| Reviews A forum to discuss/review ONLY software and hardware products. All your queries about the same go into Respective TroubleShooting Sections and QnA. Your views and first-hand experiences on any software or hardware from OSes to Graphics cards are all welcome here.
Note: The views/reviews contained within this section are purely the opinions of the posters |
28-06-2007, 06:45 PM
#1
creative EP-630 *875 Rs* Nehru place-BEATS BOSE EARPHONES
Many people are asking where to buy the EP 630
And it also beats BOSE in ear reaphones in this review
http://www.techtree.com/India/Review...81840-536.html
I just got them today for 875 bucks with bill from
Infinity Infomatic 317 bajaj house
Nehru Place
ph 41618122,41618123
jittedra 9818380633
got the contact of this dealer from cyberstar Delhi office .
28-06-2007, 06:59 PM
#2
What? Where? How?
Re: creative EP-630 *875 Rs* Nehru place-BEATS BOSE EARPHONES
Did u analyze the points of comparison of the review, most of the reviews are just s*it. Plus distortion will come in earlier in them in comparison to bose. I'm not saying that these are bad, creative makes superb stuff, but i feel bose is better. Plus bose has only been mentioned once in the review and that to its case is mentioned not the output it gives....
98% of the people using internet have started or forwarded "chain mails". If you are one of the 98%, Die a horrible death.
28-06-2007, 07:21 PM
#3
Which are better, EP-630 or Philips SBC-HP800? Both are priced similarly but have different designs, Philips being a headphone compared to Creative being earphones. Both have reputation for delivering great sound.
28-06-2007, 09:16 PM
#4
cool...........i dont belive it beats bose.........and i wanted to buythis
my only quesition........if the cable lenght is large from soure to earphones ( because of extension cable Used in between ) what will be the effect on sound quality and volume ???
2 ppl say nothing..but its hard to believe this....or may be the effect is too small..
Sony Ericsson Flashing, Modding, Patching, Hacking And More !
http://www.akshayy.com/sonyericsson/
28-06-2007, 09:27 PM
#5
The sound quality depends on the quality of the cable used. A low quality cable won't give good sound. But if the cable is of good quality or, as in some cases, is the one provided with the headphones, the loss will be negligible.
28-06-2007, 10:21 PM
#6
dude i won philips headphones and it totally rocks in terms of music and gaming. But u cant compare these two products coz they r meant for diff use.
Study= Don't fail .......eq (1)
Don't study= Fail......eq(2)
eq 1+2
study+ don't study= Don't fail+ Fail
study(1+don't)=Fail(1+don't)
STUDY=FAIL
29-06-2007, 04:18 PM
#7
Different use? They're both for music. What different use could someone make of a headphone besides listening to music?
29-06-2007, 04:32 PM
#8
@ krazyforg i dont want to use ne extsion cable
the problem is i wont be able to connect EP 630 directly to my SE k550i !!!
so i will hv to use that fastport to 3.5mm cable ne way !!
if thr is other method please suggest....
now this is deciding factor....coz if i get hpm 75 or better for 1.5k then i will buy this instead of EP 630 coz of Connectivity Issues...!! damn Sony Ericsson for this
29-06-2007, 05:43 PM
#9
The Thread Killer >:)
I want to buy a Creative earphone for my Creative MuVo. I'll check this out and if there are any other alternatives in Creative itself. Do you guys know any?
Want to make this world a better place? Then, start seeding and don't be just a leecher
29-06-2007, 07:56 PM
#10
SE doesn't have any wired audio adaptors but it has a wireless one. Its called MBR-100. Its a small, A2DP enabled accessory which you connect to your phone wirelessly and then connect your headphones to it. Its a bit expensive way compared to wired adaptors but is much more convenient. Its just the size of a cigarette lighter. Only thing is that its only for music and not for calls. If you can afford it, then go for it. Here check it out: http://www.sonyericsson.com/spg.jsp?...e=pp&pid=10795
In Creative you can go for Zen Aurvana. There are also loads of options available from Sony. Check then out at www.sonyindia.co.in. Then of course there are the bigger brands like Sennheiser, etc.
Reason: Automerged Doublepost
29-06-2007, 08:10 PM
#11
krazyforg plzz plzz suggest cheaper method.....
damn it man i saw the price in a british webiste HPM 75 cost £29.99 that is 2.5k INR
hey how abt getting a cheaper such device may be frm NOKIA or some other bluetooth device and connecting to it ??
i would love to hv a smaller cable and or a nice fastport 3.5mm converter...
ok if i get a duplicate HPM 70 and use EP 630 i hope its fine
i hv no problems with long cable as long as quality is not comprimised ...that's all
or else i willl try to get original HPM 70 second hand cable...sum1 might sell it na
29-06-2007, 08:13 PM
#12
Senior Owner :P
I'm stuck at a shopping cart, it says 100% free, but i don't see any buy button
29-06-2007, 10:52 PM
#13
I think you should just go for original HPM-70 and use it instead of EP-630. Won't be much of a difference and cable length will also be manageable. HPM-70 sounds very good and will be more than enough for your K550i.
