Go Back   Digit Technology Discussion Forum > News > Random News
Random News Non-technology news that you feel members should know about. NOTE: Sources to be mentioned at the beginning of each post.
Old 05-05-2007, 11:04 PM   #1 (permalink)
dá ûnrêäl Kiñg
zyberboy's Avatar
Post Earth's Pole Shift may occur in 2012.
Pole shift has happened in the past,which may give clue to the mysterious wipe out of Dinosaurs
A shifting of the Earth’s poles has been predicted to occur within the next few years by a number of psychics, including the renowned Edgar Cayce. This certainly is not a scientific prediction, but some scientists believe that it is at least possible that this could happen at some future date, and perhaps has happened many times in our planet’s past. Whether or not we could survive a physical shifting of the Earth’s poles is open to debate
Seeing the powerful earthquakes such as the December 26th, 2004 event that triggered the tsunami disaster, people are looking for possible causes for the apparent instability of earth's crust. "End-times" alarmists and backyard researchers believe that the predicted imminent reversal of the earth's magnetic field may be a significant clue to these eschatological-scale events.
more abt pole shift
http://www.pureenergysystems.com/new...et_Pole_Shift/
According to NASA Polar Shift Due In 2012.
http://www.gvnr.com/74/3.htm
Why 2012??
The Maya believed that their world would end on Dec 21, 2012. Of all the dates put forth by prophets and cultures for a doomsday, this is one with an authentic almost eerie feel to it
It is like a large check mark on the calendar, a pointer aimed at 13.0.0.0.0, the "End Date" of the Mayan Long Count Calendar. From the Mayan point of view, this is the "End of Days." It is so significant that the calendar just comes to a stop. It is like having an alarm set when it's time to take your medicine. This date is also December 21, 2012, the day of the Winter Solstice. But what is this check mark trying to tell us. What medicine are we suppose to remember to take?
http://www.artideas.com/Why2012/Why2012.html
http://www.levity.com/eschaton/Why2012.html
My Stomach pains:D:D
http://tinyurl.com/32jj4m
zyberboy is offline
Old 06-05-2007, 12:21 AM   #2 (permalink)
Back to l33ching :)
gauravakaasid's Avatar
Location: Latitude: 22° 32' North. Longitude: 88° 22' East
Default Re: Earth's Pole Shift may occur in 2012.
hmmm...this is sumthing new....had no idea about it
Whenever you find yourself on the side of the majority, it is time to pause and reflect ~ Mark Twain
gauravakaasid is offline
Old 06-05-2007, 01:01 AM   #3 (permalink)
You gave been GXified
gxsaurav's Avatar
hmm....I knew about the date of Mayan calender from quite some time.
Well, everyone has to die. 5 years left till this date so lets see, marna hai to marenge, why worry about it right now.
( No more future planing & investment plans after 2012 now )
about.me/gxsaurav
gxsaurav is offline
Old 06-05-2007, 01:46 AM   #4 (permalink)
hailgautam's Avatar
if pole shift happens it would be a disaster for us, we would go to left when we need to go to right... the electricity as it now flows will flow in the opposite direction...... we will be extinct...arjun singh will actually become prime minister ......it will be the dooms day
Change is Nature, the part that we can influence; and it starts when we decide.
Where you going?
With Luck forward.
hailgautam is offline
Old 06-05-2007, 11:54 AM   #5 (permalink)
mera kutch nahi ho sakta
chesss's Avatar
Dude they are talking about solar polar shift(on the SUN!!), Not on the earth.
jin files ka koi server nahi hota unka bittorrent hota hai
chesss is offline
Old 06-05-2007, 12:46 PM   #6 (permalink)
sms_solver's Avatar
I think something good or bad is going to happen very soon. The unsual weather around the world could be seen as the clue.
PS: NASA hides more information about planets, galaxies, don't believe what NASA says or any government organization.
[ॐ एसएमएस॰सोल्भर ॐ]
sms_solver is offline
Old 06-05-2007, 01:33 PM   #7 (permalink)
dá ûnrêäl Kiñg
zyberboy's Avatar
Post Re: Earth's Pole Shift may occur in 2012.
yeah sure,But Sun's pole shift has significant effect on earth's magnetic pole.And also Mayan's dont say abt pole shift anywhere, their calendar just ends in 2012.Which is one of the most accurate and Sphosticated calendar ever created.
The Pole Shift, when it occurs is a combination of several major factors not fully understood by present day astrophysicists. These factors are gravity, repulsion, the interaction of magnetic subatomic particle streams between the planet Earth, the Sun, n other planets.
But We can't say earth's pole shift will occur in 2012, only time will tell.
NASA has been studying solar flare cycles (sunspots) and shifts in the sun's magnetic field for many years. They have found direct links between abnormal weather on the earth, shifts in the sun's magnetic field, and major solar flares. Until recently, they expected the present cycle to be just another ordinary 11 year event, with the sun's magnetics waxing and waning as before. However, this cycle is behaving badly. Recent solar flares have gone off the scale, ten times greater than anything previously recorded. And weather patterns are responding with serious consequences.
