Originally Posted by Chetan1991
iMav is right. Proccessor is a very delicate thing. you should keep in the motherboard. Just check before transporting that the heat sink is fixed securely. if it is, nothing is going to happen to your processor until somhow the whole motherboard breaks up......lol , joking. just make sure that the cabinet is safely packed.
thats what i mean to say, i am going to remove the mobo, from the cabinet, pack it inside its original box (in which i bought it). now obviously the mobo wont fit inside the box, with the cpu heatsink still attached to it...so i need to remove the heatsink anyway.
hope u understood what i mean to say...
but i feel leaving the cpu in the mobo, is dangerous...coz any impact on the mobo, will put lot of pressure on the cpu pins....but on the other hand, i can remove the cpu and wrap it well with damping material,(i still have the plastic cover in which the cpu came).