30-06-2007, 06:01 PM
#14
means ?? i dint get u yaar............i will be happy if you are saying EP 630 cable will be mangable
any way before buying i will check out my friends HPM 70 and use his cable to check out EP 630 in the shop and then decide..........i willl later let u know then....means while damn it !! i hv VTU exams
30-06-2007, 07:00 PM
#15
I have Yolks not Brains!
from where can i buy this in Bangalore?
I am the egg man
They are the egg men.
I am the walrus... goo goo g’joob
30-06-2007, 08:26 PM
#16
buddy eggman i am thinking of buying this after VTU exams that is after 20th
lets meet and buy together may be we might get discount if we buy 2 at a time
like we will ask the price for 1 bargain it....later say we buy 2 and ask for sum more lil discount.....also i will try to get more of frnds to buy this coz more ppl more discount too...now currenty i am the only guy thinking of it...not sure coz of compatibilty issues
tell me with what are u going to use this beauty ??
also i dont know where in bangalore but i certainly will find
btw i live in hanumanth nagar..near basavangudi
30-06-2007, 09:15 PM
#17
spice it up
hey anyone here knows how much does this great piece of earphone cost in mumbai n from where....
i'd luv to get it asap
30-06-2007, 09:48 PM
#18
The Sexy Beast
me toooooooo in mumbai
plz visit this post.help me upgrade
http://www.thinkdigit.com/forum/showpost.php?p=887835&postcount=3713
30-06-2007, 10:02 PM
#19
Wandering in time...
^^My friend got one for me from mumbai for 1000 bucks from alfa...
Its a very popular shop...
Integrate Yourself With The Latest Happenings.....
www.ankur-gupta.com/blog
01-07-2007, 10:20 PM
#20
I had asked ages ago in alfa and the shopkeeper told of 900 bucks. Must have dropped down to 800 by now.
01-07-2007, 10:29 PM
#21
Guys.. Check out the comments there in techtree..!! The review is an entire rip-off from the Trusted Reviews website...!
http://www.trustedreviews.com/multim...-Headphones/p1
Lol.... such a foolish plagiarism..
07-07-2007, 03:49 AM
#23
Turn The Page
Location: The name of the place where I live is too big to fit in this place, so I am not mentioning it !!!
I want to buy this earphone, but i need to know where in mumbai i can get them at a price lower than rs.1050/-
This Space Has Been "RESERVED" !!!
07-07-2007, 08:52 AM
#24
Still Shining!
Can anybody tell where is it available for shopping online in India?
Its not available here in Bhubaneswar
http://rejuvenating-dreamz.blogspot.com/
07-07-2007, 10:34 AM
#25
Is this available in white in Nehru Place?
07-07-2007, 10:41 AM
#26
Stay Silent!
^^ Yup read that. Looks like the only thing they changed is changing the London underground to Mumbai's local trains.
gud one
btw, wht abt the deafness issues? do they actually make u go deaf? how much is too much? can i have sm authenticate report with links pls, i dont want my folks to scream me whn i use the Pod
I saw me running,
'Twas a long, long run.
But the view was so stunning,
And that made it so much fun... ©
07-07-2007, 07:13 PM
#27
goin deaf and other ear problmes !! me too i want to know more about is !!
yeah even with my current crap earphones the bass is pain in my ears after a few minutes
07-07-2007, 09:48 PM
#28
Stay Silent!
... n the earphones tht came with my shuffle feel funny when i put thm in my ears--- i feel God didnt construct my ears properly or smthing  (
I saw me running,
07-07-2007, 10:38 PM
#29
feel funny ?? means ?? they dont sit properly in your ears or something ??
hey i did some google search on hearing loss due to Headphones not much results man....damn it
but i now 1 fact hearing music at loudnoise is danger 100 % sure
so listening to music in traffic or at market or in a noisy class room means death is certain for ur ears !!
now i am getting a feeling these earphones sit just next to your eardrums !! and if they make noise i dont know what !! am gettin afraid
and during beats (bass) sound level goes up dangerously man i found out......
u listen to cascada......or bass lovers united....the beats man its pain if listened for 30 mins on my k550i.......but cascada is simply cool  and i can't resist to listening to them on my phone
http://www.headwize.com/articles/hearing_art.htm
08-07-2007, 09:14 AM
#30
Stay Silent!
feel funny means they dont sit properly in my ears...
n i basically listen to my pod befre sleeping, the slow songs sound amazing on low volume, and the rock ones dont need to b heard on very high volume,,,....
I saw me running,
Search this Thread |
Upcoming Events
