Old 18-10-2008, 03:44 PM   #1 (permalink)
gkbhat.blogspot.com
Default Problem with lan
I have 7 computers all have win xp are connected to a hub and all of them are connected to the internet through this hub. We use this connection as a lan.6 computers are able to view each other but one comp is not able to connect to the lan though it is able to connect to the internet.
I tried changing the work group i.e same workgroup but of no use.
We have static ip addresses.
View workgroup computer shows only one computer i.e. itself.
blogging at http://gkbhat.blogspot.com
gk2k is offline
Old 18-10-2008, 03:53 PM   #2 (permalink)
Default Re: Problem with lan
Are none of the other 6 computers able to access the 7th computer? If so, it is possible that there is some configuration issues... Also, check if you have given common IP address with another computer... And check your firewall settings...
Arun
sakumar79 is offline
Old 18-10-2008, 04:09 PM   #3 (permalink)
TechTin.com
ravi_9793's Avatar
Run setup wizard again on 7th system..and temporarly disable firewall.
ravi_9793 is offline
Old 18-10-2008, 05:35 PM   #4 (permalink)
gkbhat.blogspot.com
@sakumar79
None are able to access 7 th one and the ip addresses given are unique.
@ravi9793
I use kis 2009 and I disabled both the kis firewall and windows firewall and ran the setup wizard but no use
gk2k is offline
Old 18-10-2008, 06:37 PM   #5 (permalink)
TechTin.com
ravi_9793's Avatar
From a working system, ping the IP of non working PC.
start -->> run -->> type cmd -->> ok
ping 192.168.1.xx
Also do this:
In non-working PC
Right click on any folder -->> Sharing and Security -
Do you get option of "Share this folder on the network" ??
or do you get warning message "If you understand the risk but still want to share the root of the drive, click here ".
if see any such warning, just enable sharing.
Old 19-10-2008, 09:12 PM   #6 (permalink)
try creating another admin account..and then logged in using that account and see if you can access after configuring as you did with the other computers
realdan is offline
Problem With Data Recovary Software Problem Stellar Phoenix njm Software Q&A 1 08-05-2007 12:31 PM
Problem Related To Dvd and Iso Buring , any genius here who can resolve this problem vijayendra QnA (read only) 2 14-01-2007 09:38 AM
Problem!Problem!Problem Help Me November Cd And December dvd Doesnt Work yyy??? sourav_digit QnA (read only) 3 27-12-2006 02:33 PM
Serius problem with my screen. Can u tell it s/w or hard ware problem . tusarks Hardware Q&A 7 12-06-2006 01:58 PM
fedora cd iso problem(installation from hard drive problem) harmax Open Source 3 01-07-2005 11:34 AM
- by gforz
