Go Back   Digit's Technology Discussion Forum > Across The Board > QnA
QnA This is the place to share what you know, and learn what you don’t. If you have questions that do not qualify as either Hardware or Software questions, post them here...
Thread Tools Search this Thread Display Modes
Old 06-08-2008, 09:20 PM   #1
baradhwaj
Default Help Needed- Lan
Pple,
Is It Possible To Send Messages Thru Lan Knowing The Ip Address And The Port Number Of The System????? I Am Workin On A Project...... I Need Ur Help Regarding This.........
Thanks In Advance!
baradhwaj is offline   Reply With Quote
Old 06-08-2008, 11:34 PM   #2
motobuntu
motobuntu's Avatar
Send a message via Yahoo to motobuntu
Default Re: Help Needed- Lan
yes, it's possible
In case of windows xp you can use "net send". Only ip address is required for this.
A computer once beat me at chess, but it was no match for me at kick boxing.
motobuntu is offline   Reply With Quote
Old 07-08-2008, 07:54 PM   #3
lywyre
Jai Suresh
lywyre's Avatar
Send a message via Yahoo to lywyre
^^ thats the easiest way. But ensure that you have enabled the messenger service from services.msc
We want the old forum back.
We don't wanna discuss on a digital billboard.
lywyre is offline   Reply With Quote
Old 07-08-2008, 08:15 PM   #4
debsuvra
is NOT a PC/Mac
debsuvra's Avatar
Send a message via MSN to debsuvra Send a message via Yahoo to debsuvra
Lightbulb Re: Help Needed- Lan
Originally Posted by baradhwaj View Post
Pple,
Thanks In Advance!
I think the Apple Bonjour Service do that thing quite efficiently. Also there are some real good tools in linux too; for example Avahi in GNOME.
If u are sticking with Windows then use the previous methods told here. Or u can install Bonjour for Windows from Apple.
Tech Side of ME: www.techsideofme.com
debsuvra is offline   Reply With Quote
Forum Jump
Help needed. Things needed to connect SATA HDD to... prashantmaxsteel Hardware Troubleshooting 3 21-11-2007 12:26 PM
help needed amanjagga QnA 4 29-10-2007 03:30 PM
2nd hand LCD or DLP projector needed/reference of dealer needed Adam Lee I Want... 1 21-10-2007 04:39 AM
needed 2 buy a good camera????? help needed.. The Day Walker! Reviews 5 02-07-2005 04:43 PM
help needed mohit sharma QnA 2 27-01-2005 09:38 PM
Upcoming Events
Think diget
Powered by vBulletin® Version 3.8.2
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
