click advanced setup and then WAN and under service something called pppoe_35_1 will be there. against that there will be an edit button. click the edit button.keep default values and press next and select bridging and click next and next and save. Now your router is port forwarded. download utorrent and install. There are numerous guides availabe for automating download during 2.00 am to 8.00 am.
02-11-2008, 08:15 PM
Can anyone help me portfowarding for MTNL(broadband)-UT Starcom??
02-11-2008, 08:20 PM
Answers everything
Solution for ur problem goes here:
http://www.portforward.com/english/r...outerindex.htm
Simple!!!!
The ultimate solution for all your pc problems: My answer
02-11-2008, 08:34 PM
Originally Posted by mmharshaa
actually the firmware in mtnl utstarcom modems is different,
@rhasta
open 192.168.1.1/main.html
then goto nat and add all required ports there
03-11-2008, 11:57 PM
Level 96 Headbanger
@Ramkrishnan,
I tried your steps and nuked my router. It was not able to detect any server....with great difficulty I have got it to work again to post this message. I followed the steps exactly as you have told. Now what???
Steam : DeathMetal
04-11-2008, 12:28 PM
The Researcher
I am sorry to see that you got into trouble after following my guide. But the same steps were followed by me and I didn't encounter any difficulty. Mine also BSNL Home 500. I am using Home 500 for the last 10 months and downloading torrents. what is your modem model? Is it ut300ru?
04-11-2008, 03:27 PM
Level 96 Headbanger
yup!
BTW, my plan is Home250
Steam : DeathMetal
13-12-2008, 04:04 PM
how to forward port in adsl2 router in bsnl dataone
13-05-2009, 01:45 PM
Level 96 Headbanger
Here's my problem with PF Config:
My Model is UT300R2U, but PF Config shows:
Any Help??
Steam : DeathMetal
13-05-2009, 03:06 PM
#19 (permalink)
silentFOX
@DeSmOnD dAvId
Man, a simple google search could have solved it a long go. Here this is all you need.
http://techtricks.co.in/portforwarding-bsnl-dataone-ut300r2u-modem/
Ter's a little edit in those steps, here
13-05-2009, 03:20 PM
#20 (permalink)
Level 96 Headbanger
My firmware is different:
Steam : DeathMetal
13-05-2009, 03:43 PM
#21 (permalink)
silentFOX
oh, my apologizes.
here, try this
1) In the left side menu click Advanced setup
2) Click on NAT next and DMZ Host thereafter
3) Enter DMZ host ip address as
i) 192.168.1.2 if you are connected through ethernet
ii) 192.168.1.1 if you are connected through USB
4) Click on save/apply
5) Click on Management in the left side menu
6) Select Save/Reboot from that and leave your browser like that until it displays the summary page (this takes about 2-3mins)
Remember, this open all ports (like in Bridged Mode) so use a good firewall.
15-05-2009, 11:43 AM
#22 (permalink)
Level 96 Headbanger
Solved! Thanks mittyr!!
Steam : DeathMetal
15-05-2009, 11:44 AM
#23 (permalink)
Level 96 Headbanger
Thanks!
Steam : DeathMetal
21-05-2009, 12:07 PM
#24 (permalink)
what modem do you use????
