Re: Home Theater
its true yamaha are indeed the best in receivers, in speakers u might wanan go for the cheap ones becuz ur budget is pretty low, or there is a sony home theater system around 28k thats preetty fine and is near 600watts i think, personally home theater systems, u shud invest alot because its a 1 time investment, it suggest u the sony one or u can try a samsung one which has a hdmi port too, its also 28k but less sound quality than the sony one
try ur local samsung and sony shops
Seagate 500gb 7200RPM l Corsair 2*1GB Ram 800mhz l XFX 8800 GTS 320MB Xtreme 650/ 1500/ 950 l Asus P5N-eSLI l Core 2 Duo e6750 l Coolermaster Extreme Power 600watts SMPS l Microtek 800VA Ups l
