Go Back   Digit's Technology Discussion Forum > Gaming > Gamerz
Gamerz This section is dedicated to hardcore gamers. Gaming news, reviews, walkthroughs, easter eggs, cheats, etc., should be posted here. Note: All views/reviews within are the opinions of the respective posters only
Thread Tools Search this Thread Display Modes
Old 30-06-2007, 12:31 PM   #1
levan
Thumbs up Need For Speed Undergr.2 Hamachi network (7/24)come and race
hello...you can easily play nfsu2 with hamachi and join our big network.... race with the masters...
30 online racer per day in our hamachi network
download hamachi here and add networks below: https://secure.logmein.com/products/hamachi/list.asp
network1 : turnuva26
network2 : ht90
pass: 123
to play nfsu2 with hamachi,,,,change server file when installed nfsu2
remove the old one and paste it here: c:\programfiles\eagames\need for speed u2
server file: http://www.savefile.com/files/1346506
so you can see created games.
levan is offline
Old 30-06-2007, 12:33 PM   #2
Goten
Super Saiyan
Goten's Avatar
Send a message via Yahoo to Goten
Default Re: Need For Speed Undergr.2 Hamachi network (7/24)come and race
I still have U2 installed.
How 2 join excatly i dunno.
Nehow who know they can enjoy.
Peace~~~!
Goten is offline
Old 30-06-2007, 12:50 PM   #3
QwertyManiac
Commander in Chief
QwertyManiac's Avatar
Run Hamachi > Join his network > Run game > Enter LAN menu > Play the available game.
Harsh J
www.harshj.com
QwertyManiac is offline
Old 30-06-2007, 01:03 PM   #4
ssk_the_gr8
ssk_the_gr8's Avatar
Send a message via Yahoo to ssk_the_gr8
i am joining u..do i need to install some patch or something to use nfs U2 with hamachi & when r ur users online genrally?
if its 24X7 as u say then its gr8
(Gen.1:26-27) New Testament
ssk_the_gr8 is offline
Old 30-06-2007, 01:04 PM   #5
s18000rpm
On a time-out
s18000rpm's Avatar
me too IN.
just installed U2.
btw can someone help with Most Wanted LAN???
me & Arsenal Gunners tried (searched a lot), but couldn't get it to work
s18000rpm is offline
Old 30-06-2007, 01:06 PM   #6
ssk_the_gr8
Originally Posted by s18000rpm
me too IN.
just installed U2.
hey can u play now..im ready
Old 30-06-2007, 01:12 PM   #7
s18000rpm
On a time-out
s18000rpm's Avatar
Originally Posted by levan
hello,our new network has opened, join us and race with the masters
network1 : levan6
network2 : levan8
pass: 123
(there is a lot of racer our networks)
--you can find hamachi program with google...and how to work
dude, post some instruction on how to configure the server.cfg file.
btw this is what i found-
Okay well after hours of fiddling with VPN and watching ports and processes and etc
I got NFSU2 Working on Hamachi. Its rather simple, In your Need for speed Underground Directory.
*\Program Files\EA GAMES\Need for Speed Underground 2\
There is a file called server.cfg. Open this With Notepad. Right at the bottom there is
DO NOT EDIT ANYTHING UNDER THIS LINE. Your going to ignore this Right at the bottom is the line
ADDR=%%bind("159.153.253.82")
Remove it completely. Then your CFG file should look like this. server.cfg wrote:
# The server sends a ping message to the client every PINGTIME seconds
# and the client is expected to respond within PINGWAIT seconds or
# the server considers the connection to be dead and the client is
# logged out.
PINGTIME=20
PINGWAIT=30
# A client can only be idle for TIMEIDLE minutes before it is
# automatically logged out. Even if a client is not idle it can
# only be connected for a maximum of TIMEMAXM minutes.
# Either/Both values can be set to 0 to mean that the server will
# not timeout the client.
TIMEIDLE=0
TIMEMAXM=0
# Limits how many times per second the LAN server will service requests.
# Lowering this number will increase game performance for slower computers
# at the expense of sluggish response time from the server. Valid range is
# 1-1000.
LAN_THROTTLE=30
## DO NOT CHANGE ANYTHING BELOW HERE
ACCOUNT=1
MASTER=1
SLAVE=1
REDIR=1
# This line allows the server to determine on what interface to listen for
# connections. It can be any publicly routable IP address (this is the case
# even if the host is on a LAN that is isolated from the Internet). There is
# no communication attempted with the IP address listed here.
Old 30-06-2007, 01:13 PM   #8
ssk_the_gr8
not being able to find the hamchi server
Old 30-06-2007, 02:11 PM   #9
s18000rpm
On a time-out
s18000rpm's Avatar
ATLAST
i was able to find a server
but damn, that guy went offline.