Another shift in the magnetic field of the sun, coupled with solar flares larger than ever recorded to date, might have a huge impact on the magnetic equilibrium of the earth's crust. This could well be the catalyst that would "tip the balance" and send the large ice masses at the poles down (or up) to the equator again. These solar events usually last several days, and during that time a near alignment of the mountainous "ring of fire" with a solar/lunar tidal concurrance might easily occur. And if it does, the results and effects may easily be predictable.
zyberboy is offline
Old 08-05-2007, 07:07 AM   #8 (permalink)
mekalodu
iinfi's Avatar
Originally Posted by cyberboy_kerala
yeah sure,But Sun's pole shift has significant effect on earth's magnetic pole.And also Mayan's dont say abt pole shift anywhere, their calendar just ends in 2012.[red]Which is one of the most accurate and Sphosticated calendar ever created.[/red]
that sent shivers down my spine..
mekalodu
iinfi is offline
Old 08-05-2007, 07:24 AM   #9 (permalink)
Pawned!... Beyond GODLIKE
fun2sh's Avatar
wel nature has to take revenge from humans. we hav done a lot of destruction. n all these global warmin issues is showin that. lets prepare for doomsday
fun2sh is offline
Old 08-05-2007, 08:38 AM   #10 (permalink)
18 Till I Die............
He'd become the emporer of the world. The naked emperor cos he's as foolish
http://www.bash.org/?258908
mehulved is offline
Old 08-05-2007, 10:49 AM   #11 (permalink)
rohit_bawa's Avatar
Good Find
But Life for today let the future remains mistery
BTW i had seen a program based on the same story on discovery long time back
rohit_bawa is offline
Old 08-05-2007, 12:23 PM   #12 (permalink)
HAF 922 Owner
i_am_crack's Avatar
Sorry No comments..But is it for real????of just another Y2K kinda funda
Well Actually I forgot to say Hi to you???? Can I say now???
i_am_crack is offline
Old 08-05-2007, 01:30 PM   #13 (permalink)
lalam's Avatar
It sounds scary but its hard not to believe either if this doesn't happen something else will happen....
lalam is offline
Old 08-05-2007, 01:39 PM   #14 (permalink)
royal's Avatar
Wink Re: Earth's Pole Shift may occur in 2012.
We will have "Satyayug" after 2012
royal is offline
Old 15-05-2007, 03:54 AM   #15 (permalink)
String Phreak
mediator's Avatar
^Kalki hasn't descended yet!
mediator is offline
Old 15-05-2007, 04:23 PM   #16 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
5 years only ......... HOLY CROW ......... am not even married .......
have lot things 2 do ............
& gotta tell my GF ............
ax3 is offline
Old 15-05-2007, 07:44 PM   #17 (permalink)
mobilegeek's Avatar
hmm / the great global worming
mobilegeek is offline
Old 15-05-2007, 07:57 PM   #18 (permalink)
gxsaurav's Avatar
Holy...I forgot this point....
but if I call, i will be out of balence in my mobile before the night ends
about.me/gxsaurav
gxsaurav is offline
Old 15-05-2007, 09:19 PM   #19 (permalink)
royal's Avatar
Consider urself lucky Enjoy life as much as u can without getting entangled in "Vivah-bandhan"
royal is offline
Old 21-05-2007, 01:07 AM   #20 (permalink)
mekalodu
iinfi's Avatar
Talking Re: Earth's Pole Shift may occur in 2012.
ROTFL
mekalodu
iinfi is offline
Old 21-05-2007, 11:07 PM   #21 (permalink)
UbuntuUser
cynosure's Avatar
5 years are all I have. Sh1t man.
And I wanted to buy a hayabusa 1300RR and Alienware.
No speed for me.
Seriously guys. I have not read the full article but sh1t this is so scary...
cynosure is offline
Old 22-05-2007, 12:07 AM   #22 (permalink)
Oh no
I am only 15. Have a look at this
http://www.dailymotion.com/video/x1c...y-2012-preview
hitman050 is offline
Old 22-05-2007, 12:57 AM   #23 (permalink)
Still in war with allies
ssdivisiongermany1933's Avatar
I want all bond girls and sexy mac books
ssdivisiongermany1933 is online now
Old 22-05-2007, 11:01 AM   #24 (permalink)
*Basket Case*
~Lil JinX~'s Avatar
I can't help but wonder if this is really true. I've seen a few of these "doomsday" predictions before. Only a couple of years ago (I think?) a giant meteorite was supposed to hit the earth, and put an end to all lifeforms. It was supposedly bigger, or almost as big as the meteorite that had hit the earth, and had eliminated the dinosaurs. This was an article from NASA (It was posted on the Indian Ragnaboards...I don't know if I can find it. If I do, I'll be sure to post a link ^^) Yeah, there was a date for this...but that date came and went, and nothing happened. Every time something like this shows up, people put a big "X" mark on their calender, and jsut wait for the end of the world =.= Its true that there seems to be evidence for this...but still, I can't help but stay skeptical.
It can be true, but it may not be.
