Originally Posted by n3o.kool
hey ne one can tell me how can i format my c drive i tried the same by right clivkin on c drive icon and then format but it isnt working.I have my one XP installed in c drive and one I have installed in my D drive.I dont need the XP on c drive and it contains many bugs nd viruses plzz help
u cnt do it tht easily buddy...because wen u try to format it by right clicking, u r doing that in the windows interface which is installed in the same drive...tht is the reason y your command doesnt execute.
i would suggest stick with winxp only...it is wonderful/.
the simple way out is
1.insert a bootable win xp cd..
2.restart your computer.
3.you will see a dos based winxp setup.
4. it will ask you the drive in which u want to install fresh windows xp.
5.choose the drive, it will then ask you tht in which format u want to format your that particular drive(fat32 or ntfs), i would suggest choose ntfs.
6.thn it will format your drive and install a fresh winxp. which will be trouble free. and for ensuring tht install a good anti virus, or rather more than that for keeping your pc safe just be a little careful while choosing the kind of websites that you visit, or the kind of media that you use..(usb and all.)
happy pcing.
regards
manan
