Old 19-10-2008, 06:11 PM   #1 (permalink)
Default Slow broadband speed..due to Firewall??
I have youtele broadband and off lately I notice that when I use IE the browsing sped is very poor or sometimes the sites simply do not load. Sometimes it’s relatively OK with other browsers like Opera.
Interestingly if I shut down the Trend micro internet security, IE browsing fairly comes to a speed comparable to broadband. As such I have not changed any settings in Trend mirco. This issue has started since last 2 - 3 weeks!
Any comments or thoughts would be great. Thx
patkim is offline
Old 19-10-2008, 07:06 PM   #2 (permalink)
The Black Waltz
Default Re: Slow broadband speed..due to Firewall??
It seems Trend Micro is blocking traffic. In the firewall options, add IE (or any other browser) to the exceptions list. If you've already done it, disable the firewall when you browse.
#krow @ irc.freenode.net
Cool Joe is offline
Old 19-10-2008, 07:29 PM   #3 (permalink)
rosemolr's Avatar
yeah..firewall could slow your internet browsing speed..This is because of packet filtering and all..disable firewall
Extreme Mobile Professional..Ask anything about it..
Provide you all applications in symbian java uiq platforms
**THERE IS NO SPOON***
rosemolr is offline
Old 19-10-2008, 09:08 PM   #4 (permalink)
firewall is for use to safeguard you from certain threats online so turning it off is not really that advisible...
ditch trend micro and get another firewall..oops u use a security suite..so it came along with it..install another antivirus and then another firewall..
or disable the trend micro firewall feature/function and install zonealarm free
realdan is offline
Old 19-10-2008, 09:53 PM   #5 (permalink)
TheSaint
NucleusKore's Avatar
Which processor are you using? How much RAM do you have?
http://www.neville.in
http://www.linuxrocks.in
"The Future Is Open"
NucleusKore is offline
Old 19-10-2008, 10:13 PM   #6 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
No, firewall is processing ur data, change security settings to low.
About me:
http://about.me/preetam_nath
comp@ddict is offline
Slow download speed between 2 to 8 A.M.(BSNL Broadband) cage3d Broadband and DTH 8 14-04-2009 04:57 PM
very slow speed of net rohitshubham Software Q&A 6 17-08-2008 01:01 PM
Getting very very..... slow speed with sify broadband bravo007 Broadband and DTH 6 21-06-2008 11:54 AM
Very Slow Speed of Broadband... Manshahia Broadband and DTH 9 07-06-2007 01:52 PM
Slow Broadband Speed n2casey Broadband and DTH 19 16-12-2006 09:49 AM
- by gforz
