LAPTOP within Rs50,000
I would like you to name the Laptop you would buy...If your buget is within Rs.50,000. Please mention the model.. if possible features etc..
Compaq Presario V3029AU Notebook PC (RD574PA)
Processor type AMD Turion™ 64 Processor TL-50
1.60 GHz, Level 2 cache 256 KB + 256 KB
Operating system installed FreeDOS
Standard memory 512 MB
Memory type DDR2 533 MHz
Memory layout (1 x 512 MB)
Maximum memory Up to 2 GB DDR2 memory
Internal drives
Internal hard disk drive 80 GB
Hard disk drive speed 5400 rpm
Optical drive type Super Multi DVD Writer (+/-R +/-RW) with Double Layer support
System features
Modem High speed 56K modem
Network interface 10/100 LAN Ethernet integrated
External I/O ports 1 VGA, 3 USB 2.0 ports, 1 IEEE-1394, 1 RJ-11, 1 RJ -45, S-video TV out, 1 headphone-out, 1 microphone-in, 1 Expansion Port 3 connector, AC Adapter, 2 Omni - directional microphones
Expansion slots One ExpressCard/54 slot (also supports ExpressCard/34)
Display size 14.1” WXGA High Definition BrightView Widescreen Display
Display resolution 1280 x 800
Video adapter NVIDIA® GeForce™ Go 6150
Speakers and microphone Altec Lansing® speakers, Dual omni-directional microphones
Keyboard Full-sized Keyboard
Weight 2.4 kg (5.31 lbs)
Dimensions (W x D x H) 23.7 cm (W) x 33.4 cm (L) x 2.6 cm - 3.9 cm (H)
Thanks..
