Go Back   Digit's Technology Discussion Forum > Community > Tutorials
Tutorials This section offers tutorials and How to's on just about anything related to computers and IT. Note: All tutorials are courtesy the posters and not verified by Digit
Thread Tools Search this Thread Display Modes
  #1
Old 17-10-2008, 12:37 PM
Amir.php's Avatar
Amir.php Amir.php is offline
Lightbulb Run Opera mini on Nokia s40(v2, v3, v5)
This Tutorial i have written for those who have Nokia series 40 mobiles and facing trouble in Using internet based Java Applications on these platform.
Accoring to Nokia:
As we all know, Nokia doesn't allow one to specify a proxy for an Access Point in Series 40 v2 and v3 and v5 phones (6131, 6133, 3110c, 5300, 5200, 5310, 6500) etc.
In its recent versions of the Series40 OS (v2 & v3 & v5), Nokia has removed the ability to specify a proxy server associated with an access point. Therefore, those with WAP network plans (such as TMobileWeb users, Airtel NOP users) are unable to use JAVA programs that require internet access (such as Opera Mini, Google Maps, ...).
However, Nokia does allow users to create a provisioning document on their computer. This document, created in wbxml, specifies an access point along with a proxy. The S40 phone recognizes the configuration settings in the document and allows the JAVA midlet to use those instead, thereby allowing the midlet to access the proxy. Its very simple to implement.
The files included in the zip provide some sample xml documents, and the associated provisioning (.prov) files
Note: Before proceeding please confirm that What version of S40 device you are using. if You are using Nokia s40(v2, v3), then follow the Method on this page.
But for the users of s40 v5 move on My next page By Click Here.
Tutorial Start(s40 v2, v3 only):
From the given links Download a zip file which have various setting file(.prov) and .wml which we will Edit accordingly.
NokiaJAVAProxy.zip
or
NokiaJAVAProxy.zip
But Main problem here How to Edit this wml file according to our service provider.
So Now i am going to tell you, how to do this:
1. Download NokiaJAVAProxy.zip from above url.
2. Download wbxml2-0.9.0-bin.win32.rar & WML Editor for editing wml files.
3. Now After extracting the NokiajAVAProxy.zip, open any of the .wml file on wml editor. It looks like as:
<?xml version="1.0"?>
<!DOCTYPE wap-provisioningdoc PUBLIC "-//WAPFORUM//DTD PROV 1.0//EN"
"http://www.wapforum.org/DTD/prov.dtd">
<wap-provisioningdoc version="1.0">
<!-- This WML doc created by Ravi Mathur, Oct 22 2007 -->
<!-- HowardForums username: ravidavi -->
<characteristic type="BOOTSTRAP">
<!-- Name of the configuration -->
<parm name="NAME" value="Idea JAVA"/>
</characteristic>
<!-- Defines how network access occurs -->
<characteristic type="ACCESS">
<parm name="RULE" value="Default Rule"/>
<!-- Connect through specified proxy -->
<parm name="TO-PROXY" value="IdeaProxy"/>
</characteristic>
<!-- Defines proxy parameters -->
<characteristic type="PXLOGICAL">
<parm name="PROXY-ID" value="IdeaProxy"/>
<parm name="NAME" value="Idea Proxy"/>
<characteristic type="PXPHYSICAL">
<parm name="PHYSICAL-PROXY-ID" value="Idea Proxy"/>
<parm name="PXADDR" value="10.4.42.15"/>
<parm name="PXADDRTYPE" value="IPV4"/>
<parm name="PUSHENABLED" value="0"/>
<characteristic type="PORT">
<parm name="PORTNBR" value="8080"/>
</characteristic>
<!-- Connect through specified access point -->
<parm name="TO-NAPID" value="IdeaNAP"/>
</characteristic>
</characteristic>
<!-- Defines Network Access Point (NAP) parameters -->
<characteristic type="NAPDEF">
<parm name="NAPID" value="IdeaNAP"/>
<parm name="NAME" value="Idea NAP"/>
<parm name="BEARER" value="GSM-GPRS"/>
<parm name="NAP-ADDRESS" value="imis"/>
<parm name="NAP-ADDRTYPE" value="APN"/>
<characteristic type="NAPAUTHINFO">
<!-- PAP is "normal" authentication -->
<parm name="AUTHTYPE" value="PAP"/>
</characteristic>
</characteristic>
</wap-provisioningdoc>
4. Edit acoording to your service provider specification, which i have marked as RED.
you can also edit Your service providers name(optionally, but will be better to edit them also), which i have marked as Green. and Save it.
