Go Back   Digit's Technology Discussion Forum > Community > Tutorials
Tutorials This section offers tutorials and How to's on just about anything related to computers and IT. Note: All tutorials are courtesy the posters and not verified by Digit
Thread Tools Search this Thread Display Modes
  #1
Old 14-01-2007, 01:36 PM
sridatta's Avatar
sridatta sridatta is offline
An Esoteric Geek
Send a message via Yahoo to sridatta
Default Tutorial : How to connect to Internet on your Mobile using Broadband
Sony Ericsson Users can now access all internet services free of cost using your Broadband connection.
My model Sony Ericsson w700i must use TCP/IP for its data connection. I thought why not make a TCP/IP connection to my local area LAN and surf the Internet through my broadband? The first thing i can do is to ask google. I have found some forums talking about this and a perfect procedure was found in the above URL.
I would like to credit the whole thing to the creator Andre
Source : http://users.skynet.be/yozy/tutorials/
Required Things:
1. Sony Ericsson Compatible Model
MIDP 1.0 and CLDC 1.04:
- P800 series
- T610 series
- T630 series
- Z600 series
MIDP 2.0 and CLDC 1.0 HI:
- P900/P910 series
MIDP 2.0 and CLDC 1.1:
- S700/S710 series
- V800
- F500i
- J300 series
- K300 series
- K310 series
- K500 series
- K510 series
- K600 series
- K610 series (Java Platform 7)
- K700 series
- K790 series (Java Platform 7)
- K750 series
- K800 series (Java Platform 7)
- P900
- P910
- P990
- M600
- W300 series
- W550 series
- W600 series
- W700 series
- W710 series (Java Platform 7)
- W800 series
- W810 series
- W850 series (Java Platform 7)
- W900 series
- W950 series
- Z520 series
- Z530 series
- Z550 series
- Z710 series (Java Platform 7)
- Z800 series
- Z525
- Z500a
- Z1010
2. Necessary Software
1. The J2SE Software Development Kit (SDK)
Mirror site : JAVA SDK
2. Sony Ericsson SDK
3. Opera Mini : Best way is to download the compatible version for your mobile from Opera Official site.
Step wise procedure:
1. First install JAVA JDK and then SONY ERICSSON SDK. Downloading these two things would be a little problem but cant help...
2. Connect your mobile to PC via bluetooth or USB.
2. When the Sonyericsson SDK installed successfully, you should find a Connection Proxy icon on your system tray, otherwise Click Start > Programs > Sony Ericsson > J2ME SDK > ConnectionProxy to start the connection proxy which while active will show its status on the system tray.
3. Click on Settings icon (Gear). Select correct COM port for your connection. Choosing correct COM port would not be a big task. Open your device manager and you will find the com ports for your mobile USB/Bluetooth connection. Choose the lowest COM port apart from the COM ports that are attached to your system. Choose the BaudRate as 115200.
4. Now click Connect. You should see your mobile pic on the connection proxy saying that it is connected. ( see the source URL for sample Pic)
5. Open Sony Ericsson Device Explorer.
Click Start > Program > Sony Ericsson > J2ME SDK > Device Explorer. You should see that the software is negotiating a connection with your mobile, and when successful, it will display a list of applications installed. In my case it displayed all the games installed in my W700 games folder.
Important Note : If anyone faces error at this particular step saying "Malformed Response...... .... " then it is due to some error in parsing the characters in the installed games. Delete games one by one in your games folder and Refresh the Device Explorer. It should work at some time..
6. In Sony Ericsson Device Explorer menu bar, click File and check Serial Networking and restart the Device Explorer. WIth this, the settings on the system is completed.
7. On your Sony Ericsson mobile, create a new data account.
For that, Go to Connectivity > Data comm. > Data accounts > New account.
Account type: GPRS data
Name: Anything you want. Leave APN, Username and Password empty.
8. Go to Connectivity > Internet setting > Internet profiles > New profile
Name: anything you want
Connect using: select the account you just added in the above step
9. Still in Internet profiles window, highlight the profile you going to use and press More and select Settings.
In this window:
Connect using: the new data account you just added
Internet Mode: Http (already there)
Use Proxy: No
Username and Password: empty
Press Save to save this profile
Note: For broadband users under Corporate LAN, The settings are different. Use this profile settings.
here.. Note the following...
