Go Back   Digit's Technology Discussion Forum > Hardware > Hardware Q&A > QnA (read only)
QnA (read only) Mods please help transfer the contents of this forum to Hardware or Software Q&A
Thread Tools Search this Thread Display Modes
  #1
Old 04-09-2007, 11:07 AM
vicky_l7 vicky_l7 is offline
free as a bird
Send a message via Yahoo to vicky_l7
Default firefox problem
hi guys recently firefox hangs a lot in my system and start using 100 % cpu, currently i am using this extensions fasterfox,flashgot,pdfdownload,skype extension,adblock,tab mix pix . plz help needed to fix this problem and i have 512 mg ram
  #2
Old 04-09-2007, 11:27 AM
shady_inc's Avatar
shady_inc shady_inc is offline
Pee into the Wind...
Default Re: firefox problem
Tips to handle firefox memory usage.
Reduce memory usage on Firefox.
Google search will yield many more results related to firefox memory hogging.
Life is as complicated as you say it is.
  #3
Old 04-09-2007, 11:44 AM
ax3's Avatar
ax3 ax3 is offline
Cool as a CUCUMBAR ! ! !
his problem is since 1.0 ....... they still havent solved it ...... hope they do it in newer versions ie FF 3.0 ..........
... W H O T ...
  #4
Old 04-09-2007, 02:52 PM
abhijangda abhijangda is offline
scan ur comp may be virus or spyware.
  #5
Old 04-09-2007, 03:12 PM
zyberboy's Avatar
zyberboy zyberboy is offline
dá ûnrêäl Kiñg
Send a message via Yahoo to zyberboy
disable all extension and chk the cpu usage....and also try to start firefox in safe mode
My Stomach pains
http://tinyurl.com/32jj4m
  #6
Old 04-09-2007, 03:26 PM
free as a bird
my system doesnt have any virus,scaned with avast latest definations and spybot
Forum Jump
firefox problem ash2win Software Q&A 1 25-08-2007 08:43 AM
firefox problem babuli_05 QnA (read only) 2 08-11-2006 02:00 PM
Firefox problem!! jamyang312 Software Q&A 1 13-12-2005 11:11 PM
Firefox Problem shwetanshu QnA (read only) 3 28-07-2005 07:44 AM
FireFox Problem shwetanshu QnA (read only) 4 07-02-2005 12:46 PM
Upcoming Events
Thinkdigit
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
