Go Back   Digit's Technology Discussion Forum > Community > Tutorials
Tutorials This section offers tutorials and How to's on just about anything related to computers and IT. Note: All tutorials are courtesy the posters and not verified by Digit
Thread Tools Search this Thread Display Modes
  #1
Old 21-08-2008, 08:27 PM
NucleusKore's Avatar
NucleusKore NucleusKore is offline
TheSaint
Default Installing Linux, a dual boot system with Windows and Linux
PDF version of this guide - http://www.mediafire.com/?b1zushbgmeo
Dual Boot with Ubuntu 8.10 - Click Here
Installing linux alongside windows can be quite daunting for new users. The fear of losing data is always there, besides other problems like corrupting your boot record, getting a completely unusable system at the end, etc.
The purpose of this tutorial is to simplify the process by the use of screenshots of an actual installation (a picture is equal to a thousand words someone said).
I have covered two flavours of linux, Ubuntu and OpenSUSE. The process is very similar in other
flavours.
Assesing your hard disk, partitions
To install linux on your PC you should first make some free space available on your hard disk for the install. Click
on Start->Control Panel->Performance and Maintainance->Administrative Tools->Computer Management
Click on Disk Management System
I have covered a few possible scenarios you might face.
  • You have a 40 GB hard disk made into four more or less equal partitions. You can see your partitions and their corresponding drive letters (C,D,etc.) in the figure below.
    The idea is to free at least 20 GB for our linux install. This might seem like a lot and other's might disagree, but if you are looking for a full experience I'd recommend it. We will need this space later to make three partitons
    Swap - Space=1.5 to 2 times your RAM
    Root (designated as /) - stores your OS and system files, programs, etc. - Space approx 8GB
    Home (designated as /home) - like the Documents and Settings folder of Windows XP. Stores your preferences, bookmarks, wallpaper, My Documents and Desktop. - Space - remaining space
    The / is like the base directory in linux, into which all other directories (folders) are incorporated or "mounted". I took a very long time to understand the concept of "mounting". Don't worry about it for now, you will understand when the time is right.
    So here you will have to backup the data in the last two partitions by writing it to a CD or DVD or copying to another hard disk, and delete them as shown below
  • You have a 40 GB hard disk with only one partition "C". This is the scenario in many laptops. The other partition may be a back up or EISA partition. Now you're in for a rough ride. If you have made the back up CDs and DVDs from the EISA partition using the tool the vendor has provided you, you can delete the EISA partiton but you will have to first backup your data, delete all partition using a partition manager like GParted, make a small C partiton, say 20 GB, with the ntfs filesystem using GParted, and then boot from your recovery cd/dvd and restore the system.
Resizing Partitions is something I do not recommend with any tool unless you have uninterrupted power supply in your part of the country/world or a power back up solution that lasts for a few hours.
Hardware check
With the advances in Linux and the new kernels this step may not be necessary, but will help you in troubleshooting later if required.
Click on Start->Control Panel->Performance and Maintainance->System
Click on the Hardware tab->Device Manager button
Make a note of the model numbers of your monitor, graphics card (display adapter), and any other devices.
Installing Linux
You are now going to install linux to the empty space on your hard disk that you prepared in the earlier step. Linux by itself is not a single monolithic entity unlike some popular operating systems. It is very much a collaborative effort. It consists of a core (also called a kernel) on which the entire system is built on an runs. Linux is modular. As you become more experienced, you will realise that you can add and remove modules depending on your requirement and create a highly customised system, to make a long story short - NO **** is forced down your throat. No hidden agandas, no long cryptic EULAs (the thingy which you blindly scroll down and click "I agree" without batting an eyelid), and no leash up your arse (pardon the bad language but that's exactly how I feel).
So let's get started !!
I shall first describe the installation with Ubuntu 8.04, followed by OpenSUSE 11.0
The first step in installing any linux distro involves booting from a live media, usually a CD or DVD.
Ubuntu CDs are available for free from SHIPIT
You can also download it from Ubuntu website or ask a LUG (Linux User Group) near you. SUSE CDs and DVDs can be downloaded from http://www.opensuse.org
To boot from the cd or dvd your bios should have it as the first boot device. Alternatively some bios allow you to select the boot device. The key used for this varies with different manufacturers. To see if your bios has a boot device select menu please refer the manual of your motherboard or take help from a more experienced friend.
I suggest you try the following - insert the cd or dvd and start your pc. If your pc boots too fast simply restart windows with the cd or dvd in the drive and see what happens. Very often the optical drive would have been set as the first boot device and the system boots from the cd automatically. If it still goes to windows and refuses to boot from your cd or dvd then you will have to adjust your bios settings or search for a boot menu as I described earlier.
