Go Back   Digit's Technology Discussion Forum > Across The Board > Software Troubleshooting
Software Troubleshooting Issues related with your OS, applications, system security, configuration of network, browsers, customizations, driver support, tweaking, audio-video playback problems and programming can be discussed here.
Thread Tools Search this Thread Display Modes
Old 19-05-2008, 06:59 AM   #1
KRISHI101
KRISHI101's Avatar
Exclamation NFS.MOST.WANTED CRASH WHILE PLAYING GAME D3D9.DLL ERROR Plz help..
Hello to everyone...
i am the new user in digit forum....
i like to play nfs most.wanted game..
When i play the game it get crash always after 10 or 15min. it means game runs fine on my pc...but suddenly after some time it got crash....( Why it happens? )
Error shown as ......''''' speed.exe has encounterd a problem need to close '''''
modename- d3d9.dll....
now my problem is because of this d3d9.dll error.....
i have medium range system with via-Unichrome pro igp display graphic card ....
and all other requirements are fullfilled for the game...
I have latest Direct-x 9.0c.....
I hope you can understand my problem now...
Plz give me any suggetion how i fix this problem......
i will be thankful for ur attention...............
KRISHI101 is offline
Old 19-05-2008, 08:09 AM   #2
dheeraj_kumar
Legen-wait for it-dary!
dheeraj_kumar's Avatar
Send a message via Yahoo to dheeraj_kumar
Default Re: NFS.MOST.WANTED CRASH WHILE PLAYING GAME D3D9.DLL ERROR Plz help..
Hello.
Welcome to the forums!
Even we do...
Its like saying you arent feeling well. Anything may be wrong with you. Lets investigate more, shall we? Mostly it can occur due to a pirated version which has not been cracked/ripped properly.
This is a directx dll. It is used by the game to render the graphics.
Not really. Either there is something wrong with the game exe, or with the directx in your comp.
Are you sure this card is supported by NFS? goto www.systemrequirementslab.com to test your pc.
All others are fulfilled, meaning graphics card is not supported? if its not, then you need to get a better one...
Try reinstalling dx 9.0c.
Kind of.
Yep, try the ones above. ^^
Yep, thanks accepted!
Hehe, was in a good mood cuz of nice sunny morning
Scissors cuts Paper covers Rock crushes Lizard poisons Spock smashes Scissors decapitates Lizard eats Paper disproves Spock vaporizes Rock crushes Scissors
dheeraj_kumar is offline
Old 19-05-2008, 08:10 AM   #3
dhanusaud
S60V3 Hardcore User
dhanusaud's Avatar
Send a message via AIM to dhanusaud Send a message via Yahoo to dhanusaud Send a message via Skype™ to dhanusaud
Direct-x has problem, update it will work fine.
My blog http://www.mahunyal.com
for Symbian 3rd Edition SVG & QVGA themes
Compatible with S60v3 FP1, FP2 & 5th Edition Phones
dhanusaud is offline
Old 19-05-2008, 03:56 PM   #4
KRISHI101
KRISHI101's Avatar
I have reinstalled directX9.0c also but the problem is as it is....
and game runs fine only in the middle of playing after 10-15 min it get crash....and modename is d3d9.dll is shown,,,,,
thanks for ur kind reply Mr.dheeraj_kumar but it does not help me ....
And ofcourse its pirated but it runs fine in my friend's pc ....
Only i got these problem and i have reinstalled the game also.....
May be Driect-Draw is the problem...but why after 10-15 min...
Is there any proper way i can increase the time....means it runs for some more time.....
Again i tell u game runs smothely......but after some time .......CRRRRASSSSH
plz someone help me how to fix this problem.....??
Old 20-05-2008, 05:17 PM   #5
KRISHI101
KRISHI101's Avatar
Is anything Wrong....
why i didnt get any reply? Or the que, is much tough..
Old 20-05-2008, 05:38 PM   #6
MetalheadGautham
The Smaller Bang
MetalheadGautham's Avatar
google for d3d9.dll
you may find it in dlldump.com or something.
then download it and place it in the system32 folder replacing the current dll.
PS: First time I read this thread, I saw "NFS Most Wanted Crash" I was surprised, because crashing is a common thing in racing games
OpenSource | Linux | Hardware | Software | Tutorials | Lifestyle | Humour
P4 2.66GHz, Hynix 1GB DDR-400, Seagate 80GB, Intel D915GLVG, Sony 18x DVD-RAM
MetalheadGautham is offline
Old 20-05-2008, 05:39 PM   #7
KaranTh85
Wanna Fight! C'mon
KaranTh85's Avatar
Send a message via Yahoo to KaranTh85
It seems ur d3d9.dll file is corrupt..
just download dat file from dllfiles.com & see whether it works or not
I m the Best bcoz i work with the best....
Some people question wat i say...
try 2 break-up u & me...
KaranTh85 is offline
Old 20-05-2008, 05:45 PM   #8
MetalheadGautham
The Smaller Bang
and here it is:
http://www.dll-files.com/dllindex/d3d9.zip?0VDdPGbLdQ
Old 22-05-2008, 05:39 PM   #9
KRISHI101
KRISHI101's Avatar
Exclamation Re: NFS.MOST.WANTED CRASH WHILE PLAYING GAME D3D9.DLL ERROR Plz help..
