Old 02-09-2004, 04:56 PM   #1 (permalink)
Default Wanted Data Cable for Nokia 1100
I want a DATA CABLE for my Nokia 1100 as soon as possible.
Please contact me at the earliest at fatmi_zeeshan@rediffmail.com
or pm
zeeshan_04 is offline
Old 03-09-2004, 01:02 PM   #2 (permalink)
spykids_666
Posts: n/a
hi,
first tell me what ur budget is. the original ones are costly and the duplicate ones are cheap. ( i didnt see any difference in them).
then there is one with USB connection and other with serial Connection. (USB is faster, speed wise).
The USB one is for about 500 - 600 Rs. (duplicate).
the original ones are for about 1300 Rs (might have got cheaper)
if you cant find it in kutch. i can send you one if you want. i am from BHAVNAGAR (gujarat), thats not far from you. so the curior charges will be about 50 Rs. (I think)
Old 03-09-2004, 05:46 PM   #3 (permalink)
I really want that cable.
But I am surprised 2 know that a duplicate cable costs this much.
Can u get me a serial cable? What's the price of this?
PLease reduce the price a bit.
Reply soon
