Go Back   Digit's Technology Discussion Forum > Community > Tutorials
Tutorials This section offers tutorials and How to's on just about anything related to computers and IT. Note: All tutorials are courtesy the posters and not verified by Digit
Thread Tools Search this Thread Display Modes
  #1
Old 09-02-2007, 11:59 PM
GeeNeeYes's Avatar
GeeNeeYes GeeNeeYes is offline
powerd ↻ pramod
Send a message via Yahoo to GeeNeeYes
Lightbulb Tips for Opera Browser Users
some great tips for Opera !!
first some keyboard shortcuts:
» press Shift + I to toggle image display !!
» press Shift + G to toggle display modes
» press / or . (period) to activate webpage inline word find
» press F8 to focus the address bar field (also Ctrl + L)
» press h or F2 to pull down the address bar menu
» press + or - to zoom in or out the webpage
» press Z to go back or press Alt + Z to show backward history
» press X to go forward or press Alt + X to show forward history
» press Ctrl + H to hide Opera in the system tray
» press Ctrl + T to open a new tab
» press Ctrl + W to close the current tab
» press Ctrl + Z to open the last closed tab
» press Ctrl + B to paste a link into address bar and GO
» press Ctrl + 7 to open the Notes panel
» press Ctrl + E to compose a email
ofcourse there are many more such life-saving combos but i listed only 15
__________________________________________________ _______________
now for some tricks with the mouse:
» Press Shift while clicking to open a link or bookmark in a new tab.
» Press Shift + Ctrl while clicking on a link and the new tab will open in the background instead of popping up on top of your current tab.
» Double-click a word to select then word.
» Triple-click to select the full sentence.
» Click four times to select the entire paragraph.
» Pressing Ctrl on your keyboard while rolling the wheel on your mouse activates zooming.
» To go to previous page ::
press & hold right button, click left button OR
hold right button, move mouse left (mouse gestures).
» To go to next page ::
press & hold left button, click right button OR
hold right button, move mouse right (mouse gestures).
» Right-click any tab to select from a plethora of options.
» Select Duplicate from the tab context-menu to create a duplicate tab of any website.
» Select Lock Tab from the tab context-menu to lock the tab and prevent accidental closure of the webpage.
» Select Detach from the tab context-menu to detach the tab to open the webpage in another window.
Create Custom Search for websites in Opera
Now You can create search for Your Favourite Websites...
and search easily by just typing your query in OPERA
Example: Creating Search for <Orkut>
» Notice the search option in Orkut at the top right of the browser screen.
» Right-click the search box.
» Select the Create Search.. option
» In the dialog box that popups, fill in details like Name (anything), keyword (enter any characters like o for orkut)
I have created Search Engines for many websites like Wikipedia, del.icio.us, Yahoo, Orkut, Digg, etc.
Thats it! you are done..
You have successfully created a search engine for your favourite website..
and integrated it into Opera! Cheers!
Custom Buttons to Drag'n'Drop into your Opera
Opera allows you to easily drag-n-drop custom buttons from a web page straight onto your toolbars!
Buttons can be simple browser functions or options easy to use or advanced features or even additional external functionality for automated actions.
Buttons like "Tag this on del.icio.us" or "Post to Digit" or "Blog this" can be very easily made..
How to add a button - Simply drag a link (Button) to your toolbar and try it out (hint:drag upwards). A requestor will pop up asking whether to install the button (displaying the command the button performs to confirm 'what-it-says-is-what-it-does').
How to remove a button - If you don't like a button, you can simply right-click on it and "remove from toolbar".
Where to place buttons - The Personal bar and Menu bar do not allow buttons to be added to them, but Status bar, Main bar, Navigation bar, Address bar, the ends of the Page bar, most Panel toolbars and the Mail View bars are all fine.
Where to get these buttons -
http://operawiki.info/CustomButtons
http://operawiki.info/PowerButtons
http://www.aimwell.org/Help/Buttons/buttons.html
http://homepage.hispeed.ch/ttt-opera...owser-adv.html
http://people.opera.com/rijk/opera/dndbuttons.html
Kill Elements Button
KILL Elements - REMOVE ADS, IMAGES, FLASH, FRAMES, BLOCKS, TABLES, ETC.
The kill button is utterly invaluable. It basically can kill elements on a page. The selected element will be highlighted with a pink square, if so this means left-clicking it will remove that element from a page. Press escape or Click kill button again to exit the kill mode.
This button is useful for things like:
» Removing those annoying DHTML images that float around a page.
» Any element that distorts the page, such as overflowing ad-blocks or long entries in tables.
» Removing elements you don't want shown on a printed page.
» You may even remove flash or iframes; you have to select a parent that is holding it, hover the mouse close to the edge of the flash animation and see if you can see its parent highlighted.
Feeling a sense of omnipotence (a-la Pacman)...
BUTTONS : Kill Using the Mark as Spam icon / Kill Using the Smiley Pacman icon.
Note: You must drag the button up from the page to the toolbar, not click it and add it or it won't work. You will see icon if done right.
