Go Back   Digit's Technology Discussion Forum > Community > Tutorials
Tutorials This section offers tutorials and How to's on just about anything related to computers and IT. Note: All tutorials are courtesy the posters and not verified by Digit
Thread Tools Search this Thread Display Modes
  #1
Old 26-01-2007, 06:09 PM
sridatta's Avatar
sridatta sridatta is offline
An Esoteric Geek
Send a message via Yahoo to sridatta
Default Tutorial: How to Create Command-Line Shortcuts for frequently Accessed folders/files
Hello guyz,
This is a beautiful trick for those who want to prevent their brother/friend from accessing a folder which they often use.Hiding the folder and removing the folder options from the explorer can do this. But, it is annoying to unhide everytime whenever you want to access the folder. Alternate way is to type the full path in windows explorer address bar. This is irksome. So, we can create a shortcut and use command prompt to access the folder. Follow these steps.
Right Click on the Desktop and select New--> ShortCut
In the window, Type the path of the folder in the textbox. suppose say C:\WINDOWS
name the shortcut as something you desired. Suppose i name it as win.
Now, the shortcut is Created for your desired folder. Now, we should access this shortcut through command line. Hence, Copy the shortcut file in c:\windows\system32 directory.
Now, you are done.
Start->Run
Type the name of the shortcut that you saved before and press enter. Now,You will be able to view the contents of the folder.
How to Create Command Line Shortcuts for Control Panel, My Computer and more using the GUIDs :
Create a new shortcut and enter the following in the textbox
explorer ::{21EC2020-3AEA-1069-A2DD-08002B30309D}
name it as cpanel.
Now, copy this to system32 folder. Now, you can just open control panel by typing cpanel from run window.
list of GUIDs:
Control Panel
Internet Explorer
{FBF23B42-E3F0-101B-8488-00AA003E56F8}
My Documents
{ECF03A32-103D-11d2-854D-006008059367}
Fonts
{BD84B380-8CA2-1069-AB1D-08000948F534}
My Computer
{20D04FE0-3AEA-1069-A2D8-08002B30309D}
My Network Places
{208D2C60-3AEA-1069-A2D7-08002B30309D}
Network Connections
{7007ACC7-3202-11D1-AAD2-00805FC1270E}
Printers and Faxes
{2227A280-3AEA-1069-A2DE-08002B30309D}
Recycle Bin
{645FF040-5081-101B-9F08-00AA002F954E}
Scheduled Tasks
{D6277990-4C6A-11CF-8D87-00AA0060F5BF}
For more GUIDs, refer to this thread
http://www.thinkdigit.com/forum/showthread.php?t=47494
Optional Steps for Hiding the folders:
1. First hide the folder by rightclick --> Properties and select hidden attribute.
2. Remove Folder Options either by Registry or Group Policy
Registry Key:
Navigate to HKCU\Software\Microsoft\Windows\CurrentVersion\Pol icies\Explorer\
Create a DWORD named NoFolderOptions with value 1.
Group Policy:
Navigate to User Configuration\Administrative Templates\Windows Components\Windows Explorer
Disable the folder options by enabling the following setting.
Remove the folder options menu from the tools options.
--------------------------------------END-------------------------------
PS: Please post the comments if any
  #2
Old 26-01-2007, 06:41 PM
Tech Geek's Avatar
Tech Geek Tech Geek is offline
Send a message via Yahoo to Tech Geek
Default Re: Tutorial: How to Create Command-Line Shortcuts for frequently Accessed folders/files
nice tut
  #3
Old 29-01-2007, 04:21 PM
Chetan1991's Avatar
Chetan1991 Chetan1991 is offline
Really good!!
especially the codes are helping!
repute me if u like my rep
  #4
Old 29-01-2007, 04:28 PM
koolbluez's Avatar
koolbluez koolbluez is offline
Šupər♂ - 超人
Send a message via Yahoo to koolbluez
Good one.. although old.
One point to correct. These shortcuts can be directly placed into the Windows directory instead of Windows/System32 directory.
Been doin it for all my major programs. I even have my restart, logoff & shutdown buttons in the windows folder.
Restart shortcut: %windir%\system32\shutdown.exe -r -t 00
Logoff shortcut: %windir%\system32\shutdown.exe -l -t 00
Shutdown shortcut: %windir%\system32\shutdown.exe -s -t 00
One more addition though, some of the more famous software already start from the run prompt itself... all Microsoft programs like calc... , Photoshop, firefox, winrar.
There is also a registry hack for the same.
  #5
Old 29-01-2007, 04:37 PM
sridatta's Avatar
An Esoteric Geek
Thanks for the compliments...
@koolbluez.. Thanks for adding this additional info into this thread..
  #6
Old 30-01-2007, 08:09 PM
Ron's Avatar
Ron Ron is offline
||uLtiMaTE WinNER||
Send a message via MSN to Ron
Smile Re: Tutorial: How to Create Command-Line Shortcuts for frequently Accessed folders/fi
Gr8 Post.....
Launch Any Program Directly from Start>RUN
Navigate To
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\Curr entVersion\App Paths
Now create a new key of program you want to launch, for example ResHack.exe
Now in its Default String Value paste the path
C:\Program Files\reshack\reshack.exe
View This Thread To Secure Your Data
http://www.thinkdigit.com/forum/showthread.php?t=45998
||uLtiMaTE WinNER||
Forum Jump
Upcoming Events
Thinkdigit
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
