Go Back   Digit's Technology Discussion Forum > Member Reviews > Mobile Monsters
Mobile Monsters All threads related to cell phones, laptops, PDAs, MP3 players, and other assorted mobile gizmos... Strictly for the geeky!
Thread Tools Search this Thread Display Modes
Old 18-10-2007, 11:46 PM   #1
Suhas
Default Music Mobile -Is W200i good enough?
I want to buy a cell phone which allows me to listen good music quality,has good bundled ear phones & a good FM tuner.My budget is around 5-6K. I have singled out SE's W200i.Does it fit my requirements ?
Which other alternative phone provides features similar to W200i, but also has bluetooth ?
Suhas is offline   Reply With Quote
Old 19-10-2007, 12:28 AM   #2
gsmsikar
gsmsikar's Avatar
Send a message via ICQ to gsmsikar
Default Re: Music Mobile -Is W200i good enough?
for music then at this budget this phone is good enough...
gsmsikar is offline   Reply With Quote
Old 19-10-2007, 07:40 AM   #3
Gigacore
Dreamweaver
Gigacore's Avatar
if you dont want any other jazzy stuff than music. . . it is a good phone, no it doesn't have bluetooth. The bundled earphones are fine. . you'll get 128 MB micro card, data cable and software cd in the package. .
Gigacore is offline   Reply With Quote
Old 19-10-2007, 08:22 AM   #4
desai_amogh
The blackholeŽ
desai_amogh's Avatar
Send a message via Yahoo to desai_amogh Send a message via Skype™ to desai_amogh
no bluetooth ..
My Dibba: AMD Athlon 2000+, a cheap Mercury KVM266PM mobo, Seagate 80GB HDDs, Transcend 512mb RAM, Sony DVD Writer, IBM 17" CRT.
K750i moded to W800i Firmware(W800i R1BC001),Vista icons.
desai_amogh is offline   Reply With Quote
Old 19-10-2007, 08:34 AM   #5
Gigacore
Dreamweaver
Gigacore's Avatar
^ did i not say that?
Old 19-10-2007, 01:44 PM   #6
Suhas
If i want blue tooth,then which phone do you suggest...and how much will that cost?
Old 19-10-2007, 01:46 PM   #7
krazyfrog
Posts: n/a
^^ W300i for around 1k more.
Old 19-10-2007, 02:14 PM   #8
Suhas
But W300i is a flip phone ... I dont want a flip phone?
Old 19-10-2007, 04:08 PM   #9
krazyfrog
Posts: n/a
Then either go for Nokia 3110c or Samsung E250.
Old 20-10-2007, 01:27 PM   #10
Suhas
Thank You all of you for your valuable suggestions!
Forum Jump
want to purchase Good EDGE enabled handset with good music quality.... mdp Mobile Monsters 13 29-09-2007 02:40 AM
Good looking music fone under 10k Ray Mobile Monsters 22 28-05-2007 01:31 AM
Good Music Phone in 7K to 8K range... jiteshbhimani Mobile Monsters 38 14-05-2007 10:16 AM
suggest a good music player for n72 ????? abhasbajpai Mobile Monsters 7 30-04-2007 03:14 PM
Upcoming Events
Think diget
Powered by vBulletin® Version 3.8.2
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