5. Now Make a folder in any Drive and copy/paste this wml file in this folder.
6. extract and copy/paste wbxml2-0.9.0-bin.win32 folder also in that folder(for your ease only).
7. open wbxml2-0.9.0-bin.win32 and you will see xml2wbxml.exe.
8. To run this file open command window and go your created folder by cd command and run it. It will show how to use it.
for example:
Syntax: xml2wbxl -o output.wbxml input.xml
eg.
xml2wbxml -o C:\Amir\NokiaJAVAProxy.prov C:\Amir
\NokiaJAVAProxy.wml
This will generate a .prov file with name NokiaJAVAProxy.prov in the folder name C:\Amir
9. That's all.
Now you can transfer this .prov file in your mobile using bluetooth or infrared.
Save this setting and make it default from configuration.
Fore more help see these Screen Shots step wise:
Operation Succeed.
This tut is written by My own
  #2
Old 21-10-2008, 02:02 PM
Amir.php's Avatar
Default Re: Run Opera mini on Nokia s40(v2, v3, v5)
NO comments!!!!
  #3
Old 22-10-2008, 05:35 PM
jatt's Avatar
jatt jatt is offline
Send a message via Yahoo to jatt
nice guide thanks
ਨੋ ਗਰਲ ਫਰੈਂਡ ਨੋ ਟੈਂਨਸ਼ਨ,no girlfriend no tension,website: Punjabi.c-o.in,forum: punjabiteacher.co.cc
  #4
Old 07-11-2008, 02:34 PM
MOBEEN KHAN's Avatar
MOBEEN KHAN MOBEEN KHAN is offline
what a good tutorial
I like this
THANKS
  #5
Old 07-11-2008, 02:53 PM
bassam904's Avatar
bassam904 bassam904 is offline
M3TAL H3AD M3
Send a message via Yahoo to bassam904
Great work
you helpin yourself
[Xfire-bassam904] [Last.Fm-bassam904] [PSN-bassam904]
  #6
Old 23-11-2008, 08:41 AM
Amir.php's Avatar
Thanks friends for your response. And jatt read my tute carefully. Your solution is here. I tried to explain each and everything clearly. Make your own setting and send it to your mobile by any other bluetooth and infrared device. Now save this setting and also activate and make it default for all applications. After do this you will surely be able to run your opera mini and all java applications.
  #7
Old 17-12-2008, 02:27 PM
pankaj.yr1 pankaj.yr1 is offline
Nice tutorial!!!!!
it really works on my 3120c using NOP (airtelwap.com)
yaar koi NOP se PC par net access karne ki tweak bhi bata do Mobile Office airtelgprs.com (20/day) is quite expansive than NOP (30/week)
  #8
Old 06-01-2009, 05:24 AM
billyjames billyjames is offline
Thanks for the help. Let me give you back an advise. Read thisNokia 5310 facts article. Itis very helpfull for all Nokia owners.
  #9
Old 20-01-2009, 01:35 AM
jyoti.mallick02's Avatar
jyoti.mallick02 jyoti.mallick02 is offline
Send a message via MSN to jyoti.mallick02
can it work for Nokia 3500c
can u give brife explanation how to activate bsnl gprs in noka 3500c??????
pls need it desprately
[IMG]http://i18.tinypic.com/47lbji0.jpg[/IMG]
  #10
Old 20-01-2009, 11:28 AM
Amir.php's Avatar
^^ Yes it is surely working with Nokia 3500 classic
Now a days every isp already gives the activated gprs connectivity.
You just need setting, which you can obtain in one of the two ways:
1. request for your isp to send your required setting. and you need to save it.