Go to post number 19 of this thread for OpenSUSE installation or click here
Ubuntu Installation
If your pc boot successfully from your ubuntu cd you will see this screen
It is asking you to select the language. Use your arrow keys to select the system language and press ENTER. You will then get this screen
http://www.neville.in
http://www.linuxrocks.in
"The Future Is Open"
  #2
Old 21-08-2008, 08:28 PM
TheSaint
Default Re: Installing Linux, a dual boot system with Windows and Linux
Use the Up and Down arrow keys on your keyboard to select the option Install Ubuntu and press ENTER. The system will start booting.
You will see the Welcome screen in your language. Make sure your language selection is right and click forward
Select your timezone from the list, it is arranged by continent, and click forward
Select your keyboard type, most common is US International (see picture below), but make sure and use the test box made available to you to check your selection. Check not only for alphabets, capital and small, but also for special characters like ' " ? / + ; If all these are correct then your choice of keybord layout is fine, click forward
You will now be presented with the partitioning options. Ubuntu "intelligently" offers to resize your windows partition and do everything automatically. I advise AGAINST using this option, and instead select the manual option and click forward
You will now come to a screen which shows you the layout of partiitons on your hard disk. Note the nomenclature used in linux. The first hard disk is labelled as /dev/sda Partitions withing this are labelled as /dev/sda1 /dev/sda2 so on and so forth. Now in this example, there are some numbers missing inbetween as you can see. These have gone for the extended partition. /dev/sda5 is actually my D drive, but as it is not formatted it shows up as an unknown partition. /dev/sda1 is the C drive and has an ntfs filesystem.
Select free space and click on the "New Partition" button as shown below
Select type of partition logical, size 1.5 times your RAM (512 in this example), location for new partition Begining, Use as: swap area, and click OK
The proposed partition table layout will get updated as shown
and you will get this
Again select free space and click New Partition. Select type of partition logical, size 8000 MB or more, location for new partition Begining, Use as: Ext 3 journaling file system, mount point: / and click OK
The proposed partition table layout will get updated. Again select free space and click New Partition. Select type of partition logical, size: don't touch anything, let it be as it is, location for new partition Begining, Use as: Ext 3 journaling file system, mount point: /home and click OK. Note that you will manually have to type in the mount point in the box provided as /home
  #3
Old 21-08-2008, 08:29 PM
TheSaint
This is how your proposed partition table layout finally looks like.
Remember, nothing has actually happened to your partitions as yet, this is just a proposed layout, so if you make a mistake in your newly created linux partitions you can simply go back and redo the partitioning. CLick Forward.
You will now be asked some details about yourself. You will have to give a password. Make sure you don't forget it. Click Forward
Import your windows settings. This is optional you can leave it unchecked as shown in the second figure and click forward.
Click Install, the installation will begin with the formatting and copying of files to your hard disk.
At the end of installation click on the Restart Now button
As the system shuts down, you will get a message telling you to remove the cd from the drive and press ENTER to reboot the system which you must do.
As the system boots for the first time after your installation, you will see this screen. This is the GRUB boot loader from where you can choose between Ubuntu Linux (first entry) and Windows (last entry), using the up and down arrow keys on your keyboard and press ENTER. If you do not respond in 10 seconds it will boot to Ubuntu automatically.
Enjoy your Ubuntu !!!
Optional: Installing the GAG Bootloader
Go to post number 23 of this thread or click here
  #4
Old 21-08-2008, 08:56 PM
thewisecrab's Avatar
thewisecrab thewisecrab is offline
AFK
Thank You Thank You Thank You Thank You
This is EXACTLY what i needed
Thanks a million
NOTICE: I'll be off the forum and IRC for sometime now. Atleast not as regular as I am now.
Otherwise, follow me on http://twitter.com/thewisecrab
  #5
Old 21-08-2008, 09:05 PM
Cool G5's Avatar
Cool G5 Cool G5 is offline
Awesome post Nucleuskore. You have written in a very simple language & that's what I liked the most. The newbie's will find it easier to follow.
Reps for you.
This should be made sticky.
Gaurav Live : http://www.gauravlive.com
Layman Linux : http://linux.gauravlive.com
Photo Portfolio : http://gauravlive.com/photo-portfolio/
  #6
Old 21-08-2008, 09:06 PM
AFK
But wait
I've got a prob...
I've got 4 partitions, roughly 50GB each
one partition is relatively empty
I want to give 10gb to ubuntu
so once i delete that partition,
how do i create a 40GB partition from the partition I deleted?
