Old 12-10-2008, 12:17 AM   #1 (permalink)
99.9% Idle
axxo's Avatar
Default What to do with dead pixel?
My less than a month older viewsonic vx2235wm caught a dead pixel(not a stuck pixel) very recently. I tried with few software solutions in trying to fix it but none helped. What should i do to get this rectified?
Unban praka123
axxo is offline
Old 12-10-2008, 12:25 AM   #2 (permalink)
swatkat's Avatar
Default Re: What to do with dead pixel?
I guess only stuck pixel can be fixed. Dead pixel, as the name says, is dead. There are some tools that claim to fix dead pixel:
http://www.killdeadpixel.com/
http://fixdeadpixels.uv.ro/
http://deadpixel.googletoad.com/
Have you tried them all?
http://swatrant.blogspot.com/
swatkat is offline
Old 12-10-2008, 12:31 AM   #3 (permalink)
AFAIK, dead pixel cannot be fixed. See: http://in.youtube.com/watch?v=Or1PZUDuXJU
Bandu is offline
Old 12-10-2008, 12:39 AM   #4 (permalink)
swatkat's Avatar
Yes! Actually, I meant stuck pixel in my post above!! Fixed typo!!
swatkat is offline
Old 12-10-2008, 01:03 AM   #5 (permalink)
Jhaat Maharaj's Avatar
I think you should call the Customer Care of Viewsonic, you should get an replacement.
Jhaat Maharaj is offline
Old 12-10-2008, 09:39 AM   #6 (permalink)
99.9% Idle
axxo's Avatar
not sure whether they will take it for replacement. Any threshold like minimum no of pixels will be considered for any such replacement?
Unban praka123
axxo is offline
Old 12-10-2008, 09:41 AM   #7 (permalink)
Šupər♂ - 超人
koolbluez's Avatar
Cool Re: What to do with dead pixel?
I got one on my fantastic lappy display & it took away all the sheen. Tried those sw... but too lazy & busy to try then for 12hrs or so.. as they say.
I just pressed on the spot... blunt press... & presto... the pixie pixel's gone. Try it.
koolbluez is offline
Old 12-10-2008, 09:48 AM   #8 (permalink)
99.9% Idle
axxo's Avatar
but I wonder whether they do work for dead pixel, and i dont want to take risk affecting nearby pixels as well. plz guide me if this is safe.
Unban praka123
axxo is offline
Old 12-10-2008, 11:03 AM   #9 (permalink)
Šupər♂ - 超人
koolbluez's Avatar
considerably safe... dont poke it... just press it... slightly... sorta like.. massaging the pixel there... it worked for me.
Old 14-10-2008, 04:13 PM   #10 (permalink)
i think you'll get a replacement for sure, as it has happened inside the warranty period.
get your monitor replaced as soon as possible.
Old 14-10-2008, 04:20 PM   #11 (permalink)
Hi
Viewsonic comes with a 3yr warantee. My one yr old Viesonic had a problem with its video card and they replaced it without making noise about...
I think you should not lose any time to lodge a complaint !
Good luck
harmads is offline
how much is 1 MEGA PIXEL?(in terms of pixel) kerthivasan QnA (read only) 3 19-07-2007 02:20 PM
What is PIXEL SHADDER?? cooldip10 Gamerz 10 12-05-2006 12:04 PM
from where 2 download pixel shader Nilesh.Ravindran Gamerz 9 05-02-2006 08:17 PM
pixel shader samurai Gamerz 1 23-01-2006 01:34 PM
pixel shader Nilesh.Ravindran Gamerz 1 28-12-2005 11:12 PM
