Go Back   Digit's Technology Discussion Forum > Across The Board > Software Troubleshooting
Software Troubleshooting Issues related with your OS, applications, system security, configuration of network, browsers, customizations, driver support, tweaking, audio-video playback problems and programming can be discussed here.
Thread Tools Search this Thread Display Modes
Old 01-02-2009, 11:05 PM   #1
x3060
A LOTR fan
x3060's Avatar
Question Windows Media player not getting closed
hi,
the problem that am facing with the windows media player is that its not getting closed even after clicking close.."it runs in background"
obviously , i cant see it ...but can hear the sound of the video or song am playing.
though am not using it for anything , but if i accidentally open it , i will have to kill the process from the task manager...
am using vista x64 SP1. i incidentally i remember having the same problem in vista x32 sp1 too...i guess long long time back.though it may not be correct.
a help is really appreciated.
wonder if anyone has faced this weird problem
How many kilometers are there from washington Dc to Miami beach?????....
unban praka123!!!....
x3060 is offline   Reply With Quote
Old 02-02-2009, 12:30 AM   #2
iMav
The Devil's Advocate
iMav's Avatar
Send a message via MSN to iMav Send a message via Yahoo to iMav Send a message via Skype™ to iMav
Default Re: Windows Media player not getting closed
I've faced this issue before & found that there is a codec that is running in the bg, if it's the same case with you then this behavior shouldn't be with videos of other compression methods.
Also check your taskbar if you can see any codec icon, ffshow or something similar. Try re-installing the codec pack.
http://beingmanan.com
iMav is offline   Reply With Quote
Old 07-02-2009, 01:32 AM   #3
x3060
A LOTR fan
x3060's Avatar
oh yes, its not happening for audio....btw , i don't have any external codec pack installed in my system.
just KMP, Quick time that's all
Old 07-02-2009, 04:11 AM   #4
IronManForever
IronMan; Ready to Roll...
IronManForever's Avatar
^ KMP could very well be the culprit.. happened to me on XP. Though I did not get to the solution as I use task manager a lot.
Aluminum MacBook 2.0GHz Collector's Edition
Windows Box: 2.26G P4, 1GiB RAM, 80GB HDD, Nvidia FX5200
22" AOC Full HD
iPod Touch 16GiB, HTC Gene, Moto W230, Sansa Express
IronManForever is offline   Reply With Quote
Old 07-02-2009, 10:08 AM   #5
jojothedragon
\|/Grey Warden\|/
jojothedragon's Avatar
Send a message via MSN to jojothedragon Send a message via Yahoo to jojothedragon
Try vlc player. What format video you are playing?
jojothedragon is offline   Reply With Quote
Old 09-02-2009, 12:07 AM   #6
gaurarpit
Send a message via Yahoo to gaurarpit Send a message via Skype™ to gaurarpit
Smile Re: Windows Media player not getting closed
It is a bug inside WMP, has happened to me too..
Try reinstalling the codec pack that u use, or i wud recommend u to use any other player for playing multimedia. Personally i have likes for VLC as it plays almost all formats, except a few, For such issues use StormCodes, my favorites.
gaurarpit is offline   Reply With Quote
Forum Jump
playing vob files in windows media player for windows xp nikhil1243 Software Troubleshooting 10 15-07-2007 12:44 PM
play real media (.rm) files in windows media player mneo Tutorials 7 10-07-2007 08:30 PM
Bypass Windows Genuine Validation in Windows Media Player 11 Installation. Gigacore Tutorials 6 01-05-2007 10:55 PM
NEWS: Windows Media Player 11 Update for Windows XP Vishal Gupta Technology News 1 11-11-2006 11:08 PM
Windows Media Player 11 techtronic Software Troubleshooting 2 28-05-2006 08:39 AM
Upcoming Events
Think diget
Powered by vBulletin® Version 3.8.2
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