Also, what option do i select in the "partioning" part of ubuntu installation so that it installs by creating partition of the remaining space?
And how do I make Windows as first entry in GRUB?
Please reply
  #7
Old 21-08-2008, 09:14 PM
ichi's Avatar
ichi ichi is offline
Unban praka123
Originally Posted by thewisecrab View Post
1.how do i create a 40GB partition from the partition I deleted?
2.Also, what option do i select in the "partioning" part of ubuntu installation so that it installs by creating partition of the remaining space?
3.And how do I make Windows as first entry in GRUB?
Please reply
1. Its as simple as create and then specifying size of 40GB
2. Once you have created a partition, its easy to go for custom partition.
3. First install linux, then its just a matter of changing a number in GRUB menu.lst file.
@Nukleuskore
Images speak for itself
  #8
Old 21-08-2008, 09:20 PM
AFK
Plz forgive me for being a n00b...
  #9
Old 21-08-2008, 09:26 PM
ichi's Avatar
Unban praka123
^^I meant Manual Option (its like doing it yourself)
http://img230.imageshack.us/my.php?image=xp20lu4.png
See the mouse pointer. And read what Nucleuskore has written.
  #10
Old 21-08-2008, 09:30 PM
Garbage's Avatar
Garbage Garbage is offline
God of Mistakes...
Send a message via MSN to Garbage Send a message via Yahoo to Garbage
Very nice tut Nucleuscore..
BTW, /me is asking admins to increase post character limits for NucleusCore..
DEFINITION:
Computer - A device designed to speed and automate errors.
Unban Praka123 !!!
Registered Linux User #468778
  #11
Old 21-08-2008, 09:41 PM
The Conqueror's Avatar
The Conqueror The Conqueror is offline
I Will Conquer Everything
Send a message via Yahoo to The Conqueror
^Also the Image Limits
And What an amazing tutorial you have made!
Very Very Useful for those who are new to linux world.
Regards,
The Conqueror
  #12
Old 21-08-2008, 09:44 PM
Garbage's Avatar
God of Mistakes...
yeh.. He is coming with great HELP now a days...
@ NucleusCore bhai... kya khhate ho aaj kal ??
Same for AptOnCD and OpenSuSE updates thread...
Keep it up...
DEFINITION:
Unban Praka123 !!!
  #13
Old 21-08-2008, 10:00 PM
Krazy Bluez's Avatar
Krazy Bluez Krazy Bluez is offline
Banned to Spam
Location: Look below...not under pants dumbo...use a GPS
Send a message via MSN to Krazy Bluez Send a message via Yahoo to Krazy Bluez
Best post on Linux installation, thanks, Now i am saving it for future use !
My DeviantART page now exists !!!
Krazy-Bluez.deviantart.com
Twitter: http://twitter.com/KrazyBluez
  #14
Old 21-08-2008, 11:00 PM
TheSaint
This tutorial is far from over, still have to write about OpenSUSE. Hope to finish in a week. My parents and brothers are down on holiday, so everyone wants the PC. Will have it all to myself after the 27th.
  #15
Old 21-08-2008, 11:03 PM
mediator's Avatar
mediator mediator is offline
String Phreak
All hail @nucleuskore. U shud contact Digit & offer to write the next magazine covering the same subject & ofcors for a moderate fee with which u may give a moderate party! Your efforts r admirable. Amazing tute man and so is ur site! Neat...................
Hope to see some 'M.D' stuff on ur site tooo.
  #16
Old 22-08-2008, 12:23 AM
Ecko's Avatar
Ecko Ecko is offline
Wandering In Tecno Land
Send a message via Yahoo to Ecko
Shocked to see you were using windows for initial partitioning (rather formatting)
Ubuntu has got the best 1 ever I've seen & even i use live CD just for it
BTW excellent tut thumbs up
Born in Windows Die In Linux © 2009-10 All Rights Reserved.
Learn Linux : www.linoob.com (Official WebSite)
  #17
Old 22-08-2008, 02:25 AM
IronManForever's Avatar
IronManForever IronManForever is offline
IronMan; Ready to Roll...
One Word; Mind-Blowing!
Aluminum MacBook 2.0GHz Collector's Edition
Windows Box: 2.26G P4, 1GiB RAM, 80GB HDD, Nvidia FX5200
22" AOC Full HD
iPod Touch 16GiB, HTC Gene, Moto W230, Sansa Express
  #18
Old 22-08-2008, 07:31 AM
TheSaint
This IS for windows users. Traditional Windows home users may find even the disk management system confusing if they see it for the first time.