just folow the instruction from post #7 & you can play LAN NFS UG2
Old 30-06-2007, 02:20 PM   #10
Third Eye
Bayerische Motoren Werke
Third Eye's Avatar
Send a message via Yahoo to Third Eye
why nfsu2.can we play mw.
File not found. Should I fake it? (Y/N)
Third Eye is offline
Old 30-06-2007, 03:17 PM   #11
s18000rpm
On a time-out
s18000rpm's Avatar
as already mentioned, Arsenal Gunners & i tried almost every tip/trick from net, but cudnt get it to work.
even the Hamachi website (having MW related files is dead )
Need for Speed: Most Wanted on Hamachi
YAY
just had a RACE, but it didnt even last for 20seconds power cut.
HUGE lag (obviously when the ping rate is 340ms+)
Old 30-06-2007, 06:06 PM   #12
levan
for solve the server.cfg problem..... do it post7..it is correct
than join our hamachi network (up to forum)
you can write me in hamachi for the other problems ,when ı am online....or write here....
if you can not see the other players..do this...change server.cfg file.....
\Program Files\EA GAMES\Need for Speed Underground \server.cfg
first open with notepad...delete all inside.... paste at the bottom and save
# logged out.
PINGTIME=20
PINGWAIT=30
TIMEIDLE=0
TIMEMAXM=0
# 1-1000.
LAN_THROTTLE=30
ACCOUNT=1
MASTER=1
SLAVE=1
REDIR=1
levan is offline
Old 02-07-2007, 02:51 PM   #13
aneesh kalra
Mclaren F1 Long tail
aneesh kalra's Avatar
will it work on a 256kbps conection mtnl 590nu at acceptable frame rates.
Computers are like air conditioners. They work fine until you start opening windows.
aneesh kalra is offline
Old 02-07-2007, 03:18 PM   #14
levan
it works but 512 kbps is better
levan is offline
Old 11-07-2007, 01:30 PM   #15
levan
server.cfg file download here: http://www.savefile.com/files/1346506
change this the old one for play nfsu2
levan is offline
Old 04-02-2008, 05:51 PM   #16
levan
our new networks has updated come and race 30 nfs racers
you can download nfsu2 search google. rip
levan is offline
Old 04-02-2008, 11:50 PM   #17
bkpeerless
well any callo of duty 2 server on hamachi
Intel core 2 duo e4300 1.8 ghz 2 ddr2 ram
945 gl mob xfx gforce 8600 gt 512 mb 200gb hdd
bkpeerless is offline
Old 11-02-2008, 08:28 PM   #18
The Conqueror
I Will Conquer Everything
The Conqueror's Avatar
Send a message via Yahoo to The Conqueror
All networks are currently full
Regards,
The Conqueror
The Conqueror is offline
Old 11-02-2008, 08:30 PM   #19
nvidia
-----ATi-----
nvidia's Avatar
Send a message via Yahoo to nvidia
Does anybody know how to host NFS MW in Hamachi?
With or without religion, you would have good people doing good things and evil people doing evil things. But for good people to do evil things, that takes religion.
http://twitter.com/akshayms
nvidia is offline
Old 11-02-2008, 08:35 PM   #20
The Conqueror
Yeah I also want to know how to host NFS MW in hamachi
Regards,
The Conqueror
Old 14-02-2008, 12:22 PM   #21
ashu888ashu888
Core i7 (nehalem) Owner
ashu888ashu888's Avatar
Send a message via Yahoo to ashu888ashu888
Ok guys, this is wat i hv done..
