All Codes that I know for 6600
*#06# Serial Number/IMEI indicates
*#0000# SW version (e.g. V3.42.1, 16-10-03, NHL-10)
*#2820# Bluetooth (BT) device address
xx# Directory quick access (xx = storage location and afterwards lozenge e.g. 24 #)
On/Off key -short pressing for menu for switching between profiles
Menu key - Long pressing for "task manager" - switching between active programs (with "C" key programs can be terminated.)
Menu quick access - Over in the menu e.g. to point 3.1 arrive simply 31 enter (if the third symbol a file is opened is for these and then in it started the first Programm/Icon).
No Autostart - When switching the phone on up to the pin inquiry press the whole time the "ABC" key (pen) - this is to ignore the autoinitialization programs (and the MMC programs) - "safeboot".
12345 ... is according to be the standard Nokia nokia-securitycode.
0000 ... is according to be standard PIN2 at Vodafone (germany)
Caution - starting from here the codes are "dangerous"
*#7370925538#
*#Res0Wallet#
... is to delete the code around the "wallet"
Input like normal telephone number (not in wallet code inquiry windows).
NOTE! Afterwards the "wallet" is empty, can again be put on however with new code.
*#7780# - Reset to original settings
NOTE! Afterwards various "attitudes" are away - among other things these:
Points of entrance (Provider dependent points of entrance and attitudes)
Bluetooth attitudes
Favorite
Allocation of the two keys (beside Navi keys) in the main menue
Profiles are "neglected" (as with distribution) - still there however new bell tones, etc. are...
SMS/MMS/E Mail attitudes
Logos and spielstaende (allegedly) also deleted...
Programs, calendars and contacts, etc. not changed...
*#7370# - Soft format - resets all the telefone Memory (like Formatting a disk
NOTE! Battery should be full up to at least 75%, do not accomplish during the procedure under any circumstances ! The procedure takes some minutes (approx. 3-4)
Green, * 3 - Hard format: If the Mobile (only telephone memory) formats, puts back the attitudes (see * to # 7780 #) and implements a RESET.
Proceeding: Equipment switch off, keep "green key" (take off) at the same time pressed, "*" and to "3" key and switch the equipment on (the keys thereby keep further pressed)... to "Formatting" on the display appears...
