Go Back   Digit's Technology Discussion Forum > Across The Board > Hardware Troubleshooting
Hardware Troubleshooting Discuss basic Hardware problems, find solutions to your hardware queries, upgrade blues. From Hardware Overclocking to Cooling and Case Modding all queries, howtos, solutions go here.
Thread Tools Search this Thread Display Modes
Old 11-08-2007, 07:40 PM   #1
swaroop123
Default Info about RAM and Graphics card
I have 256 mb DDR 400 RAM on my computer and was thinking of upgrading it to 1 gb.But I came to know that DDR 2 rams are much cheaper than DDR ones.So my question is whether I can dump my 256 mb RAM and use a fresh DDR2 1 gb RAM on my computer.Will my computer support it?I have Intel 915 chipset motherboard.It will be also be helpful if you can inform me about the current prices of 1 gb RAM of both DDR and DDR 2 variety.I live in Kolkata.Secondly,I will also be buying a graphics card,so please suggest me the best deal at about Rs 3000.
swaroop123 is offline   Reply With Quote
Old 11-08-2007, 08:17 PM   #2
amandeep86
amandeep86's Avatar
Send a message via Yahoo to amandeep86
Default Re: Info about RAM and Graphics card
If i'm not wrong, your Motherboard will support DDR2 RAM. 1GB DDR2 RAM will cost you around Rs.2000-2200 depending upon Brands. But, preferably go for two dual 512 mb modules (Same).
And about your graphics cards query, goto: http://www.deltapage.com/graphic.htm
amandeep86 is offline   Reply With Quote
Old 11-08-2007, 08:24 PM   #3
xbonez
NP : Crysis
xbonez's Avatar
not sure whether 915 supports ddr2. check prices at theitwares.com
for 3000, u can get 7300gs
If fate doesn't make you laugh, you just don't get the joke
Match music tastes www.last.fm/user/xbonez
xbonez is offline   Reply With Quote
Old 11-08-2007, 09:02 PM   #4
Pathik
Google Bot
Pathik's Avatar
i think u can get a 8400m gs in 3k.. also 915 supports ddr2 only... not ddr..
Pathik is offline   Reply With Quote
Old 11-08-2007, 09:44 PM   #5
arun_chennai
tech mighty
arun_chennai's Avatar
ya...it supports DDR2...get Transcend 1GB for 1750...for 3k u can get 8400GS...
arun_chennai is offline   Reply With Quote
Old 11-08-2007, 09:59 PM   #6
amandeep86
amandeep86's Avatar
I really like the above mentioned site.
Old 12-08-2007, 12:33 AM   #7
xbonez
NP : Crysis
xbonez's Avatar
thanx. also try out theitdepot.com
they give real street prices unlike the mrp.
if 915 only supports ddr2, how come u're using 400mhz sticks??
Forum Jump
Tv tuner card / Graphics card for my config ... gsenthil Hardware Troubleshooting 4 08-09-2006 07:23 PM
Req. info - PC TV Tunner card shreyadr Reviews 2 11-03-2005 10:36 PM
motherboard, graphics card, and sound card???? angel Reviews 6 07-10-2004 03:19 PM
Query Reg Graphics card/TV Tuner card tiwariG Reviews 10 10-09-2004 06:38 PM
Upcoming Events
Think diget
Powered by vBulletin® Version 3.8.2
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
