Old 18-05-2005, 12:26 PM   #1 (permalink)
Default IrDa Query
I came across the term Irda when i went mobile hunting. the dealer told me i can use an irda device to sync the mobile(K508i) with the pc. what i want to know is, what kind of device would i need, is it a plug and play device or is it different. and how much would it cost .
In the keyboard of life, always keep a
finger on the ESC key
shyam911 is offline
Old 18-05-2005, 01:21 PM   #2 (permalink)
Another Brick in the Wall
drgrudge's Avatar
U need a IRDa dongle. It's like a small hardware (how can i explain, go to a shop and ask for the shopkeeper to show ).
It will cost 500rs onwards...
drgrudge is offline
Old 18-05-2005, 01:43 PM   #3 (permalink)
Oh ok, it that a USB device?
shyam911 is offline
Old 18-05-2005, 01:49 PM   #4 (permalink)
drgrudge's Avatar
Yeah it is... , u need it to connect it to USB.
drgrudge is offline
Old 18-05-2005, 01:51 PM   #5 (permalink)
Ok Thanks a lot.
shyam911 is offline
Old 18-05-2005, 07:02 PM   #6 (permalink)
expertno.1's Avatar
does there is a need of driver or will xp detect it automatically and install plug and play for it ?
expertno.1 is offline
Old 19-05-2005, 01:35 AM   #7 (permalink)
Technoholik !!
Tech&ME's Avatar
YES ! Windows XP will detect is and install drivers for it automatically. However you will be provided with a DRIVER CD with the package and if you wish you can install the CD driver which came with the product since the CD drive will also contain additional software for using your Irda Device. In general it is not required. XP will do everything for you.
[Desktop]
[Laptop]
Tech&ME is offline
Old 19-05-2005, 01:46 AM   #8 (permalink)
expertno.1's Avatar
from where can i download online if necessary ?
Old 19-05-2005, 05:13 PM   #9 (permalink)
Get it from www.driverguide.com
It is better to light a candle than to curse the darkness.
Shikhar is offline
Old 19-05-2005, 09:36 PM   #10 (permalink)
AMD user for 9 yrs!!
rollcage's Avatar
winxp installs the required drivers when it first dedects the IrDa instrument...
like if you put phone...nokia 6020 or something
it also installes the Drivers for the modem.
rollcage is offline
