Re: USB Port not working
sum1 probably disabled it from BIOS, in which case u need to re-enable it
if u r rulin that out
wat OS u usin?
if its -pre XP, like ME or 98 den i suggest dat u re-install d USB drivers
if u usin XP den u mite wan2 check device manager for d USB ports
if they have a yellow mark aganist them then it means that it they got sum driver problem
i suggest dt u uninstalldem and restart d comp, they will b automatically detected and reinstalled on next boot
also if ur mobo needs USB controller sw den re-install those also
if u wan2 add more USB slots to ur comp, u can do so with a PCI-based USB card
will give u around 4 USB slots
will cost around 200-300 [i think]
Mah Blog: www.shubhspace.com
F-35 JSF: www.f35.za.net
Indian Defence: www.rakshak.za.net
New Sharing: www.mynews.za.net
Scrapbook: tumblr.shubhspace.com
Reason: Automerged Doublepost