2. Make you own custom setting as I mentioned above.
In this mobile you need to make and save your own custom setting. To make your own setting follow my tutorial. You need three important things to do this:
1. Your proxy address
2. port address
3. access point.
For these three things ask for Custumer care and Note down on a paper.
Now follow my tutorial and after making your setting send it via bluetooth to your mobile.
I think this will help you.
http://amirphp.wordpress.com
  #11
Old 27-01-2009, 04:27 PM
soyab0007's Avatar
soyab0007 soyab0007 is offline
xml2wbxl is not recognised
can you made the file an give me i am using BPL_WAP
Please i am having problem using comman prompt
  #12
Old 30-01-2009, 03:59 PM
Amir.php's Avatar
Now a days i am too busy and My internet connection is not regular.
But You can send me Your setting(Here or private messege):
2. port address
3. access point.
Because i am using others conection and system, so It will take time. I will send your setting at friday 6/02/2009.
  #13
Old 30-01-2009, 08:09 PM
soyab0007's Avatar
1. Your proxy address: 10.0.0.10
2. port address: 9401
3. access point. : mizone
  #14
Old 01-02-2009, 12:10 PM
Amir.php's Avatar
Arrow Re: Run Opera mini on Nokia s40(v2, v3, v5)
Your setting is here:
http://rapidshare.com/files/19365531...Proxy.zip.html
Send this prove file in your mobile via bluetooth or infrared and save it.
Also set this setting Default for all applications.
  #15
Old 01-02-2009, 04:42 PM
Adamsjunior Adamsjunior is offline
Hi , my name is Adam and i'm from Indonesia, I use Hutchison Three, I had followed your tutorial, but it's still not working, can u made me the file with the following details..
1. Proxy address: 10.4.0.10
2. Port address: 3128
3. Access point: 3gprs
4. Username: 3gprs
5. Password: 3gprs
Please include the username and password above coz without them the file won't work.. Thanks for your help
  #16
Old 02-02-2009, 11:35 AM
Amir.php's Avatar
Take your setting and send via bluetooth and save it. also set as default in configuration.
http://rapidshare.com/files/193654040/setting.rar.html
By the way i want to know where you are unable to follow my tutorial?
  #17
Old 02-02-2009, 08:27 PM
pr.itdude's Avatar
pr.itdude pr.itdude is offline
tHe nEw gEEk......ITian
Lightbulb Re: Run Opera mini on Nokia s40(v2, v3, v5)
i've been using opera and all n/w based java apps for over past 1.5 yrs.........using the same on my s40 phone. i.e., nokia 3110c.
but in delhi, NOP is no-more available....
anyways, nice thread...!!
  #18
Old 02-02-2009, 11:24 PM
vikrant333 vikrant333 is offline
Owner of Core i7
i wll try...
  #19
Old 03-02-2009, 03:34 AM
Can u reupload the file? The zip file can't be opened, may be it's corrupted .. Thankz
  #20
Old 04-02-2009, 10:09 AM
Amir.php's Avatar
I have upload file on rapidshare. Attachment are not work here.
Now you can download and save it.
it has two setting:
with password
without password
see which will work on your mobile.
  #21
Old 08-02-2009, 07:50 PM
popkalia popkalia is offline
thanks amir
my nokia 2600 c ( s40 v5 lite )default mobile browser works very well in bsnlwap access point http://218.248.65.83:8081/msp/html/
i downlad opera mini . ucweb , teashark and install on phone
i made provn file and send to my phone
as setting in this link for bsnl
http://iamsumeet.com/bsnl-cellone-gp...tion-settings/
in north india
WAP SETTINGS
BSNL Cellone WAP SETTINGS FOR WEST, EAST AND NORTH
NORTH Setting Name CelloneNorth_wap_n
Access Point Name wapnorth.cellone.in
Port 9201 for Wap 1 device
8080 for Wap 2.0
device Proxy IP 1 10.132.194.196 User Name <leave blank> Password <leave blank> Home Page http://wap.cellone.in
is this correct setting ?
then i install on mobile
when i start opera mini and ucweb browser
then it required permission i press yes it access network
and show error subscribe data first
Please help to make correct prov file so i run opera mini and ucweb
  #22
Old 10-02-2009, 07:36 AM
Amir.php's Avatar
Take your setting:
http://rapidshare.com/files/19619258..._BSNL.rar.html
I have uses parameter:
Access Point Name: wapnorth.cellone.in
Port: 9201
Proxy IP: 1 10.132.194.196
  #23
Old 23-02-2009, 08:16 PM
ammar786 ammar786 is offline
Hey i followed the above steps then also i was unable to connect via opera mini
I have bpl connection and my handset is nokia 5220
Plz help
Thanx in advance..