Visit this website page: http://operawiki.info/PowerButtons#kill
Remove Google Ads (also in Orkut Communities) using Opera
» Right Click & select Block Content
» Click Details button in the yellow toolbar for Content Blocker
» Now click Add... button in dialog box
» Add this sites:
http://*orkut.com/AdsIframe.aspx*
http://*adwords*
http://*pagead2*
http://*adbrite*
Digit member # 17000
www.geeneeyes.coz.in
http://feeds.feedburner.com/tech-alert
www.geeneeyes.blogspot.com
www.opera.com/products/desktop/
  #2
Old 10-02-2007, 09:16 AM
nishant_nms's Avatar
nishant_nms nishant_nms is offline
Default Re: Tips for Opera Browser Users
nice post
  #3
Old 10-02-2007, 11:49 AM
forever's Avatar
forever forever is offline
filth is me
this is 1 damn good post , gr8 job.
  #4
Old 10-02-2007, 12:19 PM
Pathik's Avatar
Pathik Pathik is offline
Google Bot
nice tips...
  #5
Old 10-02-2007, 12:24 PM
blackpearl's Avatar
blackpearl blackpearl is offline
The Devil
You made my day!!
• www.instantfundas.com --> Computers - Internet - Blogging
  #6
Old 10-02-2007, 02:37 PM
ManiDhillon's Avatar
ManiDhillon ManiDhillon is offline
I believe in you!!
Send a message via Yahoo to ManiDhillon Send a message via Skype™ to ManiDhillon
Hey thanks bro. Good Tips!
Thinkpad 600E
PII 300MHz, 192MB RAM, 6 GB HDD
  #7
Old 10-02-2007, 03:09 PM
ismart ismart is offline
Very useful, thanks!
  #8
Old 10-02-2007, 06:38 PM
champ_rock's Avatar
champ_rock champ_rock is offline
champ_rock
Send a message via Yahoo to champ_rock
was always LOOKING for the search function that was similar to firefox.. thanks a lot for that "/" trick
Registered Linux user number 400618
  #9
Old 10-02-2007, 06:39 PM
Tech Geek's Avatar
Tech Geek Tech Geek is offline
Send a message via Yahoo to Tech Geek
Thanks
  #10
Old 10-02-2007, 08:48 PM
redhat's Avatar
redhat redhat is offline
Mad and Furious
Send a message via MSN to redhat Send a message via Yahoo to redhat
Nice One,
Thanks Dude, Repped you
My new Tech Blog : http://technewspaper.blogspot.com/
  #11
Old 11-02-2007, 03:23 AM
sauravktr's Avatar
sauravktr sauravktr is offline
Thanks Buddy.Very good post.Really helpful tips
  #12
Old 11-02-2007, 12:25 PM
hemant_mathur's Avatar
hemant_mathur hemant_mathur is offline
-- No Easter Eggs here --
Great tips .. thanx
E6850 3.0 Ghz, 4gb 667 Mhz RAM, Asus p5n Esli Mobo, Nvidia 8600GT 512mb, 400gb WD HDD, Samsung Syncmaster 920NW, Vista x64
  #13
Old 11-02-2007, 12:35 PM
n2casey's Avatar
n2casey n2casey is offline
Super Hero - Super Powers
Send a message via MSN to n2casey
Nice post friend. Repu for u.
Minds are like Parachutes They work best when open
  #14
Old 11-02-2007, 10:16 PM
GeeNeeYes's Avatar
powerd ↻ pramod
Thank you so much everybody
i love Opera (just my two cents)
This was the least I could do towards paying back all Digitians!!!
10Q once again for appreciating
  #15
Old 11-02-2007, 10:39 PM
s18000rpm's Avatar
s18000rpm s18000rpm is offline
On a time-out
^^thanks for the Tips dude
  #16
Old 11-02-2007, 10:57 PM
Arsenal_Gunners's Avatar
Arsenal_Gunners Arsenal_Gunners is offline
&gt;:X
Best tip:Use firefox
Nice tips dude
  #17
Old 12-02-2007, 12:09 AM
ashnik ashnik is offline
thanks
  #18
Old 12-02-2007, 01:51 PM
anilmail17's Avatar
anilmail17 anilmail17 is offline
Send a message via Yahoo to anilmail17
ulti tips yaar
Repped you
visit my blog
www.anilsoni.wordpress.com
  #19
Old 12-02-2007, 03:59 PM
forever's Avatar
filth is me
what a smart statement that is (pun intended).
  #20
Old 19-03-2007, 10:53 PM
jatt's Avatar
jatt jatt is offline
Send a message via Yahoo to jatt
thanks but how to save page in opera on mobile please tell me any one
any way good tips thanks
ਨੋ ਗਰਲ ਫਰੈਂਡ ਨੋ ਟੈਂਨਸ਼ਨ,no girlfriend no tension,website: Punjabi.c-o.in,forum: punjabiteacher.co.cc
Forum Jump
Upcoming Events
Thinkdigit
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
