Old 21-10-2008, 05:24 PM   #1 (permalink)
avtarkaint's Avatar
Question please solve my problem of usb
i m always getting this error in my pc all my internal usb drives is dead(not working- not dectecting anything) so i usec external usb 4 port drive, from 5 month now i m getting this sturboen message every time please sort it out my frnds.
& some time my pc hang always & dont start & shut down also i m using latest bit defender antivirus 2009.
system:
microsoft windows XP proffesional version 2002
service pack 2, intel(r) pentium(r) 4 cpu 2.66GHz
248 MB of RAM
using- AVAST antivirus professional updated regurarly
avtarkaint is offline
Old 21-10-2008, 06:46 PM   #2 (permalink)
Default Re: please solve my problem of usb
I think that it can be problem with your USB port. Please recheck that and make sure that everything ok with port.
flameup is offline
Old 21-10-2008, 08:40 PM   #3 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
Two problems - one has solution, other doesnt.
1. For your internal USB thing, check if its connected properly on your motherboard. Thats usually the problem. You might want to reinstall your motherboard drivers, too.
2. As for your external, some devices do not get the required power when connected via external, or cannot communicate properly to the computer, its either of the two. So, you'll have to connect the device to your internal USB only, and it will work there. And note: external also includes the front usb slots of cabinets.
Take my bluetooth module for example, it can work on both internal and external, but my gamepad can work only on internal.
dheeraj_kumar is offline
Pls..Solve my problem!!! Zangetsu Hardware Q&A 17 07-07-2008 03:21 PM
Solve this PHP problem JhonCena QnA (read only) 8 05-01-2007 09:13 AM
IE 7 PROBLEM.!!! Plz solve this sunveer Software Q&A 2 23-12-2006 01:11 PM
Anyone can solve this problem???? CHETANBHALLA QnA (read only) 7 07-05-2005 11:49 PM
How to solve this IRC problem? GameAddict QnA (read only) 12 06-11-2004 06:06 PM
- by gforz
