Go Back   Digit's Technology Discussion Forum > Across The Board > QnA
QnA This is the place to share what you know, and learn what you don’t. If you have questions that do not qualify as either Hardware or Software questions, post them here...
Thread Tools Search this Thread Display Modes
Old 09-04-2008, 08:57 PM   #1
blademast3r
blademast3r's Avatar
Send a message via MSN to blademast3r Send a message via Yahoo to blademast3r
Angry Is BSNL blocking torrents??
Hey ppl... i use u torrent for my torrent transfers... i had portforwrded my port and things were fine... but frm like the past month utorrent says ports are blocked... i hav added the ports to my firewall exception nd done all that... is it sm issue wid dataone? i hav a home 500 plan btw
Check out my blog :
www.rammbhat.blogspot.com
Check out my articles :
http://hubpages.com/profile/killer414
blademast3r is offline   Reply With Quote
Old 09-04-2008, 09:07 PM   #2
sachin_kothari
sachin_kothari's Avatar
Send a message via ICQ to sachin_kothari Send a message via AIM to sachin_kothari Send a message via Yahoo to sachin_kothari Send a message via Skype™ to sachin_kothari
Default Re: Is BSNL blocking torrents??
no problem here.
i am on ul900
sachin_kothari is offline   Reply With Quote
Old 09-04-2008, 09:07 PM   #3
akshaykapoor_3
Torrent Lover :)
akshaykapoor_3's Avatar
Send a message via Yahoo to akshaykapoor_3
Even am using H500 plan.. but i dont see any such prob.. Try switching over to some other port.. m using XP nd Vista Ultimate... I never had any such issues with vista bt smtimes dese thngs do show up in xp
akshaykapoor_3 is offline   Reply With Quote
Old 09-04-2008, 09:54 PM   #4
alok4best
TooR
alok4best's Avatar
Send a message via MSN to alok4best Send a message via Yahoo to alok4best
U need to forward Port in ur Router too...only doing that in WinXP firewall wont help...also enable encryption in utorrent.
for tutorials on how to forward some port in router go to portforward.com
I wish !!
alok4best is offline   Reply With Quote
Old 10-04-2008, 12:44 AM   #5
gsmsikar
gsmsikar's Avatar
Send a message via ICQ to gsmsikar
if BSNL block torrent then i will block BSNL from my House...
gsmsikar is offline   Reply With Quote
Old 10-04-2008, 05:59 PM   #6
blademast3r
ive done all that buddy... things still not fine
Check out my blog :
Old 11-04-2008, 12:24 PM   #7
Ramakrishnan
The Researcher
I have h500. I have no problems.
Ramakrishnan is offline   Reply With Quote
Old 11-04-2008, 03:08 PM   #8
Xccentricity
Reset ur modem manually and reconfigure it, I had the same problems on my Beetel router.
Xccentricity is offline   Reply With Quote
Old 11-04-2008, 03:14 PM   #9
Rudick
Rudick's Avatar
Blademast3r what's ur circle and during normal web activities how's ur avg. speed?
You can get much further with a kind word and a gun than you can with a kind word alone.
Rudick is offline   Reply With Quote
Old 12-04-2008, 01:07 AM   #10
alok4best
TooR
alok4best's Avatar
Bt thats all what is required...and how can BSNL block all ports, afterall they dnt know which port u r going to use for torrents.
once again make sure..
1. U have not checked the setting "Randomize port every time", in utorrent..
2. Add that port to Win Firewall exceptions.
3. Give a static IP to ur machine, something like 192.168.1.100.
4. In ur router forward that port to this IP(192.168.1.100).
If things still do not improve, use port 80 for Utorrent also..
Give it a try...
I wish !!
Old 29-06-2008, 08:48 PM   #11
zombie4eva
zombie4eva's Avatar
Yup BSNL has been blocking Torrents and this is the what my bittorrent showed....
have googled for solutions and now this is what i have come across...
Note this is for Bitcomet Client You can also do the same with other Clients.
