Old 18-05-2005, 03:47 PM   #1 (permalink)
Curious Guest's Avatar
Default ThemeManager 2005 2.2
Control the OVER ALL look of your Windows computer with Theme Manager. It's a new program that lets you manage all your skins, themes, wallpapers, icons, etc. from a single interface. You can even mix and match them together to create full blown suites! Theme Manager is a front end that seamlessly works with your other desktop enhancements to apply skins, themes, icon packages, and suites all from the same user interface. Once you have your desktop just the way you want, you can take a snapshot of your desktop that is saved as a .suite file. IT IS FREEE.
Download
http://storage.stardock.com/files/thememanager_free.exe
_____________________________________
THE HELL IS FULL SO I AM BACK WITH DIGIT.
Curious Guest is offline
Old 18-05-2005, 11:09 PM   #2 (permalink)
NikhilVerma's Avatar
Just a small ques..... Does it work on uxtheme.dll patched systems.... And does it support The XP themes??
NikhilVerma is offline
Old 19-05-2005, 05:07 PM   #3 (permalink)
rohanbee's Avatar
Why dont you use StyleXP for your windows XP. I am using the Full version and it is quite good. Amount of themes that come as default or only 8 though.
Quote by Garfield'
rohanbee is offline
