12-10-2008, 08:57 AM
how to find out what an exe is doing!!!!
hey guys i know that this question may be very simple for those who are into programming or so called "code masters" but i am not one of them. My doubt is we come across many executable files and while running such files we should know what all things are changing in our pc. I just want to know how to find what all actions is it taking along when we run a exe file.
"An eye for an eye leaves the world blind." - Gandhi
Athlon II X 4 620 Quad Core, Gigabyte GA-MA 785 GPMT, G-Skill DDR3 1333 Mhz 2GB X 2, Seagate 1 TB + Seagate 80 GB, Win 7 Ultimate 64 Bit
12-10-2008, 10:11 AM
Re: how to find out what an exe is doing!!!!
what i am interrested is all the one time changes which the exe file does... for example copying a file from place a to place b or making changes in registry.
12-10-2008, 10:43 AM
The Black Waltz
Installing a firewall like Comodo can help you with this. Besides making your PC more secure, you'll be notified everytime an executable tries to do something on your PC. It can get very annoying though, so don't break your monitor by smashing it if you get annoyed.
#krow @ irc.freenode.net
12-10-2008, 10:56 AM
@beta testing
yes what u say is fine to protect our pc from any unauthorised change but that will be restricting an exe while it is executing ....cant we have an application which can bring out the list of activities which the exe is intended to do?
12-10-2008, 11:29 AM
The Black Waltz
Originally Posted by hansraj
@beta testing
It won't be restricting the activites of the exe. It'll alert you about the action it's gonna do, and if you don't mind, you can give permission to the exe to do so.
12-10-2008, 12:01 PM
@swatcat
the sites are limiting the size to 15mb is there a software for the same. Also larger the size more bandwidth it will take for me to know about the file.
12-10-2008, 01:51 PM
Hmm... beta testing has already suggested you one tool - Process Monitor. It can monitor various API and IOCTL calls, using which you can track what an executable is doing. And, here's one more tool:
http://www.rohitab.com/apimonitor/index.html
http://swatrant.blogspot.com/
12-10-2008, 03:08 PM
The Black Waltz
^^It was not me, it was debsuvra.
12-10-2008, 09:34 PM
Still Shining!
Try "Installation Monitor" which comes integrated with " Advanced Uninstaller"
It logs all the files the exe copies/deletes/changes, folders created/destroyed, all the changes made to the registry, etc. I use it while installing demo apps. This way u can completely wipe out the app's installation data and install it once again as a demo
Nokia N86 8MP
13-10-2008, 12:35 AM
Banned to Spam
Location: Look below...not under pants dumbo...use a GPS
I would go with process explorer, though i've used it, sometimes it becomes too complicated, for example try running explorer.exe and see how much log you get...
My DeviantART page now exists !!!
Krazy-Bluez.deviantart.com
Twitter: http://twitter.com/KrazyBluez
13-10-2008, 03:34 PM
Legen-wait for it-dary!
You can use sandbox tools recommended by swatkat, or process explorer. Try PrevX as a last resort, since its more of an annoyance than a benefit. If all fails, OllyDBG.
13-10-2008, 07:06 PM
thanx guys. lots of input for the job....
13-10-2008, 08:13 PM
What kind of job
13-10-2008, 08:36 PM
*suddenly suspicious*
14-10-2008, 09:02 AM
no dear..... its nothing but using certain malicious exe's (unknowingly) has resulted in system format and reinstallation. So finding a way out ...... at times even the antivirus and spywares dont work properly and then we have to reinstall the whole os. At least i had to!!
This was the only reason to know in advance what an exe is doing.
Search this Thread |
