14-10-2008, 06:40 PM
Help me?????????
hai my sys configuration is
pentium 4 2.66GHz MB D101...
DDR1 ram 256MB
Inbuilt graphics card(i don't know wat graphics card)
80GB HDD
Friends now my system is getting problem often like when iam working the blue page turned up saying physical memory dump and after it's restart it fails to boot... so tell me why is it so?????
Now give me an idea if i want to upgrade my configuration is it best to add up a graphics card or else 1GB DDR1 RAM
And also please let me know the price of graphics card and DDR1 RAM of all types????
14-10-2008, 06:52 PM
The Black Waltz
Re: Help me?????????
^^ I think it's a problem with your RAM since your PC isn't booting. BTW, does your motherboard support PCI E cards or only AGP cards?? 512 MB of DDR400 RAM from Zion will cost around Rs 1.2 K.
BTW, where are you from?? Karnataka?
#krow @ irc.freenode.net
21-10-2008, 12:19 AM
hai iam from chennai , and iam new to this technical world could u plz tell me what is that PCI E cards and AGP....... and i siad i was using DDR1 but u telling d cost for DDR400????
21-10-2008, 12:26 AM
Core i7 (nehalem) Owner
^^ i think since u are on DDR-I, u wont be having a PCI-e (PCI Express is a new tech for graphics) configuration..
hv u checked ur motherboard's manual ?? if u hv lost it, plz search for it online.. and post the details here..
we will be glad to help u..
and , u shud add extra RAM say 1 GB DDR-I(400 Mhz speed) and a graphics card (that on board will not take u any far..
Cheers n e-peace....
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
21-10-2008, 12:33 AM
Legen-wait for it-dary!
1. There should be an error code/filename/error description in the blue screen. Post that.
2. PCIE and AGP are types of interfaces, where your graphics cards can be connected. PCIE is faster than AGP, and your motherboard supports it.
3. DDR400 refers to the speed of the ram, not the version number like DDR1. It runs at 400 MHZ in this case.
21-10-2008, 12:38 AM
hai ashu could u tell me how much it cost for DDR1 and a graphics card for it and where u r from??
Reason: Automerged Doublepost
21-10-2008, 12:43 AM
well im from Mumbai buddy..
a 1 GB DDR-I RAM from Transcend (working on 400 Mhz speed) will cost u Rs.1900/- (+/- Rs.200)
infact, i wud recommend u NOT to take a single 1 GB GGR-I RAM instead take 2 x 512 MB DDR-I RAMs and make them work in DUAL CHANNEL mode..
i hv 4 x 512 MB DDR-I (400 Mhz) Transcend RAM in dual channel mode..
well, dheeraj said tat ur mobo supports PCI-e card so u cna buy tat too, take a 256 MB or a 512 MB card...
(now-a-days, pci-e cards are alot cheaper than AGP card of the same capacity)
wats ur mobo model ?? (if u diont knw tat too) goto start>run and type dxdiag and press enter, a direct x dialogue box will appear, wich will list the mobo model.. so note it down and post it here..
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
21-10-2008, 12:48 AM
thanks dheeraj but where to find about which is mine either PCI or AGP supporting one..
21-10-2008, 12:51 AM
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
21-10-2008, 12:56 AM
thanks ashu
here is the detail is that ok
System Information
Time of this report: 10/21/2008, 00:51:50
Machine name: G-D79467AE6FCD4
Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 2 (2600.xpsp_sp2_rtm.040803-2158)
Language: English (Regional Setting: English)
System Manufacturer: ATI___
System Model: AWRDACPI
BIOS: Phoenix - AwardBIOS v6.00PG
Processor: Intel(R) Pentium(R) 4 CPU 2.66GHz
Memory: 190MB RAM
Page File: 351MB used, 1870MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.2600.2180 32bit Unicode
now tell me where to check about my graphics card is it internally build??? and what about is it PCI -E or AGP
21-10-2008, 08:47 AM
You said your Mobo is D101, it says on intel's site that it supports PCIE. THats what I said in my post above.
For your graphics card details, check the display tab in dxdiag.
Its been a long time since I visited any hardware shops(no trouble yet  ) so I dont know. If you want authentic prices, I suggest Devaraj Computers in Anna Salai, near Indian Bank, and Anna Theatre's nearby complex. They are very popular and the customer service is excellent.
21-10-2008, 01:24 PM
I think he(the original poster) shud refer to his manual, coz (i gues) its based on ATI chipset .. is it ?? (as per the details from his dxdiag page saying system manufacturer ATI)
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
22-10-2008, 02:42 AM
thanks buddy may i know where is dheeraj from and thanks for giving me a nice service area it may be helpful ......
