Old 17-10-2008, 11:12 PM   #1 (permalink)
MasterMind
killerz's Avatar
Default Cannot Monitor Temperature of HardDisk.
Hii..
I want to monitor the temperature of my HardDrives but i am unable to do so.
I have tried using HddTemp (http://www.hddtemp.com)
It says "We cant find in your system any hard drives supports temperature"
other softwares are also unable to monitor.
I am using Vista.
HDD Models are ST3160827AS and ST3250824AS
My Bios shows that my HDDs supports SMART mode.
Earlier when i was using XP it used to show the temperature.
Whats the Problem..pls Help.
killerz is offline
Old 18-10-2008, 12:09 AM   #2 (permalink)
swatkat's Avatar
Default Re: HDD Temperature Monitor.
Try HDTune or SpeedFan.
http://www.hdtune.com/
http://www.almico.com/speedfan.php
http://swatrant.blogspot.com/
swatkat is offline
Old 18-10-2008, 08:12 AM   #3 (permalink)
MasterMind
killerz's Avatar
Unhappy Re: HDD Temperature Monitor.
I tried HDTune and SpeedFan but still no luck.
and in Device Manager it shows SCSI , but i have SATA HDDs.
killerz is offline
Old 18-10-2008, 12:13 PM   #4 (permalink)
aka. ViKiD? <^_^>
Ambar's Avatar
dood try everest ultimate ed ... it ma y help
Wadadadada!! ??
Ambar is offline
Old 18-10-2008, 02:21 PM   #5 (permalink)
MasterMind
killerz's Avatar
no Everest ultimate is not working too...pls help anybody.! is there no solution ?
killerz is offline
Old 18-10-2008, 06:27 PM   #6 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
ActiveSMART
http://www.ariolic.com/activesmart/
dheeraj_kumar is offline
Old 18-10-2008, 08:09 PM   #7 (permalink)
MasterMind
killerz's Avatar
Nope this doesnt work too......any professional guys here..pls help
trying new software doesnt solve the problem.
killerz is offline
Old 18-10-2008, 09:00 PM   #8 (permalink)
swatkat's Avatar
Is S.M.A.R.T for hard disks is enabled in BIOS?
swatkat is offline
Old 18-10-2008, 09:33 PM   #9 (permalink)
MasterMind
killerz's Avatar
Yes its enabled.
killerz is offline
Old 21-10-2008, 09:03 AM   #10 (permalink)
MasterMind
killerz's Avatar
Is there no one with the Solution??
killerz is offline
Old 21-10-2008, 07:56 PM   #11 (permalink)
swatkat's Avatar
Hmmm.... Does your PC motherboard has nVidia chipset? It seems that nVidia chipset PCs running Vista have some issues regarding S.M.A.R.T. You may want to check these threads:
http://www.lavalys.com/forum/index.php?showtopic=2177
http://forums.techarena.in/vista-help/880621.htm
http://www.vistax64.com/vista-hardwa...ork-vista.html
http://www.overclock.net/hard-drives...ted-vista.html
http://www.driverheaven.net/hardware...g-s-m-r-t.html
Okay, try this software:
http://crystalmark.info/software/Cry...o/index-e.html
swatkat is offline
Old 24-10-2008, 07:43 AM   #12 (permalink)
MasterMind
killerz's Avatar
Lightbulb Re: HDD Temperature Monitor.
nopes its not working swatkat..anyways thanks for your help.
thanks everyone for your help.... its much time now i have been googling for the solution....after which i have come to the conclusion thats its the problem with VISTA only..may be a chipset diver or any other i dont know.
i installed XP it works, i used ACtive smart cheker tool using bootable Hirens Boot CD it shows S.M.A.R.T info there tooo.
Just Accept it Vista SUCKs!
killerz is offline
Old 24-10-2008, 08:07 AM   #13 (permalink)
aka. ViKiD? <^_^>
Ambar's Avatar
well i never faced ne probs like this with vista... i use Genuine Ultimate Edition with SP1
and have 4 HDD's:
WD6400AAKS
WD6400AACS
one seagate 120 gb
one samsung 80GB
no probs at all
Wadadadada!! ??
Ambar is offline
how to monitor system temperature, fans speed?? ramsingh QnA (read only) 5 05-04-2008 10:32 PM
suggest a temperature monitor? talkingcomet QnA (read only) 1 22-01-2008 12:32 PM
GFX Temperature Monitor Charan Graphic cards 4 20-06-2007 01:52 AM
Temperature Monitor Osh Hardware Q&A 4 07-11-2006 01:53 PM
no hardware sensor to monitor temperature on my motherboard casual_gamer CPU / Motherboards 13 08-08-2005 12:35 AM
- by gforz