Well... here's a step by step guide that maybe can help you turn that
yellow light if you do it right... This guide is for BitComet v0.98
(it might work with all versions) and Windows XP...
If you got something other than XP then you figure this out yourself...
First of all... get the new version of BitComet v0.98 here...
After finished installing BitComet open the Options Menu...
And then set your 'Listen Port' above '40000'...
For this guide I'll use '60000' and you can use that port too
if you like... Moving on...
Set your 'Global Max Upload Rate' (depends on your line speed)
The higher the better but not too high...
For this guide I'll set it to '36' 'kB/s' because I got a 512 'kb/s'
upload line speed..
Usually if you got a 512 'kb/s' upload speed you need to divide it to 8
and then set it to 80% of your calculated speed in there but the
easiest way to do it is to divide it by 10 and you got your optimal
speed in 'kB/s' So if my upload speed is 512 'kb/s' then devide it by 10
then I got 51 'kB/s' right... Now you ask me why I put 36 'kB/s' here
right? This is why...You can test your upload speed here... Make sure
you close all open applications that use internet connectivity before
you run the Speed Test to get an accurate line speed...
When I tested my line speed there I got 360+ 'kb/s' so I divide it by 10
then I got it 36 'kB/s' Did you notice the 'kb/s' and 'kB/s' it's the
letter 'b' and 'B' so... 'b' means 'bit' and 'B' means 'Byte'...
see the different? the Speed Test use 'bit' and BitComet use 'Byte'...
After that... get going...
Follow and set with the above options... I'm so lazy to key in all the
options name here... That's it for the BitComet configurations...
After this you have to set your router settings... Coming up next...
Now... moving on to the router settings... Make sure you close
your BitComet before you do this..
if not you can find your router type and set it here depends on your
router type... Select your router type and follow the link...
then choose 'BitComet' in the page link there and follow the instructions
for your router settings...
For the other type of router model please follow this link and choose
your exact type of router model and follow the instructions here...
http://www.portforward.com/english/r...outerindex.htm
Open up your web browser and enter your router IP Address in the
Address box... If you don't know your IP then open a 'DOS/Command Prompt'
if you don't know what a 'DOS/Command prompt' is then you don't have
to set anything just close this and burn your PC...
In your 'DOS/Command prompt' key in 'ipconfig' and you'll get something
like this...
Can you see your IP Address now? '192.168.1.3' that's it...
Default Gateway... that's your router address...
For this guide it is '192.168.1.1' maybe you got another IP... (memorized it)
Now open up your web browser and enter your router IP Address in
the Address box... Enter your username... then your
password...
BitComet chooses a random port to listen on when you install it. Before we can forward ports for BitComet, we need to find out what port BitComet is using. Go ahead and open BitComet.
In the menu at the top of your screen, click Options. Clicking Options will cause a menu to drop down. In this new menu click Preferences.
In the menu on the left the top option Connection should be selected. On the right hand side of this window you should see a Listen Port option. That is the port that you need to forward. You can change it if you like. Please enter the listen port below.
BitComet's Listen Port:
There is one more thing we need to do. We need to shut off the UPNP of BitComet.
In the menu on the left hand side under Advanced, click Connection. There should be an Enable UPnP Port Mapping(XP only) checkbox on the right hand side. Make sure it is unchecked.
To setup port forwarding on this router your computer needs to have a static ip address. Take a look at our Static IP Address guide to setup a static ip address. When you are finished setting up a static ip address, please come back to this page and enter the ip address you setup in the Static IP Address box below.
Do not skip this step!
Open a web browser like internet explorer or Netscape. Enter the ip address of your router in the address bar of your browser. In the picture above the address bar has http://www.google.com in it. Just replace all of that with the ip address of your router. By default the ip address should be set to 192.168.1.1.
You should see a box prompting you for your username and password. Enter your username and password now. By default both the username and password are adminb. Click the Ok button to log in to your router.
Click the Advanced Setup link near the left side of the page.
You should now see a new menu. In this new menu, click NAT.
Click the Add button near the center of the page.
check in your BitComet and see if you got a remote connections...
If you got it then your router has been configured correctly and your
port has been forwarded succesfully...