22-10-2008, 12:23 PM
Fullbring
Cant u c the location info on his profile...lolz
I doubt how ur mobo has PCI-e & also has DDR RAM (coz pci-e mobos support DDR2 RAM)
Btw the price of 1GB DDR 400 (Transcend is between 1.3-1.4K) in MUmbai
22-10-2008, 01:08 PM
Democracy is a myth
Originally Posted by KaranTh85
Btw the price of 1GB DDR 400 (Transcend is between 13-14K) in MUmbai
R u sure its 13-14k, then only the price of RAM can help him upgrade a new age MOBO, procy and 1GB DDR2 Ram
"My opinions may have changed, but not the fact that I am right."
"I'm never wrong. Once I thought I was wrong, but I was wrong"
22-10-2008, 01:57 PM
13-14 K >?>??? :O:O omg....
yaar its NOT 13K (Rs.13,000/-) its 1.3K (Rs.1300/-) .. lol check ur figures...
infact 512 MB DDR-I Transcend 400 Mhz RAM is (approx.) Rs. 1200 and I guess 1 GB DDR-I Transcend 400 MHz RAM will be priced at Rs.1800 (1.8K)
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
22-10-2008, 02:17 PM
Fullbring
oops!!!  forgot 2 put the dot....in betwn....
OK..post edited
22-10-2008, 03:01 PM
Excessive happiness
@thread_starter
Ur mobo supports pcie and i suggest u to go for 1GB DDR 400MHz RAM.. But in chennai proces re sky high compared to other Metro cities...
And get a ASUS 8600GT 256MB DDR2 PCI E Card....coz my niece have the same mobo as u have, and he use 7900GT PCI E in it...
My First Android phone : Samsung Galaxy SL i9003 - Rooted & Gingerbread XXKPQ
Updated : superteekz_V2 ROM for XXKPQ.
PS Request
22-10-2008, 03:48 PM
#19 (permalink)
Fullbring
offtopic:
"India runs on warez" - my latest enlightment
A born surfer - I came, I saw, I clicked.
A porn surfer - I clicked, I saw, I came.
hey dheeraj...r u so obsessed with porn dat u always use this 4 letter word in ur siggy....i remember ur previous siggy was "harry potter & the harddisk of pron"
22-10-2008, 03:51 PM
#20 (permalink)
Excessive happiness
PS Request
22-10-2008, 04:13 PM
#21 (permalink)
EXIT: DATA Junkyard
Caught him in his PRON lololz
22-10-2008, 06:59 PM
#22 (permalink)
The Black Waltz
Hey arun, I suggest you buy Zion RAM over Transcend RAM. It'll be cheaper than Transcend RAM. And there aren't any performance differences.
23-10-2008, 06:38 AM
#23 (permalink)
I'm not obsessed with porn, its just that I happen to make funny lines a lot using that word. BTW, my previous siggy and this are purely coincidental. I was modifying old quotes (I came, I saw, I conquered) into funny ones and hit upon this lol
23-10-2008, 10:35 AM
#24 (permalink)
Fullbring
Funny lines...hmmm
But we cant read ur mind...dont know what ur intention while writing a siggy...dats y...thought like dat....neways....
23-10-2008, 01:23 PM
#25 (permalink)
^^ Aww, I know, we innocent people are easily misunderstood...
23-10-2008, 02:05 PM
#26 (permalink)
naughty boy :) :)
@dheeraj.
From the information getting wen we type dxdiag , how to know which mobo is there? can u help me .
Phenom II 550 BE | GA-MA78GM-US2H | 160 gb + 500 gb hdd | 2 X 2 gb XMS2 | HD 4850 1 GB | 2033 SW | Tagan TG600-U37 | CM 690
23-10-2008, 03:14 PM
#27 (permalink)
Fullbring
Originally Posted by maheshr
@dheeraj.
If u have winXP..then open command prompt > type systeminfo
u will see all details of ur PC...
or use 3rd party tools such as pc wizard 2008,everest pro,sisoft sandra pro etc to get the details easily....
23-10-2008, 04:42 PM
#28 (permalink)
@maheshr
On the "System" tab see System Manufacturer and System Model. Thats your motherboard. In my case -
System Manufacturer: INTEL_
System Model: DG965RY_
Also, you can do what Karan said. If you want it to be shown in a nice window with search options, do:
Start->Run "msinfo32"
Have fun!
24-10-2008, 11:15 AM
#29 (permalink)
naughty boy :) :)
Thanx to both dheeraj and karan
Search this Thread |