Hell, if it IS true...why is the end of the world such a bad thing? Its not like anyone will be left on earth to miss the world XD.
~Lil JinX~ is offline
Old 23-05-2007, 10:55 PM   #25 (permalink)
dá ûnrêäl Kiñg
zyberboy's Avatar
Originally Posted by hitman050
Oh no
hmm..good video,thanx for the link man,I know abt "web bot project" but i was unaware that
"Web Bot Project" also predicts a similar kind of thing.The Web Bot Project is an amazing program which uses collective consiousness to predict future events.I have seen an experiment in which a man's unconsious mind was able to produce a small effect on a near by robot,web bot project uses similar kind of data.
Another interesting fact is that the chinese book "Book of Changes." also predic the end of world,but the amazing fact is that this concidence with mayan date, dec 21st 2012 the day of the Winter Solstice!!
Many Dooms day date has come and gone,but i feel this one has some authentic behind it.
Even more intriguing is the fact that there is scientific evidence that points to a very rare astrological occurrence taking place in the year of 2012. For milena, the Mayans believed in the existence of a dark rift in the center of the Milky Way and considered it fact. Only recently did modern scientists discover that it actually does exist.
In the center of our galaxy is a black hole. And in the year 2012, the sun and the earth will be in direct alignment with this black hole. Scientist speculate that magnetic shifts could take place as a result. In essence, the poles could reverse. The poles have shifted before, some 800 million years ago. Einstein suggested this pole shifting theory in 1955.
http://archives.cnn.com/2001/TECH/sp...ole/index.html
The Web Bot Project
The Web Bot Project, developed in the late 1990's, was created to assist in making stock market predictions.
The technology uses a system of spiders to crawl the Internet and search for keywords, much like a search engine does. When a keyword is located, the bot program takes a snapshot of the text preceding and following the keyword. This snapshot of text is sent to a central location where it is then filtered to define meaning.
But in 2001, bot operators began to notice that stock market predictions were not the only matters being accurately predicted by the program. They began to take notice of coincidence with occurrences and explored it further.
One of the first accurate predictions from the bot program took place in June of 2001. The program predicted that a life altering event would take place within the next 60-90 days. An occurrence of such proportion that it's effects would be felt worldwide. The program based it's prediction on "web chatter" which ultimately represents the collective unconscious of society.
Regrettably, the bot program's prediction proved accurate and the Twin Towers fell on 9/11/2001.
http://aphroditeastrology.com/2007/0...-and-2012.html
I too was aware of that prediction,but that was not certain meteor hit,What NASA predicted is the meteor will pass vry near to earth,it actually did but in astronomical figure 600,000 km is vry near this is wt tey said.Nasa said tat ter is only a vry slim chance that tat the meteor will hit earth by changing its path due to the inter planetary gravitational force.
http://archives.cnn.com/2002/TECH/sp...ller.asteroid/
zyberboy is offline
Old 23-05-2007, 11:15 PM   #26 (permalink)
jal_desai's Avatar
I Wanna Save The World... :d
TechExplorer.in
jal_desai is offline
Old 13-12-2007, 11:35 AM   #27 (permalink)
Originally Posted by iinfi
ROTFL
Atleast I can die laughing!
ricky_pradeep is offline
Old 13-12-2007, 11:48 AM   #28 (permalink)
A LOTR fan
x3060's Avatar
21 Dec. 2012. Will the world end????
similar thread running...
How many kilometers are there from washington Dc to Miami beach?????....;)
unban praka123!!!....
x3060 is offline
Old 13-12-2007, 01:32 PM   #29 (permalink)
Dreamweaver
Gigacore's Avatar
does anyone know what exactly is going to happen to planet earth during pole shift? earthquake? flood? storm? or ??
if this is true then it will be great! coz we all are going to die at once. if its false, this is just another rumor.
Gigacore is offline
Old 13-12-2007, 02:39 PM   #30 (permalink)
fun2sh's Avatar
wel i read some where (after googlin abt solar storms) that solar storm r also predicted by NASA to come in 2012 n this it wil hav the highest intensty than before.. n pole shift is also occurin durin that time..
now the magnetic feild of earth protects us from those solar storm(containin highly engertic particles).. but as pole shift will be in the way the solar storm wil hit. now the earth magnetic effect cause the two pole(north n south) which attracts all the energied particles of solar storm. thus those particles are mainly concentrated at the poles.(this is the reason for auroras at the poles too)
but sice of pole shifth happenin at right time it wont be able to protect that much n it was mentioned in site that it will lead to the complete wippin of the earth's atmosphere
If God has indeed created Himself in His own image, then I submit to you that God is a cockroach :mrgreen:!!!!!!!!
fun2sh is offline
Google Earth's Images aninnovator Internet & WWW 4 17-04-2007 11:35 PM
after shift+del button... varunbhide QnA (read only) 6 30-08-2006 07:56 AM
How To Shift Mydocuments ??????????????? EagerBeaver Software Q&A 9 18-08-2006 05:28 PM
Use of Shift in Windows tuxfan Software Q&A 9 06-02-2005 05:27 PM
- by Krow
- by gohan89