1.) d/loaded the custom made server.cfg file from the above said site.
2.) Installed Hamachi
3.) Joined a network (network: turnuva26 and pass: 123, I can see 1-player online, coz i guess any Online player is marked with a YELLOW STAR against his/her username and offliners with a GREYED STAR)
4.) Runned NFS U2 and clicked on LAN.
5.) THe Status says, Looking for LAN Servers...
Problem: I cannot see any one in the LAN list of NFS U2 ??? Any ideas??
[b] I have a p!rat3d copy of NFS U2, is this the reason ???
Cheers n e-peace...
Proc:Core i7920
Mobo:Evga X58
RAM:Corsair
PSU:Tagan BZ1100
GPU:GTX280 SSC
HDD:WD 1TB
LCD:22" 2233SW(FullHD)
UPS:APC SUA1500i
Corei7Thread: thinkdigit.com/forum/showthread.php?t=110397
ashu888ashu888 is offline
Old 27-02-2008, 08:15 AM   #22
levan
Cheers n e-peace...
copy not reason...you saw only 1 player online so anyone did not create a game...so you couldnt see created games...also you must create games...all racers wait same as you.
now: 25 online our networks..add networks in hamachi
networks
turnuva26
ht90
ht91
ht92
pass: 123
levan is offline
Old 27-02-2008, 12:34 PM   #23
ashu888ashu888
^^ thanx for ur reply (though it was late)
By the way,
are all players on the above mentioned n/ws (turnuva26, ht90,91,92) plzy NFS U2 >??
I.e How can i come to knw wich player is playing wat NFS U2 (race, if any) or wich game ??
Cheers n e-peace...
Proc:Core i7920
Mobo:Evga X58
RAM:Corsair
PSU:Tagan BZ1100
GPU:GTX280 SSC
HDD:WD 1TB
UPS:APC SUA1500i
Old 01-03-2008, 09:15 AM   #24
levan
By the way,
Cheers n e-peace...
ı formatted my pc so it was late.
in the networks,they are all nfsu2 players...first ask hamachi window race type..then in LAN SECTİON you join the game..or you create game and announce chat window this way...for exp: (circüit none yes yes,,ashu server)....your filter must be same the others.
levan is offline
Old 23-04-2008, 07:27 PM   #25
treybal
man i need some help..
i can't see other players and i have one all the steps......
plz.....i need a solution...this is my favorite game..........
treybal is offline
Old 23-04-2008, 07:31 PM   #26
levan
join turnuva26 or ht90 network in hamachi....and want to help... passes: 123
levan is offline
Old 24-04-2008, 01:36 AM   #27
Beta Waves
Beta Waves's Avatar
Guys in the above mentioned Network you will find people of other countries who dont even know english ..... Its very difficult to communicate with them... Why don you try this one Network : NFS_UG2 pass :123
I am Back....
Beta Waves is offline
Old 24-04-2008, 01:59 AM   #28
clmlbx
clmlbx's Avatar
will join too .
tomorrow first work to find disc and install the game
clmlbx is offline
Old 12-05-2008, 02:44 AM   #29
Vox
Hello,, i joint the network too but when i make a lan server nobody can find it:S does anybody know why this is. I have version 1.1 Do i need to forward a poort or something.
Vox
Vox is offline
Old 16-06-2008, 11:54 AM   #30
levan
turnuva26 pass: 123 is the biggests nfsu2 network in hamachi...join
1- you must change server.cfg file here: server.cfg file download here: http://www.savefile.com/files/1346506 (read the start of this topic for how to)
2- than up to hamachi top of the network connection list(go to my computer\network connections\advanced settings\advanced.....
at here take the hamachi the top of the list..and restart your computer..so that you can easily play nfsu2 and see all created games
Turkish windows sample(up to hamachi)
levan is offline
Forum Jump
any hamachi players here? ssk_the_gr8 Gamerz 18 27-10-2009 10:10 AM
Help me with HAMACHI shyamno Software Troubleshooting 11 27-02-2007 07:14 PM
How to improve your Network and Internet Speed prj15 Tutorials 3 10-03-2006 09:49 PM
Upcoming Events
Think diget
Powered by vBulletin® Version 3.8.2
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
