Re: pc problem.........
You can remove items in Start Menu, by deleting the folders/files present inside the below mentioned folders:
C:\Documents and Settings\YourUserName\Start Menu\Programs\
C:\Documents and Settings\All Users\Start Menu\Programs\
Replace C:\ with suitable drive letter if you have installed Windows in a different partition.
http://swatrant.blogspot.com/