My IP address in LAN : 172.16.5.111
DNS Address : 172.24.2.71
Proxy server Address : 172.30.3.3
create a data account named "broadband"
ip address : 172.16.5.111
dns address : 172.24.2.71
create an internet profile named " broadband"
internet mode : http
use proxy : yes
proxy address: 172.30.3.3
port : 8080
streaming settings :
connect using : broadband
use proxy : yes
proxy address: 172.16.5.111
port number : 6082
10. Opera Mini Installation
Default browser that comes with sony ericsson mobile just not mean to be used with this type of connection. You need to download other browser to be installed. Download the compatible version of opera for your model from its official site. You must download both jar and jad files. This is a quick download since the file is quite small. Now you can install Opera Mini browser by just rightclicking the JAD File you just downloaded and select "Install on Device".
When installation is successful, highlight the Opera Mini in the Device Explorer and click on "Play button", or right click and select Start to launch the Opera Mini on your mobile.
Note : Launching Opera Mini by using the phone itself will not work.
11. Now, If you are using Opera 3.0, it tests for network connection before opening the browser. If the connection test fails, check your settings once again. Restart your phone and try again. If everything is correct, i would suggest you to download opera mini 2.0. and proceed with the same steps above. Search google or download it from here ( Copy it to your phone and install from the phone since i cannot upload a jad file in my hosting site.)
12. Enter any URL in your mobile and you are done if you are able to see that site on your mobile..
Note: Please do not expect that you will be succeeded in the first trial. There is every possiblity that you may miss small things. I have spent one complete day for the connection and then succeded.
Some Points to note :
1. Make sure "Serial Networking" is checked in device explorer.
2. Connection proxy is connected
3. Device explorer shows all the applications(games) installed on your mobile. If not, try restarting your device explorer.
4. If every setting is correct and still you are not able to connect to internet, restart your mobile
5. Use Opera mini 2.0 Advanced instead of latest version if you are not able to connect using it.
Finally... Please post your results in this thread so that people facing problems can troubleshoot...
  #2
Old 14-01-2007, 01:42 PM
ashisharya's Avatar
ashisharya ashisharya is offline
Send a message via MSN to ashisharya Send a message via Yahoo to ashisharya
Default Re: Tutorial : How to connect to Internet on your Mobile using Broadband
nice one
To follow the path:
look to the master,
follow the master,
walk with the master,
see through the master,
become the master. -Zen
  #3
Old 14-01-2007, 03:27 PM
therockerz therockerz is offline
well.. y need all these.. when N90 and otehr new fones .. got WLAN support :S?
Visit ~~~www.pyr3x.com~~~ A new torrent site
  #4
Old 14-01-2007, 03:28 PM
Pathik's Avatar
Pathik Pathik is offline
Google Bot
good one..
  #5
Old 14-01-2007, 04:02 PM
sridatta's Avatar
An Esoteric Geek
@therockerz : Yeah.. this seem to be hectic but very useful. Not all mobiles have WLAN support. Not all ppl can buy such expensive phones like N90. Its a good addon to all feature rich SONY ERICSSON phones.
  #6
Old 14-01-2007, 11:12 PM
tintin100's Avatar
tintin100 tintin100 is offline
Good tutorial, but why would a people connect to the internet through the mobile while he is in front of his PC????
One of my friend did this, and now everyone calls him mad.
Just Came here to see what is happening on Digit Forum...
  #7
Old 15-01-2007, 04:11 AM
anilmail17's Avatar
anilmail17 anilmail17 is offline
Send a message via Yahoo to anilmail17
hmm really nice tut. thanx buddy
visit my blog
www.anilsoni.wordpress.com
  #8
Old 15-01-2007, 04:39 AM
NIGHTMARE's Avatar
NIGHTMARE NIGHTMARE is offline
DEVIL MAY CRY
Send a message via Yahoo to NIGHTMARE
Post Re: Tutorial : How to connect to Internet on your Mobile using Broadband
i am using nokia 9500 can u tell me setting for my mobile
C2D E6600@3.4\ ASUS P5W DH DELUXE \CORSAIR 800MHZ 3GB
Sapphire 4850 Dual Slot cooler\19 INCH FLAT CRT SAMSUNG\SAMSUNG DVD WRITER\1.5 TB STORAGE\ZEBRONIC CAB 500 PSU\LOGITECH KEYBOAD & MICE\Sony Hi-Fi
  #9
Old 15-01-2007, 01:47 PM
sridatta's Avatar
An Esoteric Geek
@NIGHTMARE : This method uses Sony Ericsson SDK, so its only for SE mobiles. You cannot connect NOKIA mobile this way..
