Old 25-10-2008, 11:34 PM   #1 (permalink)
Default Connecting mp3 player to speakers
Hello.I would like to know how to connect an mp3 player to a 4.1 speaker system.I own a Creative Zen and would like to connect it Creative Inspire 4.1.Is it possible?Also tell me if I'd require an amp or something.
Thanks in advance.
Visit my blog for updates on..umm practically everything!
www.maverickshaunt.blogspot.com
bloggerbloggerplasma is offline
Old 26-10-2008, 01:03 AM   #2 (permalink)
IronMan; Ready to Roll...
IronManForever's Avatar
Default Re: Connecting mp3 player to speakers
why? Most systems have a way of connecting stereo inputs as well. If not, then I have seen converters retailing for 100 rs.
Aluminum MacBook 2.0GHz Collector's Edition
Windows Box: 2.26G P4, 1GiB RAM, 320GB SATA + 80GB PATA HDD, Nvidia FX5200
AOC Fovi F22
iPod Touch 16GiB, HTC Gene, Moto W230, Sansa Express
IronManForever is offline
Old 26-10-2008, 01:18 AM   #3 (permalink)
Democracy is a myth
rhitwick's Avatar
Smile Re: Connecting mp3 player to speakers
U could do it, once I connected my W810i with my Logitech X540 which is a 5.1.
Just look out if the woofer jack is supported by the MP3 player, if not u may need to search for a converter.
But connection ur MP3 palyer with a 4.1 is not good idea, it drasins out the battery very much.
u must have seen iPods do that, but they have speakers dedicatedly made for iPod.
Best of Luck
"My opinions may have changed, but not the fact that I am right."
"I'm never wrong. Once I thought I was wrong, but I was wrong"
rhitwick is online now
Old 26-10-2008, 01:19 AM   #4 (permalink)
Wire muncher!
infra_red_dude's Avatar
Thanks in advance.
Technically its not possible to connect a device with stereo o/p with a 4.1 set. What you can do is get a splitter that looks like this:
http://fixtheipod.com/images/72208361_o.jpg
or like this: http://www.tomtop.com/syssite/home/s...mg/big/964.jpg
This will work provided the speakers are analog and not digital (I guess the speaker set you mentioned don't haf optical connectors). This way the front channel will be mirrored to the rear and sound output will be obtained from all the speakers. This setup is called pseudo-surround where the front and rear o/p are mirrored.
The Zen is powerful enuf to drive these active speakers. You don't require an amp.
infra_red_dude is offline
Old 26-10-2008, 10:26 PM   #5 (permalink)
Thanks for all the advice,I really appreciate it !
DVD player speakers NucleusKore Software Q&A 2 26-06-2007 07:28 AM
Connecting PC speakers to CD/DVD player. guhanath Audio 4 16-05-2007 10:11 AM
DVD Player and 5.1 Speakers ha_shock Audio 4 29-11-2006 02:03 AM
speakers for cd player gramesh Software Q&A 1 23-11-2006 08:46 AM
connecting completely diff speakers to computer sagargv Audio 20 13-02-2006 07:10 AM
- by gforz
