Old 18-05-2005, 01:12 PM   #1 (permalink)
ashisharya's Avatar
Default Does Hibernating Computer take MB?
Does hibernating take space in MBs? Whats the main benefit of hibernating computer?
To follow the path:
look to the master,
follow the master,
walk with the master,
see through the master,
become the master. -Zen
ashisharya is offline
Old 18-05-2005, 01:28 PM   #2 (permalink)
Another Brick in the Wall
drgrudge's Avatar
YEah , it will take some space, as it saves your previous settings and your running applications. I am not sure how much space it may take.
Benefits:
We can continue our work from the previously working applications...and no need to start the programs once again in case u need to work with the same application after u shut down.
drgrudge is offline
Old 18-05-2005, 01:53 PM   #3 (permalink)
expertno.1's Avatar
i am unable to get the hybernate option .
it is not lighted .
why ?
is there any problem ?
expertno.1 is offline
Old 18-05-2005, 01:59 PM   #4 (permalink)
Control Panel--> Power Options-->Hibernation-->Enable Hibernation. Wat say dr???
Shwetanshu Srivastava
shwetanshu is offline
Old 18-05-2005, 02:00 PM   #5 (permalink)
godsownman's Avatar
yes the hibernate option takes up space as much as that of your RAM.
If your RAM is 1 GB it takes up 1 gb of space
@expertno.1 which OS are you using.
If your using xp then press shift when the shutdown dialog box come and see stadby change to hibernate.
If that does not come then you have to do the following
Control PAnel-> display-> screensaver
in the screensaver box on the bottom right you will see a button as power
click it the Hibernate Tab and enable it .
That should do it .
I think these steps wil work for win 98 also.
From the body of one guilty deed a thousand ghostly fears and haunting thoughts proceed !
Visit (http://www.meebo.com)
godsownman is offline
Old 18-05-2005, 02:02 PM   #6 (permalink)
godsownman's Avatar
Also if you cannot enble it using the steps that I gave above then there is a conflict between certain drivers that are causing it to disable.
Old 19-05-2005, 10:41 PM   #7 (permalink)
Netjunkie's Avatar
Some older versions of Logitech Drivers seem to have a problem with the hibernate feature.
Uninstall all Logitech Drivers or update them with the latest versions & u can enable hibernation.
Netjunkie is offline