  #19
Old 24-08-2008, 12:23 PM
TheSaint
OpenSUSE Installation
If your pc boots successfully from your OpenSUSE DVD you will see this screen
Use the Up and Down arrow keys on your keyboard to select the option Installation and press ENTER. The system will start booting.
You will see the Welcome screen in your language. Make sure your language selection is right, tick I Agree and click next
Your system will be probed
Select New Installation, and uncheck Use Automatic Configuration
Select your timezone from the list, and click forward
Choose your desktop. I'd recommend GNOME desktop if you have <b>less than</b> 512 MB RAM, and KDE 3.5 if you have more than that.
You will now be presented with the partitioning options. OpenSUSE "intelligently" offers to resize your windows partition and do everything automatically. I advise AGAINST using this option, and instead click Create Partition Setup
Select Custom Partitioning (for experts)
  #20
Old 24-08-2008, 12:24 PM
TheSaint
Select /dev/sda and click on the the Create button, you will get a dialog box as shown below
Click the dropdown list against filesystem and select swap
You now have to enter the size of the swap partition. For example, if you want a partition of 512 MB size, in the End box type +512M as shown below. If you want 1 GB then you have to type +1GB. Swap partition size is typically 1.5 to 2 times the amount of RAM you have.
Click OK. Now again select /dev/sda and click on the the Create button, you will get a dialog box as shown below. Select the filesystem as ext3, End as +8GB, mount point as /
Click OK. Now again select /dev/sda and click on the the Create button, you will get a dialog box as shown below. Select the filesystem as ext3, mount point as /home
Leave the End value as it is
You now have to mount your Windows partitions. This will enable you to read and write to your windows partitions from linux. Windows partitions are marked as ntfs, fat16 or fat32 in the partitoner. Usually, as is also the case in this example, the C drive corresponds to the first partition on the hard disk, so it is /dev/sda1
You can also confirm this by seeing the size of the partiton in the partitioner (I am assuming that you know the size of your windows drives/partitions). So select /dev/sda1 and click Edit. You will get this dialog box
Now type /windows/c as shown in the mount point box. Click on Fstab options
In this tick mountable by user, and in the Arbitrary option value box add the entry
umask=0002
inbetween users, and fmask=133
so it should read
....users,umask=0002,fmask=133....
Please note it is umask and not unmask Click OK
Do the same for other windows partitions, the only difference being the difference in mount point. D will become /windows/d E will become /windows/E so on and so forth. There is no need to mount the partition marked as extended partition.
Remember, nothing has actually happened to your partitions as yet, this is just a proposed layout, so if you make a mistake in your newly created linux partitions you can simply go back and redo the partitioning. Note the partition table down in a book and keep it safely. You will require it to rescue your system if need be, and to install the GAG boot loader later (optional but desirable). Click Next.
You will be shown, one last time the partitioning tasks that the installer is going to perform. Click Next
You will now be asked some details about yourself. You will have to give a password. Make sure you don't forget it. I have unchecked Automatic login and Use this password for system administrator. This need not be done if you wish so. I am kind of fixated with the traditional OpenSUSE install. Fill in the details and click next.
If your password is weak you will get these prompts. I usually give yes to override them, this is optional, you may take them seriously and give a strong password if you are in a multiuser environment.
  #21
Old 24-08-2008, 12:25 PM
TheSaint
Key in your root password (also called administrator password) and click next
You will now be shown an overview of system wide changes that are going to be made and what is going to be installed.
Click on Booting. As you can see there is a tick mark against OpenSUSE indicating that it will boot automatically in case you do not make an OS selection in 10 seconds at the time of booting. In case you want to make Windows the default select windows and click Set as Default, and click OK. Else leave it as it is.
You will be shown an updated overview of system wide changes that are going to be made and what is going to be installed.
Click Install, and in the popup dialog box, Install.
You will be shown your host name and domain name. Leave everything as it is unless you know what you're doing. Click Next
The Network Configuration will come up.
Click Disable IPv6. You'll get this warning. Click OK and click next.
  #22
TheSaint
Click Next till you get the hardware configuration window.
OpenSUSE will automatically probe your system and configure your hardware. Your screen may blank momentarily to configure your display, don't panic ! Just wait patiently. You can configure your printer from here.
Click Next, and then Finish.
Enjoy your OpenSUSE Linux!!!
  #23
Old 24-08-2008, 03:00 PM
TheSaint
Default Installing the GAG Bootloader
This may be difficult for first time users who have no idea on command line usage in dos or windows. If you are familiar with the cd command to browse directories then you may proceed with Method 1, else use Method 2.
