Old 11-10-2008, 06:02 PM   #1 (permalink)
dashang's Avatar
Default Customize your os
But i have windows xp sp2 that has customized installation and also themes and the creator has also added custom softwares.
I want change logon screen that means the logon screen should be there not microsoft original
visit my site: www.techdrome.blogspot.com
dashang is offline
Old 11-10-2008, 06:10 PM   #2 (permalink)
hullap's Avatar
Default Re: Customize your os
google is your friend
hullap is offline
Old 11-10-2008, 07:43 PM   #3 (permalink)
Core i7 (nehalem) Owner
ashu888ashu888's Avatar
yup, google for it .. also be sure to install only trusted s/w which allow for logon (boot screen) wally change option, coz i once applied a bootscreen image to change the usual Win XP imgae using (sum good renowned s/w i dont remember nw,maybe it was 'talisman' or sumthing else..) and it jus made my bootscreen FREEZE..
instead apply a vista transformation pack,(google for it) and ur PC will be new overall..
Cheers n e-peace...
this is a screenshot of my desktop (i hv applied the vista transformation pack+xp SP3) jus to giv u an indication of how well ur desktop can be modified but yet simple and lite on the system
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
Last edited by ashu888ashu888; 11-10-2008 at 07:50 PM. Reason: Automerged Doublepost
ashu888ashu888 is offline
Old 11-10-2008, 08:28 PM   #4 (permalink)
The Black Waltz
You can install TuneUp Utilities 2008, which contains many different tools to tune and maintain your XP system. You can also use it to change the XP logon screen. You can't use just any screen though, you'll have to get custom screens from the TuneUp web site.
#krow @ irc.freenode.net
Cool Joe is offline
HOWTO: Customize Ubuntu A-Z sayakb Tutorials 4 25-09-2008 09:01 PM
need a SE phone to customize which one to choose ? krates Mobiles and Tablets 9 21-08-2008 12:33 PM
Guide to Customize PSP UI NIGHTMARE Gamerz 1 03-03-2007 12:52 AM
how to customize folder anilmail17 QnA (read only) 2 07-01-2007 11:46 PM