Last thing to do... Open your BitComet... If it doesn't get the GREEN light
that you've been dreaming about then open your windows firewall and
check the settings...
Start -> Control Panel -> Windows Firewall... See below...
If you didn't get something like that then just DISABLE your firewall and
you're done... And you can stop dreaming now because you got your
GREEN light now...
AND FINALLY
Did you see the green light there? WAN:
And this is my average speed when I'm GREEN..
(Using Home 500 Plan with Night Unlimited)
zombie4eva is offline   Reply With Quote
Old 29-06-2008, 09:15 PM   #12
bajaj151
bajaj151's Avatar
Send a message via Yahoo to bajaj151
I too think so...that BSNL is blocking torrent.
Problem at my end is....when I connect to net........surf & download (NON Torrents)....works fine...As soon as I open torrent using utorrent...after 15-20 min.....net disconnects.
www.exclusivearena.blogspot.com
bajaj151 is offline   Reply With Quote
Old 29-06-2008, 11:43 PM   #13
Choto Cheeta
Rebooting
Choto Cheeta's Avatar
Send a message via Yahoo to Choto Cheeta
@bajaj151
doesnt seems BSNL blocking torrents infact bellow 2 screen shot should give you the proper idea, actually torrent offering better speeds than FTP or HTTP connection
DAP
Where as good old uTorrent
rebooting
ChotoCheeta.com
Choto Cheeta is offline   Reply With Quote
Old 30-06-2008, 10:14 AM   #14
bajaj151
bajaj151's Avatar
Originally Posted by Choto Cheeta View Post
@bajaj151
Then...what may be the problem...Everytime I start utorrent....after 15-20 min....net disconnects.....but without utorrent net works fine...
Old 30-06-2008, 11:18 AM   #15
dd_wingrider
dd_wingrider's Avatar
Send a message via Yahoo to dd_wingrider
For the past 3-4 days i am also facing very low download speed, 5-4KBps to be precise on bsnl UL 900 plan, its damn frustrating
http://iphone3g-india.com - One stop for all iPhone3G updates, tips,news,resources
dd_wingrider is offline   Reply With Quote
Old 30-06-2008, 11:46 AM   #16
bajaj151
bajaj151's Avatar
Actually...me too on same plan...but...I am getting normal speed....but my net disconnects after 15-20 min....the I have to restart my modem again.
Old 30-06-2008, 05:28 PM   #17
Choto Cheeta
Rebooting
problem seems to be at BSNL end line may have unstable Attenuation values
rebooting
ChotoCheeta.com
Old 01-07-2008, 01:45 PM   #18
dd_wingrider
Well i really dont know the cause of the problem for my low download speeds, but jus for the heck of it, yestreday i downloaded bitlord to give it chance(was using utorrent before), and suprisingly for the same torrent i got good download speed(avg 30KB-35KBps) in bitlord whereas it was giving pathetic (0.6 to 5KBps) in utorrent.
I have no idea whats the problem with utorrent, but download speed matters for me and for the time being i am happy
Old 01-07-2008, 02:19 PM   #19
amrawtanshx
Redemption in May ...
amrawtanshx's Avatar
Send a message via Yahoo to amrawtanshx
I am getting Avg. 200 kBps with Home 500 plan....
So here no problem.
XFX 8800 GT || Nokia N73 & E62
"What happens when an unstoppable force meets an immovable object ???"
My xFire id .. amrawtanshx
amrawtanshx is offline   Reply With Quote
Forum Jump
Blocking Orkut ! max_demon QnA 14 29-01-2008 08:08 PM
blocking sms vish786 Mobile Monsters 19 09-08-2007 10:21 PM
Is ip blocking is legal? orkube.com QnA 1 28-06-2007 09:51 AM
ISP blocking Torrents ? Maverick340 QnA 6 06-03-2007 04:04 PM
Blocking POP-ups in Web page brshravan Software Troubleshooting 5 11-08-2006 09:06 AM
Upcoming Events
Think diget
Powered by vBulletin® Version 3.8.2
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
