Old 25-10-2008, 01:27 PM   #1 (permalink)
Indidiot
Plasma_Snake's Avatar
Default XP 64-bit help
Just installed 64-bit XP. Now few questions.
  1. Normal XP's brico packs etc don't work with 64-bit one so will the normal themes of 32-bit XP work on 64-bit one?
  2. In this XP, under "Arrange Icons By" there's no option to "Show desktop Icons". I mean I want to hide my desktop icons.
  3. Where can I get good themes for my XP?
Plasma_Snake is offline
Old 25-10-2008, 06:40 PM   #2 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
Default Re: XP 64-bit help
1. No idea, sorry.
2. Its there in all versions, I'm sure. Someone might post a solution.
3. First 10 links:
http://www.google.com/search?client=...utf-8&oe=utf-8
You should also try WindowBlinds, which works on xp, vista, x86 and x64. Its better than using themes.
dheeraj_kumar is offline
Old 25-10-2008, 07:16 PM   #3 (permalink)
The Black Waltz
1. Most of them will work.
3. From the search results mentioned by Dheeraj, beware: some themes from CrystalXP are malware. themexp.org is a safe place.
#krow @ irc.freenode.net
Cool Joe is offline
Old 25-10-2008, 08:28 PM   #4 (permalink)
Indidiot
Thanx homies, I knew u peeps got my back covered!
- by gforz