  #24
Old 24-02-2009, 07:48 AM
Amir.php's Avatar
While making setting, you need to very careful.
just a little error in parameter and compilation cause failure.
Try to make new setting or give me your parameter.
  #25
Old 27-02-2009, 08:14 PM
thank Amir for setting and Blue Rose
as i search nokia forum
these setting works from default s40 devices
gprsnorth.cellone.in
MY OPERAMINI , BOLT , UCWEB BROWSER works without .prov file
you can set setting with this help flash file from rediffmail
so click on 8th link HOW TO SETUP NETWORK SETTINGS
http://mr.rediff.com/mr_tour.html
  #26
Old 27-02-2009, 08:21 PM
My connection is bpl mobile.
There is a bpl folder in the zip given above but it is not working with that.
Anyways my configs are:
apn: mizone
proxy:
10.0.0.10
port:9401
Username:919821730440
Password : bplmmsc
authentication: normal
If anything is missing plz post it.
Thanx in advance.
My phone model is Nokia 5220 XpressMusic
  #27
Old 27-02-2009, 09:22 PM
shyamno's Avatar
shyamno shyamno is offline
sorry..guys ..what it is for ?? means after applying this i can access net from opera mini in mobile..or what ???
I have no idea about this.I just use the cellone portal service and my GPRS is activated but i hardly use it (costly for me).
Visit my Blog::::::
http://shyamkol.blogspot.com
  #28
Old 28-02-2009, 08:17 AM
Amir.php's Avatar
Many of the peoples who have nokia series 40 mobiles faces this problem.
The problem is that the default Browser of mobiles are capable to run with default GPRS setting, but Other internet based applications such as Opera mini, Yahoo GO, Email client etc not able to detect internet connectivity.
Reason: This problem occurs, because the series 40 mobiles such as 5300, 3500 etc are not give the option to the users to set proxy.
The problem occurs only on those mobile who uses proxy(some service provider allow internet via proxy only on mobile).
If anyone using Direct internet connection then you will not face any such problem.
Solution: Here i have given a method to make your own custom settingin .prov file and save it.
This will allow proxy users to run other internet based applications successfully on their mobile besides default browser.
You have no idea about it because you looks you are using Direct internet connection(Not proxy).
  #29
Old 28-02-2009, 11:54 AM
shyamno's Avatar
thanks...for describing it so nicely...
Visit my Blog::::::
  #30
Old 01-03-2009, 10:18 AM
Amir.php's Avatar
apn: mizone
proxy:
10.0.0.10
port:9401
Password : bplmmsc
Thanx in advance.
The pre compiled setting you are trying to use does not includes User Name and Password
I have tried to make setting with User Name and Password .
You can download it from rapidshare:
http://rapidshare.com/files/20385943...ngBPL.rar.html
use this setting to see if it works.
Forum Jump
Opera mini not working on Airtel+nokia Generic Superhero Mobile Monsters 21 28-03-2009 07:57 PM
Anyone using opera mini on nokia 6233 amit_at_stg Mobile Monsters 3 27-07-2008 09:55 AM
Orkut on Nokia 6630 - Opera / Opera Mini rak007 QnA (read only) 6 06-07-2008 01:49 PM
Opera Mini for Nokia 5610 ToxicSerpentz Software Q&A 1 07-02-2008 06:13 PM
Opera Mini for Nokia 6270 with Airtel NOP hdewan Mobile Monsters 1 10-07-2006 02:28 PM
Upcoming Events
Thinkdigit
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
