Hello frenz...
This tutorial might be familiar to you.. but, its funny to do..
First download the zip file below and extract the ppt file.. double click it...
you_are_a_fool.zip
After having a glance at the above ppt, you'll now have a clear idea. If you wanna fool your friend or make him agree that he is a fool.. just follow these steps...
1. Open
Powerpoint, Make a
new presentation.
2. Set any image as background if necessary. You can do like this..
Right click on the slide area, and select
Background
In the dropdown box, select
Fill Effects. Go to
Picture tab and select the desired image you want. Dont forget to click
Apply to all.
3. Now, Create two action buttons. Make sure you have
Drawing Toolbar checked in
View -> Toolbars. If not, Select it.
Now, Click on
AutoShapes in
Drawing toolbar, select
Action Buttons and Click on the first one. Now, draw it.
Add the desired text by Right Clicking on the button and select
Edit Text. Create the slide that exactly looks like the above pic.
4. HyperLink
Right click on the
Action button and select
Hyperlink
Navigate to
Mouse Over tab. Select
Next Slide under
Hyperlink to : as shown in the pic below.
If you RightClick on the action button in the edit text mode, then you may see the pic below which is not the desired one..
Now,
Right click on the
YES Action button and Select
Last Slide instead of Next slide in the similar way shown above...
now,
copy the slide and make several duplicates of it. Move the No button to different positions randomly in all slides.
5. Create a loop
Now, in the
last slide,
Right Click on the
Action button, select
Edit Hyperlink and select
Slide... and click on
Slide1. Now, we have created a logical loop on the slides.
6. The last slide
Create the last slide as the below pic..
7. Disable the "Advance Slide" on click
Go to
Slide Show ->
Slide Transition. In the Right pane, Under
Advance Slide,
Uncheck the option
On Mouse Click. Click
Apply to all slides.
Now, Press
F5 or
slide show and verify whether you are able to catch the NO action button.
PS: You might be having several innovative ideas that can be implemented using this trick... Please post them if you have any...
