Go Back   Digit Technology Discussion Forum > News > Random News
Random News Non-technology news that you feel members should know about. NOTE: Sources to be mentioned at the beginning of each post.
Old 02-03-2009, 12:37 PM   #1 (permalink)
Pragadheesh's Avatar
Cool The mirror that gives a true reflection
Andrew Hicks has designed the first mirror which gives a true reflection – and not a mirror image.
His creation has several tiny curves and bends in different directions which flip a mirror image back the right way.
Text can be viewed from left to right and, if you raise a hand while looking in the mirror, your reflection appears to be raising the opposite.
Mr Hicks, a mathematician at Drexel University in Philadelphia, used computer algorithms to find the *dimensions and angles need to make his invention work.
The 42-year-old has spent years creating different mirrors and has also made ones which eliminate distortion or give wide angle views.
The reflection we see in a conventional mirror is shifted from left to right, so text appears back to front.
Normal mirrors simply bounce light from an object back to the viewer.
The unique shape of Mr Hicks' design directs light from an object, across the mirror face and back to the viewer, which flips the mirror image.
amazingly cool right..!!!! so if such mirrors come to use then ambulance can sticker their vehicles in normal fashion.!
source:
http://www.metro.co.uk/news/article....&in_page_id=34
Pragadheesh is offline
Old 02-03-2009, 03:05 PM   #2 (permalink)
Default Re: The mirror that gives a true reflection
So is it a Plane,Concave or Convex mirror?. Halp. me = n00b at Physics.
Count Dracula is offline
Old 02-03-2009, 06:56 PM   #3 (permalink)
^^Dracula you needn't worry, you wont see your reflection in any mirror.
Steam/Flickr: psygeist
Asus Z68 V-Pro|i5 2500k|TRUE Black|Ripjaws X+Corsair Vengeance|U2311H|N560GTX|D7000|XONAR STX|RE272|RE0|CC51|XE200PRO Walnut| TD II V2| Ultraphile|N5800
Faun is offline
Monster and mirror :D funkymonkey Hardware Q&A 2 01-05-2007 09:47 PM
SMS Text In the Mirror dd_wingrider Technology News 2 09-02-2007 12:18 AM
Photoshop: Image Reflection goobimama Tutorials 17 01-02-2007 12:19 PM
mirror sites saptak QnA (read only) 4 29-07-2005 01:27 PM