@tintin100 : There are several hidden features.
1. You can access wap sites through your mobile.
2. In corporate offices with content based firewalls, this method provides anonymity to the users.
  #10
Old 15-01-2007, 05:38 PM
NIGHTMARE's Avatar
DEVIL MAY CRY
Smile Re: Tutorial : How to connect to Internet on your Mobile using Broadband
Ok Fine Using Bsnl Gprs Free Of Cost But Some Site R Not Open
Thanks
  #11
Old 16-02-2007, 03:11 PM
ruturaj3's Avatar
ruturaj3 ruturaj3 is offline
Hi i want to use my mtnl dsl internet on my SE k790i. I have try out all the above settings.Still it is nit working. And one more thing In Data accounts it doesn't ask for GPRS data instead of this ; it ask for PS data OR CS data.
Tell me which 1 to select.
  #12
Old 16-02-2007, 03:14 PM
Tech Geek's Avatar
Tech Geek Tech Geek is offline
Send a message via Yahoo to Tech Geek
Nice one
  #13
Old 16-02-2007, 06:16 PM
sridatta's Avatar
An Esoteric Geek
@Ruturaj : I have no idea of that phone.. I'll let u know about this soon..
  #14
Old 26-02-2007, 08:41 PM
max_demon's Avatar
max_demon max_demon is offline
PSN : godofwarmax
Send a message via MSN to max_demon Send a message via Yahoo to max_demon
Guyz imn my k750 i i cannot access any site . i m using UL900 is that really working for other k750i users.HELP please . i do dictto as u write that thing.
STILL FAILS
When someone dies in the grip of a powerful rage... a curse is born.
Kayako Saeki: Croakkkkkkkkkkkkkkkkkkkkk!
  #15
Old 12-03-2007, 02:01 AM
Super Super is offline
Hi,
First, thanks for posting such a detailed instruction guide. Now for my problem:
1. I get stuck on step 7. Where it asks for Account type it only gives me the option of either: PS or PC, there is No GRPS option.
2. I picked the PS option instead of GRPS and followed the steps to the end. When I started Opera it looks for a connection and freezes the search at 25%.
What shoud I do next? Please help!!
  #16
Old 15-03-2007, 03:31 PM
max_demon's Avatar
PSN : godofwarmax
UPDATE : after step 9 If oprea is not working under Connectivity > settings for java , Select the new profile u created(very important step)
  #17
Old 17-03-2007, 07:01 PM
Josan's Avatar
Josan Josan is offline
Gangsta
Location: I come from the land of WARRIORS, land of 5 rivers, where the alcohol will make your liver quiver!!
Send a message via MSN to Josan Send a message via Yahoo to Josan
Thanks
  #18
Old 27-03-2007, 02:02 AM
kin.vachhani's Avatar
kin.vachhani kin.vachhani is offline
Dreaming Future
Send a message via Yahoo to kin.vachhani Send a message via Skype™ to kin.vachhani
hey dude wht abt N SERIES OF NOKIA
World without Computer is like a man without Brain.....
  #19
Old 03-03-2008, 09:52 PM
superuser superuser is offline
ya man what about N73
  #20
Old 03-03-2008, 09:59 PM
ring_wraith's Avatar
ring_wraith ring_wraith is offline
=--=l33t=--=
Nice, but the whole point of having internet on your mobile is mobility, I would rather surf net on my PC if i'm close to it.
Homer: God bless those pagans.
  #21
Old 03-03-2008, 10:01 PM
Gigacore's Avatar
Gigacore Gigacore is offline
Dreamweaver
wat a bump.. please mention the bump superuser
Forum Jump
Upcoming Events
Thinkdigit
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
