Go Back   Digit's Technology Discussion Forum > The Free World > Open Source Software
Open Source Software A place where you can talk to like-minded people about the fastest growing software movement today!
Thread Tools Search this Thread Display Modes
  #1
Old 20-05-2007, 03:38 PM
amitava82's Avatar
amitava82 amitava82 is offline
Send a message via Yahoo to amitava82 Send a message via Skype™ to amitava82
Default HOWTO: Open Office 2007 .docx file in OpenOffice.org
I often get docx documents from my friends and each time i had to find a PC with office 2007 to convert it to doc file. it was frustrating so here is the solution i found in ubuntu forum to open docx file in ubuntu.
1. First install alien either using synaptic or apt-get.
2. Download the file odf-converter-1.0.0-5.i586.rpm from here. SAve it to your home folder.
3. then execute this command in terminal
alien -ct odf-converter-1.0.0-5.i586.rpm
4. Now extract generated file odf-converter-1.0.0.tgz. Go to the extracted directory using terminal.
5. Copy three files into your OpenOffice.org directories -- note that the usr that you're copying from is a directory that was inside the tgz file.
sudo cp usr/lib/ooo-2.0/program/OdfConverter /usr/lib/openoffice/program/
sudo cp usr/lib/ooo-2.0/share/registry/modules/org/openoffice/TypeDetection/Filter/MOOXFilter_cpp.xcu /usr/lib/openoffice/share/registry/modules/org/openoffice/TypeDetection/Filter/
sudo cp usr/lib/ooo-2.0/share/registry/modules/org/openoffice/TypeDetection/Types/MOOXTypeDetection.xcu /usr/lib/openoffice/share/registry/modules/org/openoffice/TypeDetection/Types/
Now you can open docx file....
Forum Jump
An Open Letter and Invitation to Dell: OpenOffice.org eddie Technology News 3 16-03-2007 09:59 PM
Free Office Word Plug-in for Read/Writing of OpenOffice Documents anandk Reviews 1 24-02-2007 04:50 PM
OpenOffice opens support for Open XML techtronic Technology News 2 05-12-2006 01:59 PM
MS Office/Open Office--File Save Dialogue Box-Modify Varghese Software Q&A 1 08-04-2006 03:25 PM
OpenOffice.org 2.0 Final,The best free office rajat22 Reviews 9 27-10-2005 12:30 AM
Upcoming Events
Thinkdigit
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
