Go Back   Digit's Technology Discussion Forum > Member Reviews > Tutorials
Tutorials This section offers tutorials and How to's on just about anything related to computers and IT. Note: All tutorials are courtesy the posters and not verified by Digit
Thread Tools Search this Thread Display Modes
Old 29-04-2005, 11:32 PM   #1
goobimama
 Macboy
goobimama's Avatar
Send a message via MSN to goobimama Send a message via Yahoo to goobimama
Default Reflective Text (Photoshop Tutorial for Absolute Newbies)
Here’s a very simple tutorial to add a reflection to text. Its very simple but very important.
Step 1: Create/Open your document and type in something. White background and Ethnocentric Font, Black. Once you have gotten the basic concept, you can do this with other types of backgrounds.
Step 2: Duplicate the Text Layer (Ctrl+J).
Step 3: Rasterize the type by Right-clicking on the text in layer in the layers palette or go to Layer > Rasterize > Layer
Step 4: Go to Edit > Free Transform or press Ctrl+T to transform your text.
Step 5: Drag the top anchor downwards to have the text peel off downwards into a reflection. Drag it to about 80% of the size of the original text.
Step 6: Tap the down arrow key 1 or 2 times to separate the bases of the two text layers.
Step 7: Reduce the Opacity of the reflection layer to about 40%
Step 8: Ctrl+Click the reflection layer to select the text. Then, using your gradient tool, add a Black to White gradient. Drag from the top to bottom of the text in the reflection layer.
I know I really made a simple process complicated, but what the hell.
I'm like a bird...
goobimama is offline   Reply With Quote
Old 30-04-2005, 05:30 AM   #2
ramakrishna.nalla
Great and Simple
The Key Points only:
font(for good result)
Reflected layer Opacity 40%
Reflcted text size 80%
Gardient IS must
Very simple........Thanks mama
ramakrishna.nalla is offline   Reply With Quote
Old 30-04-2005, 07:48 AM   #3
dreams
Thinking...
dreams's Avatar
hey mama ur really awesome some gud and creative tutorials are frm ur side..kudos !!!
HTC Touch - Elfin - P3452 - WM 6.5
iPT 2G(S) 8GB - JBn
MAC OSx86 on P4 2.4Ghz
- Dont Dre@m... Juz Chase UR Dre@m -
dreams is offline   Reply With Quote
Forum Jump
Upcoming Events
Think diget
Powered by vBulletin® Version 3.8.2
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
