18-05-2005, 06:22 PM
IE adult site opens
whenever i start my IE the site "adultfriendfinder" opens automatically what to do pls help
18-05-2005, 06:31 PM
Download AdAware and install it. Run it, click "Scan Now" button in the left pane and select the radio button "Perform full system scan" and click "Start". Then rempve any malware it finds.
If this doesnt help you, then download HijackThis and unzip it to dedicated folder.
Then run it and click the button Do a System scan and save log file. HijackThis will perform a scan and saves the log file as hijackthis.log. Copy the entire contents of the file and post it here.
http://swatrant.blogspot.com/
18-05-2005, 06:32 PM
Location: The throne at the royal palace of Smiley Kingdom!
 Hey admins, judging by the trends.. how bout a sepatare sexion only 4 IE bluez
& dhyanabhay, its a common problem - addressed many times by myself & others in here so search/browse the board/seek & u shall find
:) [_CALCATIAN_] :)
Status: Online [ ] / Offline [ :( ]
\"I sleep 4 only 2.5 Hrs/week & doc.s say I\'m fine :!: \"
Everyone SUX in their own comfortable way :!:
18-05-2005, 06:33 PM
may be u have made it as ur home page...
try finding that out...
NOBODY
is perfect,,, I am NOBODY
18-05-2005, 06:35 PM
you can also use spybot search and destroy
its free and best
18-05-2005, 07:45 PM
Run Adware or other Spware/Adware removal tool.
In the keyboard of life, always keep a
finger on the ESC key
18-05-2005, 08:17 PM
GUNNING DOWN TEAMS
Hey there so many adware and spyware software everymonth in digit cd's and DVD's use them dude....
18-05-2005, 08:59 PM
Just Do It
There arent any spywares on adultfriend. They must have asked you whether u wanna set it as ur homepage, you must have clicked yes.
18-05-2005, 10:16 PM
Another Brick in the Wall
Originally Posted by mohit
Dude, he has been hijacked, and he needs to post his HJT log file, and there is no wrong in starting a new thread.
18-05-2005, 11:19 PM
To handle yourself, use your head; to handle others, use your heart.
18-05-2005, 11:43 PM
What? Where? How?
yeah ur right. :roll:
98% of the people using internet have started or forwarded "chain mails". If you are one of the 98%, Die a horrible death.
19-05-2005, 12:48 AM
Certainly not, but these sites pay u if a vistor lands there with your referrer code... thought bout that
Now consider 5-7000 hopeless victims like this one contributing to yor purse everyday, round the clock, around the world - got the nice picture
So this is another intrusion/exploit trick that even makes some cash 4u... and ... well the usual HJT + (regedit:SpybotSD) shud be naf
:) [_CALCATIAN_] :)
19-05-2005, 09:17 AM
Distinguished Member
sure your browsers homepage has been hijaked !
download, update and run adaware, ms antispyware and spybot.
then manually go to ie/tools/internet option, and change your homepage to whatever u want or best "about :blank".
then using any of the antispy programs mentioned above, LOCK you homepage.
u wont be forced to c something u dont want too !!!
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
19-05-2005, 11:39 AM
i tried to change the home page of ie to about blank but in vein, then i used the adaware se thn spyware doc, thn registry repair pro but all in vein. no solution. pls suggest me somthng else.
19-05-2005, 12:03 PM
MAn, post ur HijackThis log file...., then it will be ok.
http://www.merijn.org/files/hijackthis.zip
19-05-2005, 12:26 PM
well buddy how about changing over to firefox???
its time now for u to think about it !!!!!!
cheers
19-05-2005, 12:49 PM
Download MS anti-spyware & do a clean.
Then try spy sweeper as well. They did quite a good job for me....
Hope they will work for you too....
Quote by Garfield'
19-05-2005, 01:32 PM
#19 (permalink)
Just Do It
Seems like then it is a spyware. Anyway run the HJ and use the Spywares to elimnate the crap.
Search this Thread |