Ubuntu and OpenSUSE by default use the GRUB bootloader which is again, by default, written to the first sector of your hard disk, a location for the Master Boot Record (MBR). If anything happens to this boot record because of a virus attack or a system bug your system simply won't boot. Updating Ubuntu or OpenSUSE over the internet, updates (especially kernel updates) sometimes mess up the boot loader because of wrong entries or pointing. You'll find enough of these instances in the official forums. This can be avoided if you put your GRUB bootloader in your / partition instead of your MBR. In your MBR you can install any third party bootloader like GAG as I have described below. This is optional and if you are happy with GRUB you need not install GAG. If you want to learn more about GRUB go through this wonderful article.
Install GRUB to your root partition. In a terminal type
grub-install /dev/root_partition
where root_partition is your root partition, and press ENTER. An example: if /dev/sda7 is your root partition, just type:
grub-install /dev/sda7
Close terminal
Download GAG from here
http://www.mediafire.com/?q1hhft5azyi
You can also get the latest version from here
http://gag.sourceforge.net/download.html
Save it on your linux desktop.
Installation Method 1:
Right click on the file and select Extract here. Open a terminal and browse to the folder using the cd command. In that folder enter the linux folder using the cd command.
At prompt type
sudo ./copy-file.sh
and press ENTER
Then type
sudo ./gag-install /dev/sda
and press ENTER. If this does not work (in OpenSUSE), type su and press ENTER to become root, and then type
and press ENTER.
Restart your PC
Installation Method 2 (EASY):
Right click on the file you just downloaded and select Extract here. Open the folder, you will find a file cdrom.iso in it, write that file to a cd using the default cd writing software in linux (simply double click on it and burn). Restart your PC and boot from the cd.
Whichever of the above you have followed, you will now get this screen
Press 4 to install GAG. You will get this screen next
Select your keyboard (usually 1 in India)
then your language
You will then come to this screen. press S to setup the bootloader
The alphabets you have to press to execute a function are highlighted in red in the GAG set up screen. Keys are case insensitive. Press A to add an operating system
As you can see, partition A is the floppy, B is the first windows partition, so press B
You will now have to type a name, say Windows
You will have to now type a password, optionally, so press ENTER to avoid giving one
You now have to select an icon, Press C for windows
Now you will come back to this screen
Now if you remember the first partition you made was swap, so that's D, followed by /, that's E over here (refer the partition table in your notes). So press E (in this example).
You will now have to type a name, say Linux
You now have to select an icon, Press D for Linux
  #24
Old 24-08-2008, 03:01 PM
TheSaint
Press H to save in the hard disk, you will get this message, press ENTER
Press R to return to the main menu, you should see this
Extra options in the setup include setting a timer for a default OS to boot.
Read the index.html file in the docs folder of the gag file you downloaded.
All the best !!!
  #25
Old 24-08-2008, 03:15 PM
Garbage's Avatar
God of Mistakes...
OMG... It's superb...
Requesting mod for STICKY !!!
DEFINITION:
Unban Praka123 !!!
  #26
Old 24-08-2008, 03:34 PM
ichi's Avatar
Unban praka123
awesome, openSUSE looks way better than Ubuntu.
Am tempting to install it over Ubuntu now, as am using Arch mainly
thanks for this nice tut.
  #27
Old 24-08-2008, 07:36 PM
OpenSuSE Looks cool...
Regards,
The Conqueror
  #28
Old 25-08-2008, 12:25 AM
TheSaint
PDF version of this guide - http://www.mediafire.com/?vuvfmgfm02j
md5sum 42befee063ab7317d5791d8983ca6052
  #29
Old 25-08-2008, 01:14 AM
ichi's Avatar
Unban praka123
^^thanks
How do you convert it to pdf ?
  #30
Old 25-08-2008, 07:27 AM
TheSaint
Using OpenOffice 2.4.0
That's one of the lesser known features of OpenOffice. Even in OpenOffice 1.4 we had the option of exporting our files as pdf and swf !!
All we have to do is type our document and click the pdf icon in the openoffice writer toolbar
Forum Jump
[Tutorial] How to dual boot Linux and Windows Cyrus_the_virus Open Source Software 5 21-02-2008 06:15 PM
Dual Boot Windows and Linux in a Smart Way! rakeshishere Open Source Software 1 11-03-2007 09:45 AM
dual boot linux not having windows ondemandemails Software Q&A 5 08-02-2007 10:56 AM
Dual Boot For Linux and Windows XP cooldev007 Open Source Software 13 14-11-2005 12:08 AM
Dual Boot Partition windows(NTFS/FAT32 ?); Linux (ext3/ext2) godblessedson QnA (read only) 3 12-07-2005 07:16 PM
Upcoming Events
Thinkdigit
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