Thanks all of you for your kind reply...
Yes i have downloaded the d3d9.dll file from tht site....
Now the version of my system's d3d9.dll is 5.3.2600.2180
And the file which i downloaded is 4.9.0.901......
So i replace this file to older one in my system32 folder......
But again the old file is restored automatically........
yes when i replace the downloaded 4.9.0.901 file with older one it replaced but instatly it restored by as it is means in old v5.3.2600.2180.....so how is backup happens....?
so i cant replace the file even with pc restarted also.....
and this time i run the game it again crash and error shown as file schedsvc.dll .....
and again d3d9.dll file error shown when i run the game second time.....
and the mode version is 5.3.2600.2180 for both mode name.
bcoz the version is same for both file...
i think i will not find the problem unless i want to buy new pc...
thanks again to all....
and will be thankful if problem will solved,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,
Old 22-05-2008, 05:59 PM   #10
KaranTh85
Wanna Fight! C'mon
KaranTh85's Avatar
r u sure u got the ryt dll file....
just chec inside game folder whether it has any dll files with similar name....
d3dx9.dll etc
Old 22-05-2008, 08:16 PM   #11
dheeraj_kumar
dude... 5.3.2600.2180 is the version and build of your windows. 4.9.0.901 is the version and build of the directx. I suggest you to get the 60 MB dx redistributable from microsoft.com and use it.
And you cant replace files because of SFC or System File Checker. it detects any modifications of system files, and when it does, it automatically restores a safe backup.for bypassing it, use safe mode
Old 22-05-2008, 08:20 PM   #12
KRISHI101
KRISHI101's Avatar
No..mr. KaranTh85 there is no such file in game folder...and error shown file is version 5.32600.2180 which is the version of my system32 's file d3d9.dll...
it is system file and i cant replace tht..
is thre any hidden backup? becoz whenever i replace the file its allow me but instatly the old file again restored thre (in system32 folder)
thanks mr.dheeraj_kumar so is it harmful for replace the file?
and should i replace the file in safemode as u told ...and i told u i have latest directx9.0c although it is september update....but i think nothing is changes in directx... becoz thre is no new version is produced ( is it?)
and the directx10 is for vista i cant use it....
Old 23-05-2008, 08:59 AM   #13
dheeraj_kumar
Well, files get updated all the time, and microsoft releases the runtimes every month.
this is the latest(march 0
http://www.microsoft.com/downloads/d...displaylang=en
70 mb.
Old 23-05-2008, 09:14 AM   #14
Riteshonline
*Unlimited&Ultimate*
Riteshonline's Avatar
Send a message via MSN to Riteshonline Send a message via Yahoo to Riteshonline
Huhhhh!
@ KRISHI101 Try this if u r guiune user otherwise NAG!!!!!!
Riteshonline is offline
Old 23-05-2008, 10:35 AM   #15
KaranTh85
Wanna Fight! C'mon
KaranTh85's Avatar
as told dheeraj_kumar use the march08 setup....
I guess ur problem will be solved then
Old 25-05-2008, 01:34 AM   #16
KRISHI101
KRISHI101's Avatar
ok i will try it...altough i have airtel mobile office internet so i cant think more than 5-6mb..but thanks all of ur valuable guidance...i will chek it out.....thanks again
and ya i forgot to tell tht...i can run many game like...maxpayne2...wwf raw...nfs hp2....freelancer..igi2.....etc law rang games
only this game is get crash..and i cant play it...just it....
but i will try tht update....
Old 25-05-2008, 03:16 PM   #17
dheeraj_kumar
Does this work in other computers? if not, the game might be faulty.
Old 26-05-2008, 02:34 PM   #18
KRISHI101
KRISHI101's Avatar
No. In Other Comp. It Runs Well.....only In My Pc...and I Dont Think Directx Update Will Solve This....i Stuck..............
But Thanks Man
But Thanks Man
Old 26-05-2008, 02:55 PM   #19
ctrl_alt_del
A Year Closer To Heaven
ctrl_alt_del's Avatar
Send a message via Yahoo to ctrl_alt_del
You have had enough help for a pirate. Take these queries to the some warez forum.
The ANGRY Pixel proudly announces the launch of India's first ever launch center for a game, The ANGRY Pixel - Milestone Interactive Street Fighter 4 Launch Center
ctrl_alt_del is offline
Forum Jump
Which Game Are You Playing albeinstein Gamerz 142 15-07-2007 12:31 PM
Which game are u playing n.regmi Gamerz 48 22-12-2006 01:50 PM
RAM playing Game sac_meer Hardware Troubleshooting 3 02-11-2006 11:24 PM
is anyone playing this game?? rohanbee Reviews 12 13-01-2005 07:59 PM
game crash shivi4 QnA 1 18-10-2004 08:41 PM
Upcoming Events
Think diget
Powered by vBulletin® Version 3.8.2
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
